Question about Coffee Makers & Espresso Machines
A capsule wth imprintAPO020 - Coffee Makers & Espresso Machines
  • Coffee Maker... Master
  • 15,604 Answers
APO 020 Pill - omeprazole 20 mg - Drugs.com
https://www.drugs.com > Pill Identifier > SearchPill imprint APO 020 has been identified as Omeprazole delayed release 20 mg. Omeprazole is used in the treatment of barrett's esophagus; gerd; erosive esophagitis; duodenal ulcer; gastritis/duodenitis (and more), and belongs to the **** class proton pump inhibitors. **** Class‎: ‎Proton pump inhibitors
Color‎: ‎Pink / Red
Imprint‎: ‎APO 020
Inactive Ingredients‎: ‎magnesium hydroxide
APO020 Google Search
Posted on Apr 23, 2017
Nespresso xn 2003 - water comes through without a capsule but when a capsule is in place the water goes straight into the catch tray?
at the back of the capsule holder there is a metal that correspond
with the sensor sow your problem is the sensor is not finding the capsule holder at the and of the capsule holder do you see the magnit if not replace and try agian
Jul 08, 2014 | Krups Coffee Makers & Espresso Machines
My Nespresso Xn250140 U doesn't work. Why?
Check the hole where you put the capsule, are there any faults or obstructions visible? If not be very suspicious of your capsules, there are lots of brands of Nespresso coffeemakers and the capsules have slight variations between the different brands. The variations are almost invisible but enough to prevent the wrong capsules being used.
Jan 28, 2014 | Krups Nespresso Xn250140 U Coffee Machine,...
Capsule area is leaking
Perhaps capsule holder.
Look Inside on top of this capsule holder for a crack in molded plastic where water come in.
(I have replaced big "O" ring for nothing because the capsule holder is cracked on top).
Jul 04, 2012 | Nespresso Citiz C110
Why do Nespresso capsules squash?
the capsule must plop in at an angle, it it's straight it will crush and not work properly
Apr 18, 2012 | Coffee Makers & Espresso Machines
Can not remove capsule and lever stuck
I had a similar problem, and it was down to high pressure remaining in the machine preventing the lever from releasing. You can test this by pressing the capsule in the machine (which will be much more solid than normal).
To fix, all you need to do is make a hole in the stuck capsule. I did this by drilling a small hole in the side of the capsule.
That releases the pressure (and a little spurt of coffee!), and the lever will release.
Mar 10, 2012 | Krups Dolce Gusto KP 2100 Espresso Machine
Not able to connect the extender to my apple time capsule? no wps button. can i use this extender?
Hi, yes you will be able to use the Netgear range extender with the Apple Time Capsule, provided you configure the Time Capsule's wireless settings based from the wireless security you have setup on the Netgear router or extender. No need for WPS button. Just treat the time capsule just like another wireless laptop.
For instructions in setting up wireless settings of Time Capsule click on this link -->> http://www.apple.com/timecapsule/wireless.html
Hope this helps. Glad to be of service.
Nov 10, 2011 | NetGear WNR2000 Wireless Router
My Nespresso Magimix Citiz does not pierce the capsules every time. I use only Nespresso capsules. I have tried to pass them through a second or third time when this happens but I have thrown too many...
-the short term solution-
1. take your affected capsule. set it on its un-punctured/un-perforated bottom (the thin foil surface) on a flat surface. the three puncture holes should be facing upward on the top of the capsule. by the way, if you shake the capsule you should hear the grounds sound dry as if the capsule was new.
2. find a thin small rubber band. size-wise, ideally, the rubber band will fit loosely around your thumb; with a very small gap between the rubber and your thumb.
3. put the rubber band around the collar of the capsule. the band should be put over the top of the capsule and pushed down until it stops flush against the flange (rim). if the band is correctly placed, the band will be just 1mm flat inside the rolled bare aluminum edge (rim).
4. insert the capsule in your citiz machine as usual. optional: you can orient one of the puncture holes at 12 o'clock position (top dead center) during the insertion process. this time, it will work. you will find the capsule will eject cleanly with the rubber band intact.
5. save the rubber band.
-which machines does this apply to?-
this is a common problem with nespresso machines introduced after 2010, specifically the citiz. i have not seen this problem on the pixie, yet. i would expect this issue on the lattissima plus.
i am assuming that the machine is otherwise functioning properly: meaning that the machine does not have an issue with the water pump, excessive scaling deposits restricting water flow, or some other major mechanical part.
-why is this happening?-
look at the capsule, the post-2010 machines bite new slightly rectangular indentations on the capsule around the top edge of the wall. this is new. nepresso changed the insertion mechanism in response to competitors bringing non-nespresso branded capsules to market: Douwe Egberts/Sara Lee "L'or expressO", Caffe Vergnana "ESPRESSO", etc.
this new insertion mechanism was supposed to thwart knockoff capsules, instead it is unintentionally thwarting your "real" nespresso capsule. the injector needles are not piercing correctly all the way. the injectors poorly lodge: deep enough to make puncture holes but not deep enough to allow water to flow freely into the espresso grounds compartment.
two things can happen:
1. the pressure release valve, inside the brewing chamber which prevents an explosion occurring if the coffee exhaust path becomes blocked, is activated and hot water overflows into your used capsule basket.
2. the hot water flows outside and around the capsule and into your cup as clear hot water.
-what do i do long term?-
contact nepresso. get your machine repaired or replaced. this is a factory manufacturing defect that has nothing to do with you, wear, use, or hard water. refuse to pay the $125 repair fee. demand that they fix the machine free of charge. they will send you a loaner in a plastic shipping crate to use while your is being fixed. you should not have to suffer without espresso or waste legitimately purchased capsules just because nespresso is in a legal fight capsule copycats. this is not your fault.
Mar 02, 2011 | Nespresso C100/T-US-AERO Espresso Machine
With our nespresso machine, when you place the capsule inside & press the button the water runs through the inside of the machine where the plexiglass basket for the empty capsules are
Feb 04, 2011 | Nespresso Citizmilk D120
The capsule lock system does not make holes in the capsule
Oct 09, 2009 | Nespresso Le Cube
I have a new time capsule to back up my mac, and want to set up a new internet service provider
You can use your Time Capule as a starting point but you will still have to use the Internet providers ADSL or Cable modem as a conduit to the internet.
Oct 11, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
