No raster/brightness/video. the screen is black
Raster with many colour , sound OK ,low brightness
Degaussing problem. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Apr 24, 2015 | Televison & Video
Tip
White Raster with thin lines; Sound Ok.
White raster with retrace lines: No picture, Sound OK
(picture tube based telivisions.)
It is a common fault to occur in most of the CRT based telvisions, regardless of which brand it is. There will be sound OK, and a bright screen with thin white horizontal lines across; at about an inch space, all over the screen area. This fault may occur along with colur shades also, like blue screen with white retrace line, red screen with white retrace lines, green screen with white retrace lines. Let us take the first case. A white raster with white thin retrace line acorss the screen. These are call vertcial retrace lines technically. To make it mor understand, we have to go to some picture tube electrode details. There are three colour cathodes for a colour picture tube, Red, Blue and Green. Two girds are there called Focus and Screen. Focus grid is supplied with focus voltage which in turn determine the cocus of picture, and screen grid is supplied with screen volrage which determine the emission of the picture tube; in short. There is a final anode to all the picture tubes, which supplied with Extra High Tension voltage, can be located at the top side of the picture tube, to which the EHT voltage from LOT is connected with the help of rubber ****** and clip. Without these three voltages, EHT, Screen and Fcous, no raster will be produced. Therefore in our case, there is a raster, so, horizontal output section including Line Output Transformer [LOT] is functioning well, and as far as sound is there, tuner and video IF section are working well. In fact, all other section except, video output section is working properly.
There are three cathode points on the base card, marked as Bk, Rk and Gk. Check the voltages of these three cathodes. In our case, it will be very low or approximately equal to zero. When cathode voltages goes low, emission of the CRT increases, is the reason. There must be a voltage between 120 and 135VDC at these points. Find out the reason for this voltage drop is the next step. The video drive voltages in most TVs comes from LOT windings, after rectification and filtering. There will be one reisitor of low value, say one Ohms or so, will be connected series with this winding, in between diode and winding. Check the voltage at the cathode of this rectifier diode first. If found low replace the diode and the smoothin capcitor. The smoothing capacitor will be between 33 and 47MFD 250VDC rating. Replace both of them. If there is volatge, say 200VDC or so, check whether this voltage comes to the CRT base board or not, If not, check the conducting wire, serial resistors; if used for open. There is no chance of transistor shortage at this time as the raster we see is white. If raser we see have a specific colour predominent, that is green, blue or red, check the revalent video out transistors and replace it. It is best to replace all the three video output transisors at the same time with same batch and number.
on Apr 18, 2011 | Televison & Video
No picture, no menu, black screen, no raster, sound ok
From your detailed description, it sounds that the main chroma processor IC has damaged. Raster means nothing, but the lighted screen that appears, when a TV is switched ON. For some brands, there will be a blue screen; when there is no signal input, and some others will have a bright white screen with some snow.
I advice you to contact any service technician, to get this TV repaired. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 07, 2014 | Televison & Video
No picture but has sound
First make sure that the brightness and contrast are turned up.If the screen is lit up (that is you have a raster) then the problem would be in the video circuits.If the screen is not lit then you have a problem in the deflection circuits.A good possibility,with no raster,would be the Horizontal output amplifier.If you are not familiar with circuitry you would need a tv tech.to do the repair.
Sep 14, 2013 | Toshiba 32AF43 32" TV
Retrace green, relay on/off..when turn on the screen is green and after a few seconds it turns off by itself
Oh dear ! I fear my answer may not be what you want hear but my advise is free. Bright green raster with Flyback (retrace) lines may indicate a heater cathode short in the tube (crt) this causes a sharp increase in beam current and the power supply shuts down into standby mode. To prove the point isolate the red and green cathode pins on the tube base and cross couple the red video output stage to the green cathode pin and the green output to red cathode pin using wire links. If set now comes on with bright red raster the fault is in the green video output stage and not the tube. If still bright green then tube is most likely cause. Gently tapping the tube neck may prove the point, but take care the tube neck is thin glass and if hit too hard will break compounding your problems. WARNING if you do not feel totaly confident to attempt this level of repair there is no shame in seeking the advice of your local service technician. Safety first always
Mar 04, 2010 | Sanyo 21MT4 21" TV
Thin diagonal lines on screen. How to adjust whit balance ,screen end focus?
