Question about Tablets & eReaders
Why is my tablet saying it's charging but it's still draining the battery while charging
  • Tablets & eR... Master
  • 19,004 Answers
If it is doing that, you need a new one or it needs repairing. Put it onto charge and then power it down. Batteries do start to fail after 3 or 4 years and are reasonably cheap to replace.
tablet battery - Google Search
Posted on Apr 24, 2017
Fire tablet won't charge
I called Amazon and went through a 15 min troubleshooting session with support. Since mine was only 10 months old they sent a replacement. When it happened to the replacement it was 3 years old so I had to buy a new Fire - they forums say it's the charging portal.
May 05, 2017 | Tablets & eReaders
Why does my nook turn off at as soon as its turned on and it drains my battery when its off
The battery drains while the item is off, on laptops, tablets, and flashlights. ANYTHING with a battery will do this.
Your device is low on power. Charge it for a day and it should be workable.
The longer you let it go without a charge, the worse your battery will be. (You cannot overcharge it.) Some have to get a new device because they let it go a few weeks without a charge.
You should charge it every week.
Nov 24, 2015 | Barnes & Noble Nook Tablet
Battery will charge to 100% only 50%
Morning Emily,
A couple of questions, then a couple of ideas.
  1. Are you using the charger that came with the tablet or are you using a universal charger?
  2. Do you leave the tablet on the charger a lot of the time or do you only charge it when it gets very low on charge?
Often devices like these need to be drained periodically so that your battery does not develop a shallow cycle. Shallow cycle can often occur whenever a device is charged often before it actually gets down to a low percentage of this battery capacity. If you have been typically keeping it charged without letting it drain I would suggest leaving it on and letting it drain fully and then try to recharge again.
If you have not been doing constant charges as described above, then it sounds to me like either you have a bad charger or there something wrong with the battery in your device. I'm going to provide a link to a Page on the next book site so that you can see some of the information related to your device.
I think the biggest questions to be asked are, a) is the charger that you're using putting out sufficient power to charge the battery properly, or b) is the battery in your unit defective. These questions can probably be best answered through the store which you purchased it, such as a Best Buy or wherever it is that you got it. They should be able to analyze the output of the charger to see if it's correct. If it is correct and again if you've not been doing the shallow cycling then that would indicate a problem with the battery.
I'm including some links below that might be helpful for you. The first one is to a knowledgebase article dealing with battery and battery life. The subsequent links are for the manual and also for the technical specifications for your device. The tech specs will probably help as far as your battery and also what should be the output of your charger.
Knowledge Base:
http://support.nextbookusa.com/support/index.php?/Knowledgebase/Article/View/71/23/battery
Links:
Manual http://www.nextbookusa.com/pdfs/NEXT8P_Manual.pdf
Spec Sheet http://www.nextbookusa.com/pdfs/NEXT8P_Spec_Sheet.pdf
I hope this helps.
Dec 27, 2014 | Nextbook Premium 8 Se Android
How can I charge my my archos 70 cobalt tablet it says not charging and will not charge
The correct procedure to charge the battery is to plug in the device in when it is powered off, and then do *nothing* - just let it do it's thing: It will power on by itself and then eventually go into sleep mode and keeps charging. Just let it be.
You may wish to switch off wifi while charging as it is the second biggest drain on the battery (the screen is the biggest!), and having wifi on may suck some of the power away from the battery charge and into the wifi hardware also try getting a charger just like original, sometimes during transport from warehouse to store where u purchased your tablet things get knocked around and or damaged, but the store is not aware until u bring it to their attention
Aug 17, 2014 | Tablets & eReaders
Kaser Android tablet will not turn on or charge its brand new
Did you drain the battery completely and try to recharge it? A lot of people have problems if they drain the battery and recharge. I went through 3 A300 tablets before I figured out I had to recharge the tablet BEFORE it went dead or it would never start again. I don't know why but many brands have this problem. Also, do not shut it completely off when it is on the charger. Always take it off charge, or turn off before charging. I had another prestige that had to be replaced because I turned it off or on while charging. I have not found out why this happens to many tablets! Good luck!
Feb 26, 2013 | Tablets & eReaders
Fujitsu siemens stylistic M532 tablet not charging battery
I have just had same problem. Battery on M532 absolutely refused to charge from flat.Tablet worked when plugged in so I downloaded an app killer from android market and killed all but the essential apps then tried again and it seemed top work! Maybe background apps draining battery at faster rate than could be charged?
Nov 08, 2012 | Tablets & eReaders
ASUS Tablet TF101 Wont Charge
batteries do not last forever get it replaced by a computer shop
Jan 05, 2018 | ASUS Eee Pad Transformer TF101A1 Tablet...
Tablets & eReaders Logo
55 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
