Question about Epson Stylus RX560 All-In-One InkJet Photo Printer
Epson rx560 printer no yellow
I have put 3 new cartridges in but eaven after several head cleans still no yellow ink on print out sheet and lines on all i print yours hope fully frustrated epson user
  • 724 Answers
I thru out an epson ink jet and never bought one again. I did not use it that much and the ink dried in the head and it would not clear out.
I toke it apart and soaked it is almost all the solvents from dish detergent lye for denatured alcohol to napa tested it each time and nota so save the frustration buy a new head or a printer instead. where anytime you place new ink the heads are changed too.
Posted on Jul 24, 2009
Epson stylus c88 red ink prints yellow
print a check of the nozzles, and check what colour (magenta) is not working. If the cleaning part does not help, perhaps you should put a new cartridge in, or clean again.
Feb 17, 2015 | Epson Stylus Office Equipment & Supplies
Epson Stylus Photo R800 not printing certain color
You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Aug 15, 2012 | Epson Stylus Photo R800 InkJet Printer
Yellow ink will not print
On the Brother MFC series printers it uses remote ink trays as you will know, instead of having print heads directly on the ink cartridge. Whilst this approach makes it cheaper to produce the ink, and easier to change the cartridge, it can make it difficult to clear clogs.
There are several things you can do which may help, but B. and C. are at your own risk. All steps assume you have a new yellow ink cartridge.
A. In paint or another program, create a full page yellow image and keep printing it out. See if it gets any better after each print. If it does, continue until it seems to be working fine.
B. If you can manage to get to the print head, you can get a cue tip, dip it in rubbing alcohol and gently clean the print head. Leave 20 minutes to dry, and then do step A. again.
C. (AS A VERY LAST RESORT AT YOUR OWN RISK. THIS IS GOING TO RUIN YOUR YELLOW INK CARTRIDGE SO USE AN OLD YELLOW ONE IF YOU CAN) If steps A. and B. fail, you can put a "little" rubbing alcohol in the Yellow Ink Cartridge, and keep trying step A. If Yellow starts printing again, swap to a yellow cartridge that does not have rubbing alcohol in it. You are now going to have to cycle through many pages to clear the rubbing alcohol from the ink lines.
Note that if you keep cleaning the cartridges, it is going to use a lot of ink, and may actually hinder solving your yellow ink problem.
Good uck
Apr 24, 2010 | Brother MFC 240C All-In-One InkJet Printer
Epson r265 keeps printing purple pictures I have installed new cartridges and done a head clean several timesbut i just won't budge
You probably need to purge the yellow ink channel. Use the cleaner found in refill kits and gently force the cleaner through the channel where the yellow ink cartridge attaches.
After cleaning, you will need to "charge" that ink channel either by many cleanings or by forcing the yellow ink into the channel before installing the cartridge.
Nov 03, 2009 | Epson Stylus R265 InkJet Photo Printer
Dx8400 printer, red ink not working, fitted new cartridges blue yellow and black work but no red, done all the print head cleaning and nozzle checks but no luck
Possibility is that the nozzle might have been clogged. try to perform a cleaning cycle for about 3 to 4 times if it still does not work reseat the ink cartridge affected
Sep 23, 2009 | Epson Office Equipment & Supplies
No yellow
buy a new one srry man if u eney thing els tell me at alexswierenga@yahoo.com
May 29, 2009 | Epson Stylus Pro 7600S InkJet Printer
Epson CX3650 printing gaps
Remove ink cartridges one by one and put it back in. If same thing happens, try to do head cleaning and nozzle checks consecutively from the computer.
Start -> Control Panel -> Printers & Faxes (Windows XP) / Printers (Windows Vista) -> Printer Icon (right click) -> Printing Preferences -> Maintenance
You should be able to see nozzle check, click it and follow the prompt. Line patterns that corresponds to the colors of the ink cartridges would be printed. If breaks on the patterns appear, continue with head cleaning. Try to do this about 3 times until all patterns are complete.
Dec 21, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Very Faint Printouts
I find the best way to clean the heads is buy some cleaning cartridges as they have cleaning fluid in them and use them to clean it will take about 10 or more times to clean the heads then put the color ones back in and try again.
Just keep putting it on clean the head don't do a print out till at lest you have cleaned 10 or more times.
Rgs
The StickMan
Dec 08, 2008 | Epson RX620 All-In-One InkJet Photo...
Not printing Yellow
hi,
most likely the printer needs the printhead replaced it is proberly clogged and it cannot be cleaned. a printhead can be purchased from the manufacture or a dealer just go to there website.
Mar 14, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Continuous aqua/turquoise color even with new cartridge
hey Karyn. The problem that I have experienced with printers with the same problem is a dirty head. Get the instructions on the printer and it will tell you how to clean the head. If after cleaning, still does it then you need to purchase a new head for the machine. Dont be afraid to tear into it. printers are pretty simple. Ink and ink head. If it prints at all it seems to be a dirty head. or worn out. Watch out using ink refills or off brands. Some inks are not very good quality ink and will ruin the head and void the warranty. Use the ink that the machine requests. Staples or Office Depot carries several types of printer heads. Good luck.
Sep 04, 2006 | Epson PictureMate InkJet Photo Printer
Epson Stylus RX560 All-In-One InkJet Photo Printer Logo
155 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
