Question about Electrical Supplies
No spark in onan 6500 generator LP gas - Electrical Supplies
    Top Expert:
  • 45,551 Answers
Check the operation of the low oil level unit as it shuts off the spark if the sump oil gets low
Posted on Apr 24, 2017
I have a 2006 winnabago with onan marquis gold 6500 lp generator that won't start
Check the Onan web site for troubleshooting. Otherwise it's probably time to go to an RV center to have them check it out.http://www.cumminsonanstore.com/
Oct 13, 2014 | Electrical Supplies
Troubleshooting generators
Not normally, the board outputs to the fuel pump, or LP shut off solenoid. It doesn't know the difference.
Aug 12, 2014 | Onan CUMMINS 5.5 HGJAB-6755 - Cummins...
I have a 6500 lp onan marquis generator in my rv that wont start. any suggestions?
Check the fuel. If old, drain & refill it.
Check for spark.
If the fuel is there and good, trace it to the carburetor. Check the carburetor bowl for fuel.
Check the spark plug, the magneto, any switch that breaks the circuit or kills the circuit for spark.
If you're getting good fuel to the carburetor and you're getting good spark, try to start it with ether spray.
You might also want to check compression while you're checking everything else.
Jul 26, 2014 | Onan Marquis Gold 6500 Lp
Onan genarator will not crank
If it wont crank, check to see if the solenoid on the starter pulls in, the starter and solenoid are one unit, it sounds like an internal starter contact, if you have 12V going to it. Assuming the battery is good. When you press and hold the stop button does the fuel pump pump prime? if so control board has power
Mar 24, 2014 | Onan Generator, 6500W, LP Vapor
My Onan 2500 Microlite LP starts when cold, but soon quits until it gets cold again. I think that the fuel inlet valve needs and adjustment. How is this done?
I would not adjust it, I would say the unit has sat and carb is gummed up. Flush with sea foam and run for as long as you can under heavy load
Oct 08, 2013 | Onan MicroLite 2500 & 2800 LP Gas...
Electric control circuit for onan 6.5 hgjab-1272
Did you get this fixed? this is an old post. If not visit www,advanced-power-technologies.com (Cert Cummins Dealers) They can answer your questions.
Mar 07, 2013 | Onan Cummins 6.5 HGJAB-1272 RV QG 6500 LP...
I need a manual for onan 6500 lp genset
You can buy a service and or operator manual from advanced-power-technologies.com
Aug 13, 2012 | Onan Cummins RV QG 6500 Generator, 6500W,...
I have a 6500 lp onan marquis generator in my rv. It starts then stops after 15 seconds or so. I did a code check on it using the manual and it read code 47. Controller not reading generator running. Any...
ONANS ARE PRETTY QUIRKY AS IT IS NOT CONSUMER FRIENDLY. THE GENSET IS DESIGNED FOR ROUTINE AND SIMPLE MAINTENANCE PERFORMED BY THE OWNER, AFTER THAT, U WILL NEED TO TAKE IT TO THE NEAREST DEALER OR CUMMINS DIESEL REPAIR SHOP.
Jan 10, 2010 | Watts Onan Portable Generator - 5000 ,...
Onan Marquis Gold 5.5 HGJAB 1038C. Won't start.
Test the solinoid with an ohms meter and if the circuit is open replace the solinoid.
Oct 22, 2009 | Watts Onan Portable Generator - 5000 ,...
Electrical Supplies Logo
32 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
