Question about Kenmore Washing Machines
We have a Kenmore washer model 110.82874120 and the control knob for off/on on the right side has broken loose from its metal screw attachment. How may we get a replacement?
SOURCE: whirlpool duet washer model GHW9400PWO
Removing the Washer Top
Three screws secure the washer top at the back of the washer. Remove the three screws and lift the top from the washer.
Removing the Console from the Cabinet
Disconnect the Touch Pad/LED Assembly ribbon connector from the left side of the Central Control Unit and release it from the wiring harness brackets on the right side of the washer top
Remove the detergent dispenser drawer by pressing down on the release tab at the back of the drawer and pulling it completely out of the washer.
Once the drawer is removed, remove the screw in the recessed hole next to the drawer opening. Release the tab securing the right side of the console to the washer
Open the washer door and place a flat-bladed screwdriver into the slot in the bottom center of the console. Push the console up to release center console tab. Be sure the ribbon cable clears the cabinet frame.
Removing the Touch Pad/LED Assembly from the Console
The Touch Pad/LED Assembly is removed as a single unit and contains the Push Buttons, LEDs, cable, etc. The buttons can be replaced separately
Posted on Oct 05, 2008
  • 60 Answers
SOURCE: Kenmore 70 series. knob -timer-button
The knob is a simple screw on knob and the replacement part number is 3353309. Cost is 16.50. It will have a metal back as opposed to the plastic one you must have now. Shipping would Should you choose to order, follow this link:
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Posted on Nov 09, 2008
  • 1214 Answers
SOURCE: kenmore washer 110.92292100..Washer Timer Control Knob is broken,
If the knob is tight on the timer stem, then the timer has failed.
If the knob is loose, then maybe just the knob has failed.
You can order either of these from a number of places. One I recommend is searspartsdirect.com. YOu just enter your model number and find the exploded view for the controls. If it does not find it, drop a number off the end of the model number that you've given and try again.
They are easy to replace.
Reply back and I can give you more advice or instruction.
Posted on Feb 03, 2009
  • 107 Answers
SOURCE: Kenmore Series 80 Washer timer knob spins
Something in the timer came apart. Timer needs replaced. When in good working order, the timer should ONLY ever be turned clockwise..Reversing this could break it.
Posted on Mar 13, 2009
  • 686 Answers
SOURCE: Wash cycle knob turns without controlling wash cycle
it's possible go to www.repairclinic.com and enter the numbers you have posted and it will show you what they are. I have the same problem. What I did was not pretty but it works for now. I broke a piece off of your part#387997 and simply turn my dial that way and then pull the center out to start the wash. Considering a new timer is close to $100+ and it works fine this way , well you know...
Posted on Apr 06, 2009
How do i remove the top front panel (the one with the lights/knob) on my Kenmore HE2 Washer? I take out the screw by the dispenser, but am not sure how to remove the other side?
I am not familiar with your model of washer. In my limited experience further screws are often found behind control knobs and other fasteners can be rather difficult. Some control panels need to be raised upwards to be disengaged after the screws are removed and some need an application of carefully applied brute force and some leverage from a slim tool slid between the panel and the cabinet.
This type of panel is retained in the middle by a snap-in fixing that due to the design tends to freeze into position so the application of force is more likely to break the fixing than release it.
If the end of the fixing is visible and accessible inside the cabinet it might be possible to close the legs of the fixing and push it through the hole.
Apr 10, 2018 | Kenmore Washing Machines
Remove front panel on kenmore washer dryer stack model110.26182
Model# 110.88752799 Kenmore stacker washer/dryer
Q; How do I remove the front control panel? (to remove the timer dial, to replace a switch, etc)
A: reference diagram- http://www.searspartsdirect.com/partsdirect/partsdirect/printSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fK1105180-00001.png
-remove four crews (#8 on diagram) from left and right sides.
-remove one screw (at #21 on diagram) from the bottom of the panel.
-remove #7 panel from the left and right side
- this will expose a thin metal catch (#9) on each side. With a small finger or screw driver, push down on the top of this metal strip where it bends horizontally. This will compress the spring (#14) and release the catch.
