Question about Wagner Air Tools & Compressors
How do u take apart the outlet valve of Wagner crew 770 paint sprayer?.
  • 3 Answers
SOURCE: Sirs: I was painting, and everything was going
i will tell you what the first problem is...YOU BOUGHT A WAGNER!
i know they are priced for the homeowner and marketed as such, but they are horribly built!
but heres some things that may help...
did you check that the tip was compleately cleared?
the pinhole helfway down the shaft is likely clogged, you need a tiny pin or needle to clean it.
2nd did you leave paint in it after using it?
all sprayers are very fickle and should be completly cleared though with at least water until you see no colorization in the water.
its best to run 'pump juice' through it as well to keep the parts lubricated.
also there should be small yellow filters in the handle of the gun, which will be caked with paint once again if you didnt run lots of water through it.
i have to take my CAMBELL HAUSFELD into the shop about every 100 gallons sparyed through....fickle creatures.
Posted on Nov 07, 2009
  • 3 Answers
SOURCE: Wagner Paint crew - No pressure
In order of likelyhood:
1. There is an inlet valve where the paint first enters from the hopper. With the machine off, you can poke your finger all the way down the hole. It's spring loaded and will depress abouta quarter inch. If the inlet valve is stuck no paint will pump in PRIME or SPRAY position.
2. In SPRAY position. Motor runs for a few seconds then turns off. This means the pump is working. When you pull the trigger, if you get poor pressure, the problem is in the gun. Unscrew the handle and remove the filter. Clean out everything you can, and replace filter if necessary. Also try turning the spray nozzle 180 degrees and spray to clear if necessary.
there are more things that can go wrong, but these are the most likely.
Posted on Dec 14, 2009
  • 3 Answers
SOURCE: Wagner paint crew won't build pressure or shut off.
1. Does it pump paint in PRIME position. If yes, then the outlet valve assembly may be stuck or bad.
2. If it won't pump paint in the PRIME position, the inlet valve may be stuck, just poke your finger down the inlet hole (machine off) . It is spring loaded and should move about an 1/8".
3. The worst option is the pump piston if froze. To check: remove the plastic hopper assembly, comes off with about 4 screws from underneath. The whole thing just pulls off. Now you can see the inlet assembly with two O rings. Use the white plastic hex shaped tool comes with the spray, and stuck on the lower base of the unit. Unscrew the inlet assembly. If clean enough, you can see the end of the piston. It's about a 1/4" diameter. Turn the machine on for a moment and you shoud see the piston move back on forth. If it doesn't the piston is froze. Good Luck with that.
  • 14 Answers
SOURCE: finding a booklet for a Wagner 770 paint sprayer
You can find a manual here: http://www.portlandcompressor.com/docs/Paint-Crew-manual.pdf
Michael
www.sprayfinishingstore.com ' info@sprayfinishingstore.com
Posted on Jun 21, 2011
rockitman187
  • 2559 Answers
SOURCE: have a Wagner Paint Crew
Paint Flow Problems
  • If the unit does not draw material when the PRIME/SPRAY knob is set to PRIME, check to see if the paint hopper is empty. If paint is in the hopper, ensure that the paint is not too thick for the unit to draw. Also, make sure the unit is on level ground to allow the paint to flow properly in the hopper. Examine the inlet filter to see if it is clogged and clean it, if necessary.
    Sometimes the inlet or outlet valves may be stuck. If so, clean them. If this does not help, replace the valves. Check the PRIME/SPRAY valve to see if it is plugged and clear the valve, as needed.
Pressure Problems
  • If the sprayer is drawing material properly, but the pressure drops when the trigger on the spray gun is activated, first examine the spray tip for clogging or wear. Clean the tip or replace it, if worn out. Also, check the inlet and outlet valve assemblies for clogging or wear. Clean the assemblies or replace them, if necessary. The paint may also be too thick or coarse to spray properly and may need to be remixed to a thinner consistency. The filter in the spray gun may also need to be cleaned.
Posted on Jun 29, 2011
Remove and Install prime/spray valve Wagner paint crew airless paint sprayer?
Was the unit purchased new or used? The price of a new is about $125-170. This unit is for homeowner occasional use, not for large jobs.Was the unit working on the previous use? If so were the cleaning instructions followed and not shortcut. If paint is failed to be totally removed on cleanup it will dry inside unit.There are very few replacement parts for this unit. If the unit is not working take wrench and try to remove prime/spray valve. You will have to remove knob to access this part.
Apr 18, 2017 | Wagner Air Tools & Compressors
Why did I have a sudden loss of power?
HI, let me see if I can't help you with this problem-
You are say no power as in it won't turn on and It's new, right?
Lets troubleshoot a few things right now and see if there is a simple problem that may be causing "no power"-
1-turn the power control knob all the way while you pull the trigger
2-don't use an extension cord and try a different wall outlet
3- do you a GFI wall plug (ground fault interrupter) that needs to be reset
4- look at the power cord and check if you have any obvious damage to the cord that might be causing the problem ok
Thanks,
Perry Tradesman @ Tradesman Painting & Decorating Lic.778435
Feb 25, 2015 | Wagner SprayTech Paint Sprayer. Flexio 590...
Does a Wagner Paint Crew sprayer take lubricant?
The Wagner Paint Crew airless sprayer does not require oil for its operation like full professional sprayers. The piston is off-set from the pump chamber with the inlet and outlet valves opposite each other, however you need to protect the parts from corrosion between use and Wagner recommend running some light oil through it after cleaning. If you will be using it in a day or so for water based paint, you could run a 10% solution of their EasyGlide through it.
Sep 30, 2014 | Wagner Spray Tech Wagner Paint Crew 2750...
Won't prime
You either have a stuck ball valve, or a leak in the paint suction
Feb 09, 2014 | Wagner SprayTech Wagner Airless Paint...
Wagner paint crew model 770
It doesn't take much residual paint to dry out in hose and block it.Have you lowered the paint pressure?
Wagner 770 Owner Manual Page 8
Nov 27, 2017 | Air Tools & Compressors
Have a Wagner Paint Crew and it started out fine and then after a half hour or so, it gradually lost pressure to a small stream, I was using new paint and I cleaned the hose, screean, intake valve, and...
hello ald... use a fine piece of wire and clean the opening that the paint comes out through. It has a tendency to fill in as you spray. Joe
Jun 28, 2011 | Wagner Plumbing
MANUAL FOR WAGNER MODEL 770 I NEED A MANAUL FOR THE WAGNER MODEL 770
Here you can find the manual: http://www.portlandcompressor.com/docs/Paint-Crew-manual.pdf
Michael
Jun 20, 2011 | Air Tools & Compressors
Finding a booklet for a Wagner 770 paint sprayer
Michael
Jun 21, 2010 | Air Tools & Compressors
Air Tools & Compressors Logo
102 people viewed this question
Top Wagner Air Tools & Compressors Experts
Jim Parker
Jim Parker
JOHN LAPIER
ray gallant
Are you a Wagner Air Tool and Compressor Expert? Answer questions, earn points and help others
