Question about Hayward Pool & Spa
Dc low voltage reading hayward multi speed pump. What's wrong?
    Top Expert:
  • Hayward Master
  • 7,897 Answers
Possible bad two speed relay
Posted on Jun 09, 2017
longbranch1
  • 16 Answers
SOURCE: what type of thermostat do I need for a used master cool evaporat
Look in your yellow pages for an ac distributor that carries your brand of equipment
Posted on May 21, 2009
  • 16 Answers
SOURCE: High speed setting on pump won't work.
might be the starter capacitor or run capacitor
Posted on Aug 23, 2009
john224
  • 1378 Answers
SOURCE: I have a challenger 2 speed spa pump. Only the low
You are correct. Appaently you have a short in the winding connection and that is not a do-it-yourslef type of repair. Unfortunately, the cost to fix something like that is high since it is labor intensive and you may want to look into a new motor since the chances of additional or near future failures is likely. If you would like a quote on a new motor, contact us thru www.arrowmotor.net and be sure to include the voltage you are connecting to as a 1.5 HP is available in both 115 and 230VAC.
Posted on Sep 25, 2009
  • 1891 Answers
SOURCE: A.O. Smith 2 speed pool pump motor won't start in
if this motor has a cent sw it is bad / replace the sw and if is shaded pole the winiding are bad .. the motor needs repari .. mm
Posted on Aug 17, 2010
MOTORWIZJ
  • 1383 Answers
SOURCE: my hayward super II pump
VOLTAGE IS SET FOR 230 AND YOU ARE RUNNING IT ON 120V BACK OF THE MOTOR HAS A WAY TO SET THE VOLTAGE.LOOK ON TOP OF THE MOTOR FOR THE WIRING SCHEMATIC . THERE IS A START AND RUN SPEED.. HOPE THIS HELPS VOTE Jay
Posted on Jan 31, 2011
My abs light and my battery light is on. new battery ran down in less than an hour.
check for voltage from the alternator, charge the battery ,, with a multi meter set to DC volts ,, check voltage, you should have a reading just a little over 12v dc, then start the car,, check again, you should get a reading between 13.5 volts to 14.5 volts , if you have that your alt is good,, if not Its not charging the battery as your driving, having a low battery makes the computer go crazy and it looks for anything wrong,, Ive had dash lights for everything light up ,
Jun 23, 2011 | Oldsmobile Aurora Cars & Trucks
My hayward super II pump is cycling between hign and low speed every i second until it overheats and shuts off. What could be the problem
Jan 30, 2011 | Hayward 1.5hp 230v 2 Speed Uprated Super...
Can you please tell me the correct wiring for a Hayward 120V pool pump (not 240V) Thank you
Follow diagram on the tag. typically low voltage and high voltage volt are diagramed on the tag. Most manufactures send pumps out already for 220. the A and B terminals are for pump wires. and the lines are for the power cord. follow the diagram and you can't go wrong;
The Pool Tech
Jul 10, 2010 | Hayward 1HP Super Pump II Inground Pool...
Have hayward 2speed pump and cant get speeds to change ontime clo
If I am following your description correctly it sounds like the booster is tied to the wrong clock...You want the booster to run with the high speed which is 'the other' timer it sounds like.
Sep 11, 2009 | Hayward SUPERPUMP 2.0 HP, 115/230V
Haywards Super Pump Tick tack sound
You may have been running it on the wrong voltage for 3 years especiallyif you feeding it 120 volts to a 220 setup. Assuming it is getting the right voltage and it clicks off and on you run winding is bad so the start winding cliicks on to bring it up to run speed opens the switch but the run winding isnt there so it repeats the process forever till it fails.
Jul 15, 2009 | Hayward Pool Products HAYWARD 1.5 HP 2...
Pump motor runs very shot time turns on and off continuously
You have to go by the name plate connection for correct voltage and two speed operation. Check name plate and verify incoming voltage. Connect motor accordingly.
Jul 13, 2009 | Hayward 1.5 Hp Northstar High Performance...
Not getting full power
usually indicates low voltage. get a volt meter and measure voltage.
David
May 21, 2009 | Hayward Power Flo Lx 1 1/2 Hp
Pool & Spa Logo
261 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
