Tools & Hardware - Others Logo
The Peti-Buffer works really well for my two dogs. I can not find the refill sanding discs. Where can I order them.
Wood sanding discs for electrolux
You would take 2 passes at this, first with a coarse or nedium grade, then fine. You ought to be able to buy the discs at a large hardware store like Home Depot, and get advice there too. Wear a dust mask too.
How often does sand need to be changed? Cloudy water a symptom?
about every three years take multiport off shop vac sand out check the laterals for damage then refill with sand check label on tank for amount when refilling dont get sand in vertical pipe
How can I calculate how many calories my dog needs to eat per day?
In order tocalculate your dog's daily calorie needs, go to this website and enter theinformation in the calculator: http://www.dogfoodadvisor.com/dog-feeding-tips/dog-food-calculator/.It will then tell you exactly how many calories your dog needs to eat per day. Thiscalculator really helped me with adjusting my dog's diet.
Jul 18, 2012 • Dogs
2answers
Sander disc no longer "sticks"
Most commercially made disc sanders have replacements pads whether they are hook and loop type or the rubber. If you go to the manufactures web sit and look up your sander, it will usually be listed somewhere. But you might have to call an authorized repair center to find the part number to order.
Jun 07, 2011 • Vacuums
1helpful
Can the 1999 durango headlight lens be polished on a buffer?
if the lenses are getting cloudy, they can be restored. Easiest way is to start by wet sanding the lenses with a fine grit sand paper, about 200 grit, then working progressively finer in about 3 stages. After sanding, if you want them even clearer a high speed buffer with cutting compound then polishing compound works well.
1helpful
Clarke FM1700 buffer-sander, problems with using it
what is the condition of the felt pad on the driver?? The sander should not be that hard, usually you need to lift up or slightly bear down to get the machine to move left or right. Are there any exposed nails in the area you are sanding and check the grit for the sanding conditions
Instructions on placement of the lateral assmebly w/center pegs
That placement is automatic based on the center pipe resting on the bottom of the filter tank and the valve being fully seated into the opening on top of the filter and clamped into possition. You likely have damaged laterals and need to replace that assembly in order to fix the sand issue. When refilling the tank with sand, be sure to fill it nearly half way with water before adding the sand.
Jul 15, 2009 • Plumbing
I have the porter cable 7424 buffer/polisher. My problem is when you apply any pressure, even the weight of only the buffer on the car it stops spinning. You have to hold it up slightly lifting the we
The armiture has a winding problem, common in a lot of power tools. Replacing the armiture is not cost affective unless your time put into it is worth it, sorry. I recomend the Dewalt veriable speed, nice professional buffer!
1helpful
2answers
Bosch 3107DVAS Random Orbital Sander not working.
You must replace the fan assembly. The part number is
2606610901
Hope this helps
1helpful
2answers
TEAC DW 552g DVD/CD rom combo drive, CD works, DVDs dont
I have your solution, but you are NOT gonna like it, so I hope you will rate it FAIRLY, even though its relatively BAD NEWS.
TAKE A LOOK AT THIS:
Teac (DW552G/KIT/USB2) CD-RW/DVD-ROM (Combo) Burner The Teac (DW552G/KIT/USB2) CD-RW/DVD-ROM (Combo) Burner deliver unbeatable CD speeds of 52X write to CD-R, 32X re-write to CD-RW media and 52X read as well as 16X DVD playback speeds and the drive features an advanced buffer underrun prevention technology. This disc-saving feature suspends the recording process until the buffer is refilled. No more bad discs even when you’re multitasking. It also supports EasyWrite (Mount Rainier), a new disc formatting feature that makes it easier and saves time preparing CD-RW discs for recording. Teac W552G (cdw552g/kit/b) CD-RW Burner Newbie The Teac W552G (cdw552g/kit/b) CD-RW Burner operates with: Microsoft Windows XP, Microsoft Windows...
YOUR DRIVE DOES NOT BURN DVDs, only CDS!!!
Top Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
