Question about The Audio Players & Recorders
When i try to play a Cd it shows door why it will not let the cd pay how do I fix this
  • 50 Answers
SOURCE: CD PLayer won't play CD's
Hi First of all, you must find all the screws for the top cover and remove it. Make sure the unit is not plugged in! Then, making sure that you are not touching anything inside the unit, plug it back in,put a Cd in the drawer, and watch what happens. If the drawer closes, but you can still hear a motor running, then it is a belt drive unit, and the belt is slipping, if that part is ok, listen carefully for a ticking noise, which is the laser lense going up and down trying to focus on the CD, if the disk starts to spin then the mech has closed properly, and the unit is trying to find the directory. If the unit then spins the disk for a while then ejects it, then the laser is dirty or faulty. I would suggest getting it cleaned at a shop if the lense appears dirty. ***Never look straight down at the laser lense if it is exposed on your model of CD player, it is a class 3 laser, and you will be doing some harmful home laser surgery to yourself!!!*** Hope this helps! Good Luck! P.S. When following the steps above, if you hear the ticking of the lense moving up and down, but the disk does not spin, gently spin it clockwise with your finger, if it starts to play, or finds the directory, then the spin motor is bad.
Posted on Aug 16, 2006
SOURCE: Not Recognising a CD
I got a second hand 541 a few weeks ago. After many hours of listening pleasure an no problems at all, the machine stopped spinning CD's, both copied ones and original ones.
The sollution for my problem was simple after some figuring out.
Open the CD tray.
Power off the unit with the tray open.
Open it up.
In the CD frame in the back there are 2 srews that hold the CD engine unit in place. I untidied these screws just a little bit.
I also untidied the screws that hold the cd clamp cover on the top a little.
After this it loads all my CD's fine again.
Posted on Feb 28, 2008
SOURCE: Sony CDP-CX300 CD won't play
The rubber drive belt for the c/d load mech is streched or broken,
replace the belts there is another that drives something else so change them both while you have it open
Posted on Mar 30, 2009
SOURCE: 6 cd changer
try to reset the cars computer. i had the same problem and it fixed it. all you need to do is unplug the battery for about 10 minutes and it may work. Good luck!
Posted on Jun 15, 2009
SOURCE: CD player Error 3
I have different experiance with the C.Dplayer ( error 3 ) , there is no need to remove it nor send it to the dealer ,all you have to do when you have `` Error 3 `` is to reset the C.D player , by recycling the power supply ,this can be done by disconnecting the main car battery power supply , you must also keep the battery disconnected for at least one hour . then connect the cables to the batteries ,when you start the C.D player you will hear some clicking sound ,and watch the numbers of the C.D`s in the display you will find all what is inside has been detected by the display .
and your C.D player is back to normal..
i discovered ths by chance , when I had this error in the past ,coincidently I had to replace the battery and after installing the new batteries ,i was suprised to see the player back to normal condition by its self.
Posted on Jun 19, 2009
My Sony CD Player Won't Play
before yo junk it try this procedure.
1. try to used cd lens cleaner.
2. if no helped try to manually clean the lens,
3. open the cover.
4. power on the unit.
5. push eject button.
6. after eject then power it off.
7. you can now access the lens, try to clean the lens using cotton buds and small amount of alcohol then wipe it out or you can used microfiber cloth.
Hope it helps please rate my answer.
Nov 07, 2012 | Audio Players & Recorders
CD player shows "CD Err" when trying to play a CD
Try a CD cleaning kit and follow instructions, if no change! the laser pickup assembly will need to be replaced, not cost effective to repair, cheaper to replace.
Apr 23, 2012 | Audio Players & Recorders
Trying to play a cd on the TEAC GF-680 . Blinking message
  • You may have some dust blocking an optical sensor that detects the door being closed. Try to blow into the door area with the tray open, either with your breath or with compressed air.
  • You can also try unplugging the player for 1 minute and plugging it back in to see if that fixes it.
  • Try a different CD. The DVD player may not like the CD you are trying to play or the CD might be dirty.
  • The DVD player might just be broken.
Feb 11, 2012 | Audio Players & Recorders
Dvd/cd door won't stay shut
Nobody fixes these devices. Instead, spend $35 to purchase a replacement CD/DVD reader/writer, and install it -- cheaper than paying a technician to try to repair it.
Jul 19, 2011 | HP Computers & Internet
I have a Sharper Image Blue Night CD Player with a motorized CD cover that automatically slides up or down (to play CD) at the touch of a button. When I push the button to close the door (and play CD),...
I would first check to see if there is something that is obstructing the door, and if you cannot find anything, then you could take it to any electrical repair shop, and they could fix it for you.
Mar 26, 2011 | Audio Players & Recorders
Cd player doesn't play or ejects shows like there's cds inside but nothing comes out when the eject button is displays"player error".what could be the problem?
The CD is probably not in the carousel the way it should be and cannot play and also has the door jammed so it can't eject. Sometimes this can be fixed by taking a thin object like a credit card and sliding in between the top of the door and the case. If you can move the CD just a little, you may be able to get it to eject.
Jan 28, 2011 | 2002 Buick Rendezvous
CD keeps ejecting without playing.
try reformatting the cd or try a cleaning cd, the more you pay the better the cleaning cd
Nov 06, 2009 | Pioneer FH-P4400 CD / Cassette Player
My sharp cd player is showing error 11. door will
dismantle your cd player and set it up back and it will automatically reset itself. if does not then have a tech repair it as your aduio output is damage or the momory chip needs to be replaced.
Apr 18, 2009 | Sharp Audio Players & Recorders
Error code 6 & error code 4
hi try first to insert a clean up CD, and test your Cd player with an original CD, if the problem persist , your laser sense is defficient you have to go to fix it to a specialist.
hope this helps you
May 21, 2008 | Clarion DXZ438R CD Player
24 people viewed this question
Top The Audio Players & Recorders Experts
Jose Ma DM.
Jose Ma DM.
Level 1 Expert
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
