Stackable washer does everything but spin makes noise as if draining but doesn't spin Can't find model number
huuum
  • 750 Answers
SOURCE: frigidaire washer model FWX833AS1 top load
Hello Lcl2610.
welcome to Fixya,
My name is Huuum,
How old is your machine?
I have found some reasons of what may be the matter!
List of thinks to check
1.Defective Lid Switch
Check lid switch for proper operation. Check the switch for continuity. If it is found to be open, replace the switch assembly.
2.Faulty Direct Drive Coupling
The Direct Drive (motor) Coupling may be broken. Many Whirlpool/Kenmore brands washing machines utilize a small, relatively inexpensive direct drive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other.
It can wear out over time or fail under overloading conditions. This protects your transmission from excessive loading.
3. Faulty Water Level Switch
If the water level switch is not resetting once the water is drain, power will not be available to operate the motor during spin. Check the water level switch for proper operation.
4.Will not drain and displays F/02
The error code F/02 will be displayed if the drain time exceeds 8 minutes. Press pause/cancel twice to remove display. Check the pump filter and wiring connections on the pump. If all looks good, replace the pump.
You may want to use a pro, rather than attempt this project your self.
Let me know how it goes!
Thank you Huuum.
Please remember to leave a rating
Posted on Oct 21, 2008
mark_37388
  • 100 Answers
SOURCE: Washer won't spin, but making funny noise and water drains
You have a broke motor coupling broken between the motor and transmission the part is not expencive but a little hard to explain how to put it in.
Posted on Mar 29, 2009
dblred
  • 68 Answers
SOURCE: kenmore stackable mod number 417.94802301
check your lid switch. if your lid swith is bad, it will fill and agitate, but will not pump or spin. therefore it will not go into rinse cycle without being able to pump out water. some lid swithes control the agitation also (usually frigidaire and older maytags), but i doubt yours does. you can check the lid switch for continuity while opening and closing the lid with a meter
Posted on Apr 30, 2009
  • 351 Answers
SOURCE: washer doesn't spin, just makes funny noise.
i would change the coupler between the motor and transmission.... whirlpoolpartssurplus.com
Posted on Jun 23, 2009
SOURCE: Frigidaire stackable washer-dryer
I would check the manual.
Posted on Mar 14, 2010
How can I get my stackable washer to spin?
Hi friend, I appreciate your post!
I see that your Frigidaire washer is not spinning. I would check to make sure that the drain hose is not restricted or too long, because that could cause your appliance to not spin. It could additionally be a possible issue with the drain pump or timer inside your appliance. I would set your appliance to spin and if you hear a humming noise the best step would be to contact a professional to come out to your appliance and diagnose it properly. Hopefully this is helpful. -Matt
Aug 31, 2014 | Frigidaire Washing Machines
Frigidaire washer won't drain or spin
Hello - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. Supposing that it does not, I would suggest contacting a professional to move forward accurately. The unit could possibly have a faulty pump, timer, or door lid (if it is a laundry center).
Oct 11, 2012 | Frigidaire Washing Machines
My Thin Twin stackable washer & dryer Model # LTE5243DQ3 is having problems w/the washer spin cycle. I'm thinking I may just need a new timer because it goes through all the cycles except the spin...
Before wasting money on a timer that wont be returnable once it is removed from the packaging please respond to me and tell me does the washer do everything including draining, and the only thing it will do not do is spin
or will it wash but not drain and spin
their are 2 posibilities based on your response and neither is the timer
Thanks,
Gene
so ya know i have beena appliance repair technician for over 30 years
Jul 23, 2011 | Whirlpool LTE5243D Top Load Stacked...
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
Stackable Washer/Dryer model number FLSE72GCSB wont drain and also not sure if it is even spinning at the right speed.
you need a new drain pump the price on that is about $90.00 part number is ps2342446 asmy-pump (pump water) get that on their and you should be good to go .GOOD LUCK!!!
Oct 12, 2009 | Frigidaire Washing Machines
The stackable washer will not agitate
Give me a model number. Fridgedare and White westinghouse made some of these stacks for Kenmore. I'll need to know the manufacture. Reply with the whole model number and I'll help.
Aug 27, 2009 | Kenmore 98702 Stacked Washer/Dryer
Washer will not drain on spin cycle, water stays in machine
you might have a broken pump belt go to www.repairclinic.com enter model number and scroll down to the red 100 click it and start looking for the pump part number 1480330. You'll have to lean this thing back far enough to see if it is your belt or maybe even go through the back of it.
Mar 22, 2009 | Maytag LSE7806A Top Load Stacked...
Washer won't drain or spin
sounds as if you have a lid lick/door switch issue, the machine is not recognizing the door being closed and for safety reasons will not enter spin/drain.. open anc\d close lid a few times slowly, cam you hear a "clicking noise" whe njust about closed?? id assume not replace teh lidswitch
Jan 21, 2009 | Kenmore 88732 Top Load Stacked Washer /...
Washing Machines Logo
Top Washing Machines Experts