Is that diagonal thin line about 10 to 20 degree slant? And then you have a very bright raster?
Then you set the flyback(for tube tv), I think its "screen" voltage is set too high adjust it slowly to lessen the brightness. It is commonly a small pot on the side of the flyback together with the focus pot.
If you have raster turn the tv on, use insulated screw diver, then slowly turn the knob to the direction(CC or CCW) where your raster go dim.
Be careful your dealing with live and high voltage. If your not inclined on electronics better not to.
Oh BTW, set your settings to normal.
Sep 30, 2009 | Televison & Video
IM A TV TECH. I HAVE A SONY LCD KP-60XBR800 I HAVE NO RASTER. POWER OK, MENU OK BUT NO RASTER ON TUNER, TUNER VOLTS OK,CAN YOU HELP ME PLEASE. THANKS my email sergioaguirre0182@hotmail.com
check the high voltage with the screen control turned up high where there is no raster. suspect problem within the video circuit where there is no high voltage or defective picture tube.some time when the screen is black and the screen control advanced,you can see if the tv has video or vertical or horizontal problems on the screen.service the high voltage circuit if there is no raster or high voltage is seen.no raster can be caused by the no heater or filament in the CRT.---- a defective picture tube can cause many problems, such as, poor brightness ,missing colors,intermittent picture,poor focus,a single-colored raster,arching in the gun assembly,retrace lines in the picture,negative picture,chassis shutdown,noheater or filament lit and no raster to name a few.an open filament or heater can cause no picture or no raster symptom.a defective CRT can have an extremely bright screen.loose particles of the cathode element can lodge between the grids and cause an intermittent black and white picture. simply tap the ends of the CRT gun assembly and notice if the picture begins to flash off and on.---- with a leaky picture tube after turn on the raster dims and get extremely bright.a dim picture with no green in the raster can result from a bad green assembly. a heater-to-cathode short can cause a raster to change colour or a result in no raster at all.replace the picture tube if there is severe arching in the neck of CRT. excessive brightness with retrace lines and a vertical collapse to a thin line can be caused by a bad coil on the neck board of the picture tube.rejuvenate the picture tube when there is very bright green screen. check for the resistance change on the resistors of the CRT neck board for an excessively bright picture with retrace lines.excessive dust inside the CRT spark gaps within the picture tube socket can cause the very bright raster and the chassis shutdown.a defective video amp,luminance buffer,or reference transistor can cause a bright picture with retrace lines. -------- for getting any required parts to replace you can get it from www.radioshack.com or from www.partstore.com or from www.shopjimmy.com --------- thanks.please do rate the solution.thank you for using fixya.keep updated.
Sep 06, 2009 | Televison & Video
No picture
Good Day;
No video, has raster and sound, check I012, 3.3 Volt reg.
Good Luck, big IRISH.
Jul 26, 2008 | Hitachi 53FDX01B 53" Rear Projection...
Mitsubishi proyection tv
what model mitsubishi do you have. It has to be video related not deflection or you wouldnt have the menu screen. Do you have snow, retrace lines or black screen? Let me know your model.
Jan 19, 2008 | Televison & Video
Sanyo TV Model# DS32224
This is usualy because there is either a high voltage regulation fault, or a main power supply regulation fault.
There are many things that can cause this. When the high voltage goes too far down, the raster will enlarge. High voltage regulation can be caused by faulty components in the feedback sensing, or in the high voltage multiplier, or in the flyback windings itself.
A quick way to sort of know if the high voltage is regulating is to wind the brightness and contrast from one extreme to another and observe the raster size. If the raster is changing size with the brightness on the screen, the regulation is not working well. In some of the low cost sets there will be about a 2 to 5% raster size shift in this case. The high end sets will have a near 0% shift in the raster size. A size change of about 2% is acceptable for most sets. If the CRT is weak, this test will not work well, because a weak CRT will not properly load.
If the main power supply is operating slightly over voltage, the raster size will increase. Usualy, the brightness will be a little on the high side when the supply is too high. Voltage regulation faults can be from warn components in the voltage regulator area, or in the feedback control.
This should be looked after by an experienced TV service tech. This type of fault can be involved.
Jerry G.
Nov 09, 2007 | Sanyo DS32224 TV
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
