Question about The Computers & Internet
My Aqualink stopped following the program schedule. When I go into schedule on the screen, I cannot make changes to the schedule and get a "waiting for connection press setup to configure" message.
sandrew
  • 2961 Answers
SOURCE: Plug & Play Configuration Error
this may not be your ethernet card that is causing the fault, it is probably a flat cmos battery (CR2032) disc shaped battery normally close to the memory slots. This will need to be replaced, it's a simple job, just remove side panel of tower and flip the battery out and replace, probably cost $3.00. You will then be prompted on the next boot up to press f2 to set the date and time and then save and exit again for a reboot
Posted on May 29, 2007
  • 15 Answers
SOURCE: I have an Aqualink RS4. I want to delete the 3
The best thing to do is to clear the system memory. Aqualink can have a problem with "ghosting" Things just go on by themself when not programed to. A bad spa side remote can do that to but that is another problem.
To clear the memory
Push the menu button once
Push the back arrow to "System setup"
Push star * or enter button
Push back arrow till diplay says " clear memory "
Push star or enter
Push star or enter again to comfrim.
You will get a message "earsing memeory"
Now you can reprogram system
If you want differant run times like a summer and winter timing you can do that with the program groups
Hope this helped
Keith
Posted on Jun 23, 2009
SOURCE: invalid configuration information-please run SETUP program
Here is what you do, go into the BIOS setup, usually you press the DEL key OR F2 or whatever your one is, IT should say on screen as it boots up.... it says "Press YOUR- KEY Key for SETUP". So, get into setup, using your manual ensure it is set correctly. Then SAVE SETTING and exit All should be good now.
Posted on Feb 06, 2010
SOURCE: DVD stopped working and cannot do setup.
You probably need to reset your DVD/VCR/Combo. Go to www.samsung.com. Go to <Support>. In the search box, type in the model of your DVD/VCR/Combo. Or type in, >how to reset DVD/VCR/Combo<. Each model has different reset method and there are hundreds of models!
853. How To Reset Your Samsung DVD Player STEP 1
STEP 1. DVD Reset List
Samsung DVD players have a built-in reset procedure that resets the DVD player to the factory defaults. You can use the reset procedure to reset settings that don’t work with your TV or to resolve issues such as unit lock up. To run the reset procedure, you press one or more buttons on the front of the DVD player and hold them for at least fifteen seconds. The buttons your press depend on the model you have.
Important: For the reset procedure to work, you must press the buttons on the front of the player, not on the remote control for the player.
Below is a list of all Samsung DVD players and the buttons to press to run the reset procedure.
DVD511 - Stop / Play
DVD611 - Stop / Play
DVD709 - Stop / Play....
Many, many other models follow but cannot be listed here because of this site's text limitations.
Posted on Mar 22, 2010
SOURCE: Mystery message "wait" appears above "following
Mystery message "wait" appears above "following schedule" display line on our Th8000. Ac does not come on even when temperature is in range. Fan operates ok. Is "wait" setting one I can reset? Maybe a compressor issue rather than thermostat? Thanks
Posted on Oct 22, 2010
How can I disable the pump clock on the intelliflo variable speed pump
check you tube for programming you have to put it into the controller mode or it will override it
Aug 11, 2014 | Pentair IntelliFlo VS-3050 & VS+SVRS...
Aqualinks rs4
Go to menu , program the pick pool and input your desired schedule.
Make sure the day and time is set correctly!
Jul 21, 2014 | Jandy Aqualink Rs4 One Touch Control...
Thermostat is following a schedule when none is set
Your Lennox thermostat could be defective, but it may have been programmed by some inadvertent button pushing. The thermostat also has certain default settings such as a low limit that will trigger heating if the indoor temperature becomes too low (to prevent freezing of pipes).
Feb 09, 2014 | Heating & Cooling
I have a jandy AquaLink RS PDA screen that has Handheld 1.38 and ----Waiting----- on screen. Anyway to reboot?
shut everything off turn aqualink back on then turn on PDA if still doesnt make sure wire to antenna not cut
Mar 27, 2013 | Jandy PDA-PS8 Aqualink RS PDA PS8 Wireless...
How do you reset the programs? Unit is saying
You need to hit the menu button and go into program. In there you will see each item, such as the filter that is on a schedule. When you hit the filter, it will have 3 options, add, remove, or change. Just hilight the schedule and hit remove, that program will be deleted.
May 15, 2010 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Every program scheduled to record starts and ends five minutes early? So the end of the preceding program is recorded and the end of the selected program is cut off.
BigBillO,
One of the options for the DVR recordings is starting and ending before the program starts and ends. You can change this setting to your preference. To change , press the DVR button 2 times on your DISH remote. This will bring up the "My Recordings" screen on your TV. Go to "Schedule" button on the right side of the screen. Press select. You should be on the "Daily Schedule" screen. Go to "Timers" button on the right of the screen. Press select. You are now on the "Timers List" screen. Select one of the programs scheduled to be recorded and press "Select". You are now on the "Timer Schedule" screen. Go to "Options" button and press select. You are now on the "Timer Options" screen. This is the screen you can set your preference for the "start early" and "stop late" settings. Be sure to select the "Set as System Default" if you want to apply this setting to all your recordings. I hope this helps.
Ray Calo
DISH Network
Mar 20, 2010 | DISH Network ViP622 DVR DTV Receiver /...
I have an Aqualink RS4. I want to delete the 3 programs scheduled under filter pump. How do I do that?  Thanks
To clear the memory
Push star or enter
Hope this helped
Keith
Jun 18, 2009 | Jandy AQUALINK RS TELELINK KIT
Need to clear a program from my aqualink
Start with the cancel button. It will then prompt you to cancel the desired program. Go through the menu as you would with a program but follow the prompts to cancel. Remember, press cancel to start.
Dec 26, 2008 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Computers & Internet Logo
29 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