- the control panel will fold down now.
Jun 01, 2012 | Kenmore 98702 Stacked Washer/Dryer
Washer displays "suds" and then "f 35" and will not operate? what is this code and how can it be repaired?
Just tilt the washer back and prop it up with some wood blocks. Three screws are right on the front at the very bottom. Use a 9/32 socket to remove them. The front cover slides right off. The drain trap cleanout is right in the middle. Turn the large white knob counter-clockwise to remove it and clean.
Thank you !!
Jun 16, 2010 | Kenmore Elite 45986 Front Load Washer
How to access the timer on my kenmore 11026962502
((((top load washer machine )))
first UNPLUG THE WASHER FROM THE POWER OUTLET..!
On the headpanel looking at the knobs
you will see the side covers on the end of the head panel. depending on the model of course, the side covers pop out
lift the bottom of the cover slightly, then the top an pull to the outside
then use a philips screw driver to remove the two screws one on each side, then slightly move the headpanel towards the back , then raise it then up an you right in it
to remove the timer you will see some srews holding the timer from the back, and to remove the knob pop the time knob out an turn it clock counterwise an the knob will come off
just a comment am not sure why you chancing the timer on your washer, but iin case your washer washes an stops right at the spin cycle, and is fill w/water. is not the timer that is bad, check the lid switch may be broken!
good luck post some feedback!
Feb 01, 2010 | Kenmore Washing Machines
Apr 06, 2009 | Washing Machines
Nov 02, 2008 | Kenmore 22422 Top Load Washer
Kenmore 80 Series - water wont fill to full load
remove edge decore trims from left and right side front of control panel8b608f8.jpg
remove phillips screws from bottom corners of contol panel
remove knob from water level selector
raise control panel ~1 inch then flip over backwords on pivots
depress lock tab on right/underside of water level control body where it touches metal mount plate
rotate water level control body 45deg anti clockwise
pull body off
top side of body next to knob shaft is 1/8 hex head bolt
turn clockwise to rais water level
anticlockwise to lower water level
machine can be operated with this part not fitted so can check level. fill, adjust screw, fill will start again, adjust screw, until water level is correct
reinstall in reverse order
Incidentally, the cause is a VERY small wire spring inside the control body that is not really up to the task, and stretches over years.
Its a common occurrence, and I make this repair, on callouts, no parts required, couple times a month you may have to flip the switch to reset to get the water to restart filling
Oct 25, 2008 | Kenmore 24032\24036 Top Load Washer
Removing the top
the pressure sensor is inside the control panel, the panel is screwed closed from the rear
you initially check that the plastic air line is attached at top and bottom
top is easy
to reach the bottom
the top of the washer must be removed, unlock the two metal clips at the front ~3 inches from the edges by sliding a putty knife or other blunt blade between the front panel and the top
tilt up the top
visully inspect the air line running from the top left to the bottom of the drum/tank
usually the top comes off
test that first,
because if the bottom is off, there would be water running all over the floor as the pressure sensor attaches below water line
if both hose ends are attached remove the top end and blowe down it, any water in the line messes up pressure readings
the water level sensor is adjustable
remove the water level sensor body from the control panel, there is a lock clip on the right side of the control body
there is a 1/8th nut next to the shaft the knob sits on
clockwise to raise water level
counterclockwise to lower water level
if turning the adjuster has no effect, the spring inside has broken, not weakened, and the control body should be replaced.
water level control bodies are common to many models and makes, the local parts store will have a suitable one, even if labelled ge or kenmore instead of maytag
Aug 21, 2008 | Maytag PAV2300 Top Load Washer
Kenmore 110 timer
the allen head screw should be for the holes. they should tap themselves. with washers the metal is so thin you don't really need selftapping screws. but not know what model you have i can't be 100% sure. good luck
Aug 06, 2008 | Washing Machines
Kenmore 70 Series heavy duty washing machine
Kenmore
depress lock tab on righ/underside of water level control body where it touches metal mount plate
rotate water level control body 90deg anticolckwise
pull body off
Mar 01, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
56 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
