Question about Microwave Ovens
How to use the grill function on a 1000 watt oyster microwave
  • 1027 Answers
SOURCE: MW8107WA 1000 Watts How do I set the time? .
Cant find a manual, but on most microwaves, the clock is set by pressing the 'Clock' key, then the numbers for the time, and pressing the 'Clock' key again.
Posted on Jul 13, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Kitchenaid KHMS155LSS 1000 watt microwave makes grinding noise
Chances are you have a bad stirrer motor or the stirrer blade is jamming or loose on the motor shaft.
Your owner's manual should tell you how to remove the stirrer cover to check it.
If for some reason you don't have your owner's manual, you can download it free here, as well as the parts manual for your model.
You can also find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Jan 01, 2009
scottowa
  • 87 Answers
SOURCE: Whirlpool MH1150XMQ 1000 Watts Microwave--NO HEAT
About 95% of the time it is the magnatron. If the microwave is under 5 years old that part is often covered under warranty. I would check your manual. If not the p/n is 8206335 and it's about $80 and fairly easy to install. I just looked and the magnatron is covered.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0523111.pdf
Labor to replace it would be about $125
Posted on Mar 04, 2009
  • 572 Answers
SOURCE: my frigidaire GLMV 169D 1000 watt microwave made a
the magnetron. is what heats
Posted on Feb 11, 2010
SOURCE: microwave starts as normal but cuts out after
This is happening due to either the magnetron, or the Power Diode, or both, is breaking down, under load, then the unit detects the fault condition, & then, for safety reasons, to avoid a fire or explosion, shuts down the system. You need to take it in to be looked at please obtain a "Quote" before proceeding with any work. This way you can decide to repair or replace.
Posted on Mar 24, 2010
Testimonial: "Excellent. Thanks so much for your very quick and valued help! Will do as you suggest and give further feed back on outcome. Again, Many Thanks. "
Where is the bulb located on the 1000 watt emerson microwave
outside the oven under the outer case
it is located above the small grill in the oven wall
Nov 01, 2015 | Emerson Microwave Ovens
Clicking noise when going
Sounds like a high voltage arcing. possible transformer or insulation failure causing an overload. Not a recommended consumer fix.
Feb 28, 2015 | Whirlpool Jet Chef 31 Litre 1000 Watt...
Wattage for mc 1000b microwave
By the name I would think that it is a 1000 watt Microwave. Wattage as in cooking power is what you wanted? Running wattage, a 15 amp circuit will work fine. A 120 volt, 1000 watt microwave will use 13.4 amps (1,600 watts) of electricity in a full power cooking cycle. I think that covers everything! ..:)
May 16, 2014 | Magic Microwave Ovens
JVM1340 lights not working
Behind the top grill above the door is an access panel to change the light bulb. If the bulb is good but light still don't work, its possible the door switch is bad, but normally if the switch is bad the turn table won't work either. Most likely just a bad bulb part number you would seek is WB36X10003 this is not cheap for a bulb, you maybe able to get a replacement from a local lighting center near you. its a 40 watt, 130V bulb
Good Luck
Nov 03, 2013 | GE JVM1650 1000 Watts Microwave Oven
Are you available to assist? It is not heating. My microwave is functional in all aspects, except it does not heat. Could it be a fuse?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 30, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Re: Oyster Micro-wave 1000 watts-LED Panel not working correctly.
you probably have to replace the keypad control, or you could try checking the connections to the keypad by taking the cabinet and checking the connections to see if they're loose.
Sep 30, 2009 | Microwave Ovens
Power receptacle ok. All functions not working.Dead-internal fuse? jvm1790wk01
Sounds like the fuse. I recently replaced it. Remove the grill (look on top of your microwave for two screws) and you'll see the fuse to the right side of the microwave. You can get the fuse at Home Depot.
Jun 23, 2009 | GE JVM1790 1000 Watts Convection /...
Microwave hums
Microwave not heating problems when the timer/controller board appears to function properly, are related to the following components -
1) Diode
2) Capacitor
3) Transformer
4) Magnetron
Jan 24, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Cannot remove plastic upper exhaust fan grill for cleaning
Here are the steps to take:
1. Unplug it from the outlet.
2. Remove the two screws hidden in the slats of the grille.
3. Jiggle it up and out to remove the grille.
You can download your owner's manual here.
Dec 02, 2008 | GE JVM1850 1000 Watts Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
