Question about Garden
I have a trimmer that is 1 year old and the line will not feed.I have followed the instructions to the letter but it will not work.I hope you can help me.Thank you.
  • 3,930 Answers
In my limited experience all but the very cheapest strimmers have a bump feed line head fitted. These aren't foolproof but I find them less bother and less difficult than the manual feed type.
The main consideration seems to be reassembly after winding the new line onto the spool. Most spools have helpful arrows for the winding direction but sometimes the spool will fit on the spindle either way and the position of the spring isn't always obvious. I have one and the spool is marked this side top. The obvious thing is not the right thing as they assume the machine is upside-down.
Once assembled a bump-feed line head should move against the spring with a firm hand pressure freeing the spool so the direction of travel feeds out more line. The correct line diameter is important. If the head will not move up to free the spool it is assembled wrongly or an accumulation of grass, weeds and nettles has fouled the operation and it should be cleaned and maybe lubricated a little.
Posted on Apr 24, 2017
How to feed a b
hello,, how to restring black & decker,worx,ryobi,sears cordless and corded trimmers,, turn trimmer upside down,make sure bottom is clean,, push in the two tabs and pull bottom piece out,,remove the black spool,remove any old line and make note how string is attached to spool,you will need 30ft.of # 65 line some stores has this pre packaged for your b&d, insert the lone in the grove or hole and follow the arrow on the spool,line should be wound, now to reinsert the spool make sure that the spool is lined up with the slot to slot on the out side cup also on the auto feed make sure that the small half moon inside clip is towards the center,put spool on making sure to get groves in the spool slot,and get line through hole.put on cap, on the auto feed the line comes out when you turn trimmer on, you should do good to go,hope this help,any comments welcome,thank you..
Feb 15, 2012 | Black & Decker Garden
Why is line feeding out too fast on 503a
Hello! Trimmer Line Installation; Place Trimmer On Workbench Or Floor, Grasp Trimmer Housing With Left Hand Turn Middle Nut With Right Hand,Left To Right Removing Center Peace,In Some Models Suchas Electric Models The Center Piece Just Snaps In.Remove Nut Remove Line&Spool,Bottom Caseing.If Spool&Inner Housing Is Dirty Cleam With Soap&Water.Pay Attention How Line Is Inserted Through Spool,You Will Need To Reinstall Same Way.You Will Need About Twenty Feet Of # 60 Or 65 Line.Buy Line At Any Home Improvement Center. Most Trimmers Are Double Lined.Find Middle Of Line,Thread Through Holes That Old Line Came Out Of.Wind Line Accordingly To Arrows On Spool Edge. Leave Enough Line TO Insert In Groves On Edge Of Spool.Reinstall Spool Put New Line Through Holes In Outer Housing Pull Line Untail Line Is Free.reinstall The Rest Of Parts In Reverse.Hope This Helps,any comments welcome,thank you, !!
Jan 29, 2012 | Garden
My bump knob on my Ryobi elect trimmer turns although very tight and turns the bolt but is not undoing. Any solutions please
Oct 31, 2011 | Ryobi 15" Electric Factory Reconditioned...
How do I change the line on my 25 cc homelite zip start trimmer
1) Use a pair of vise grips to open the wheel on the bottom of the feede;
2) Remove the wheel, taking care not to lose the screw inside it;
3) Remove the outside wheel, feed line into one of the interior wheels and wind it around until the wheel is full following the direction of the arrow on the outside. Leave enough line (4 - 6") to feed out the holes;
4) Repeat for other wheel;
5) Replace wheel, feeding excess line into outside wheel holes on wheel frame still attached to weedeater;
6) Hold wheel together tightly and reattach wheel hub. Hand tighten only as it will tighten itself with use and require vise grips to remove again.
Hope this helps.
Nov 01, 2010 | Homelite Mighty Lite Lawn Trimmer
Grasshog trimmer line wont stop coming out and it won't break off
Rewind your string in the opposite direction than it is wound now.
If it is wound in the wrong direction it will cause the line to continue to feed out.
Good Luck, I hope this helped
Please do not forget to rate me,
Thanks
Apr 29, 2010 | Black & Decker String Trimmer Cordless 12"...
I need to put in new string -- don't know how to install. I need to know what to remove -- do I unscrew something, or do I just stick the string inside the casing?
This trimmer is an "AFS" (Automatic Feed System) trimmer meaning the trimmer uses centrifugal force and a lever that play out trimmer line without you ahving to bump it on the ground. Your trimmer uses .080" diamter line. You can get a replacement spool and lever at Lowe's fairly cheap. I would say get the spool that is already wound rather than trying to buy just the line and re-spooling...that will make this a LOT easier!
What you do to replace the line is place the trimmer on a stable flat surface (like a workbench), raise up the head of the trimmer and follow the steps below:
1. Remove the spool cover (this is the orange cap on the head)
2. Remove the spool, (observe and note the orientation of the spool!)
3. Using a pair of pliers, pull the orange feed lever straight out (observe and note the orientation of the lever!)...do not try to pry it off, you will damage the head!
4. Insert the new lever in the same orientation you noted when you removed the old one.
5. Insert the new spool and line in the same orientation as the old spool.
6. Replace the cap.
Black and Decker has an 800 number you can call if you get stuck, the number is 1-800-544-6986. Good Luck!
Nov 04, 2009 | Black & Decker 14" Grass Hog Xp...
Need Gas Line installation instructions for a McCulloch Lawn Trimmer I bought New Neoprene tubing (Gas line) for My McCulloch trimmer model B400128-11. The old lines hardened over the years, and broke off...
Hi Start from the filter in the tank to the bottom of the carby then from the top of the carby to the short primer pipe then from the long pipe on the primer back to the tank. Hope this helps.
Aug 24, 2009 | Garden
My Balck&Decker Grasshog won't automatically feed line.
Just replace the LEVER, Item #29, Part #598435-00, for about $3.00 (B&D, Dewalt). Just pull old level straight out (pliers) and push replacement in. Level end expands to hold it in place. No other parts. Forget cleaning and replacement the spool, graphite or oiling... just replace the lever.
Aug 24, 2009 | Black & Decker 14" Grass Hog Xp...
String continuously feeds and cuts
sounds like something is out of place. try again.
Jun 23, 2009 | Black & Decker String Trimmer Cordless 12"...
Troy-Bilt Trimmer won't start
try taking the carb off and you should find 2 adjustment screws on it. turn those in until they stop, do not force tight. while doing this be sure to keep and eye on how far you turn them in. they likely wiil be set at 1 1/2 turns. now that you have done this unsrew them all the way out and get some carb cleaner to spray in there and rinse any old or dried up gas out. then replace the screws at the same setting they were before you took them out. this should take care of it.
Mar 08, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
