Question about Refrigerators
Fridge is set on the lowest setting and crispers still freezing
    New Friend:
  • 28 Answers
As you have not put a model number, I shall assume it is a side by side fridge freezer..
if you take out the crisper, you should see a special vent that leads directly into the freezer compartment.. that vent aperture is controlled by a separate slide on the front of the crisper, or on the side just above the vent in the body of the fridge freezer.. simply close that aperture down by moving the slider in the right direction.. but if your food is already frozen, it will take a long while to thaw, even with the settings corrected.
Posted on Apr 24, 2017
Hi I have Westinghouse freestyle 450 my problem is that no matter how low I have temp the begs freeze in crisper other wise been very happy I have had this fridge for 20years
fridge settings work in reverse to freezer settings
1 for a fridge is almost freezing where it should be around 4
cold air sits at the bottom of the fridge so the setting will be colder in the crisper draw that at the top shelf
May 26, 2017 | Westinghouse Refrigerators
Fridge cabinet set on medium but any vegetables I crisper section are freezing? Help please!
What is your fridge model number? Some models have independent air flow from freezer to the crisper section and a trick to test
APPLIANCE 911
Nov 29, 2015 | Refrigerators
My Kenmore side by side is fine, except for freezing everything in the crisper drawers.
The coldest place in your fridge is in the crisper drawers, manufactures know this and they even put heaters under the floor of your fridge to try to heat it up a bit in there, if you set your freezer temperture to low there will be less cold air current that flows into your fridge but it will flow in over a longer period of time, that air is about -22C so it will be blowing on your items in your crisper for a long time and it will probably freeze them, all very confusing and complicated but it may help to turn your controles for your freezer to a warmer setting, on the other hand if you only open your fridge a few times a day the cold air being denser will settle in the bottom of the fridge and freeze the crisper area, not much you can do about this, except eat more food... :-)
Aug 26, 2011 | Kenmore Side by Side Refrigerator
Freezer set at 0 fridge set at 37. thngs in fridge and crisper are freezing
this is a big problem that can only be solved by a professional so please get your local repairman on the line and have him come and take a look.
Jun 11, 2010 | Kenmore 73503 Stainless Steel Bottom...
My bottom drawer of my 3 year old Maytag fridge is freezing up all the items I put in it. The fridge is on its lowest setting. What's up?
You mentioned that the fridge is at its lowest settings, try up it a bit so it doesn't freeze up your items.
Feb 04, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
Water not working, ice is. fridge is set at 2.stuff freezing
i have this exact same problem. Started about 3 months ago with the crisper and now the water. when I turn the fridge off after a few hours the water works again. I'm calling the repair person tomorrow
Jan 30, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Food freezes in the fridge part even at the highest
If it is freezing, either you need to turn both temp down to 2nd to lowest setting. Cold air does sink, so that is why crisper gets colder. There is a flap and vent for air between the fridge and freezer. The flap can get stuck in one direction, or the acutator that moves it can become faulty. A leaky door seal will also make the opposite compartment colder.
Oct 11, 2009 | Frigidaire GLRS263ZD Side by Side...
Why are my veggies freezing even thought the temp is set to 40?
Most fridges have crisper drawers that have a selection lever on either the front or side of the drawer that allows you to select eiher veggies or meat. Veggie setting is supposed to keep the crisper drawer warmer, while Meat setting makes it the coldest possible.
If you don't have the selector slide levers, I would suggest you use the highest possible crisper drawer available, as the lower in the frdge compartment you go, the colder the air will be. That should resolve the problem you're having, other than lowering the fridge temp setting slightly.
You might notice a cold air exchange vent next to your crisper, which supplies cold air from the freezer section into the fridge section, so that could be contributing to the colder temps in the crisper where you keep your veggies.
Hope you find this Very Helpful and best regards!
Aug 20, 2009 | Jenn-Air JBL2088H 20 Cu. Ft. Cabinet-Depth...
Kenmore elite fridge crisper drawer freezing stuff
If you have a side by side model you need to look at the refrigerator compartment wall on the left of the bottom drawer and move the slide control to the warmer/fruit/vegitable setting instead of the meat setting.
I hope this helped. Please rate my help or ask for more help please. supertechks
Apr 05, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Crisper door/water line freeze problem
mar...you're box is set too cold. Use -17 C/38 F on the freezer side which is about 38F/4C on the fridge side. Use an outdoor thermometer and let it sit closed for at least a few hours. Adjust accordingly and this will work out. One adjustment is often the cold vents from the freezer into the fridge. If set too wide, too much cold air gets into the crisper and water lines.
Feb 01, 2008 | Maytag MFD2560HES Bottom Freezer French...
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
