Question about Mercury Boating
Hello, My mercury 9.9 outboard motor has a milky tan discharge coming out it's exhaust. It seems to run fine just troubling to see. What do you think it is?
    Passionate:
    Visited the website for 10 consecutive days.
  • 83 Answers
Sounds like one of the seals is bad. What I would do is to first remove your lower unit oil screw and see what color the fluid is, if it is milky then it is a seal/s are bad and you will need to rebuild your bottom end. If the fluid is normal in color, your going to want to get a compression tester and start testing all the cylinders to see if you have an issue internally in your motor. Not trying to scare you but those would be the only reasons.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_677dced97ad9bddf
Posted on Apr 24, 2017
Water got into the engine oil of my 8 hp 4 stroke when on the boat only as troller
Water gets in your engine through the exhaust with the boat speed! Lift that engine when not in use!
Oct 16, 2014 | Mercury Marine 8hp & 9.9hp 4 Stroke...
I have a 60hp Johnson outboard motor, what will cause it to leak oil&fuel from around the propeller
With out knowing the year, It could be running rich and a little discharge could be considered normal as that is where the exhaust comes out.Or your float could be stuck if it is not running right
Aug 14, 2014 | Boating
Where does the water discharge at on a 2000 mercury 25hp 2 stroke outboard motor?
Modern engines have a small "tattletale" discharging water out the back or side to let you know the water pump is working. The majority of the water exits thru the exhaust system to keep it cool and finally out the propeller hub when under way. There may be a small discharge out "idle ports" on the back of the motor.These relieve exhaust gas pressure when at slow speeds or not moving.
Jul 16, 2014 | Boating
Hi i am looking for a repair manual, online, free would be best,for a 7.5 hp mercury outboard motor - no idea what year but must be early 90's at best. It won't start, fuel drips from under the head and...
Mel's Marine Service Inc. stocks those repair manuals and will ship them. I believe they run about $50.00. There phone number is 541-689-0136. They are open from 8-5 pacific time mon-fri and 9-2 on saturday.
Oct 08, 2009 | Light Outboard Motor Boat Bass Fishing...
Water cooling of exhaust
If its a newer model Mercury the Relief exhaust port does not receive water at an idle, all the cooling water is discharged through the Propeller hub exhaust and Tattletale.
Sep 20, 2009 | Boating
Where is pee hole on 1980 Mercury 4 HP 2cyl 2 stroke
Hey I just got the same motor and actually have the same exact concerns. Have you found any answers?
Aug 30, 2009 | Boating
Merc outboard 115HP 1996 fuel primer/Choke
Hello there
here is a good place to start ok Outboard (wiring A Tachometer To An Outboard, Mercury Outboard Float) safe.gif
merc outboard motors mercury outboard ... diagram of mariner outboard motors johnson outboard fuel problems ... johnson outboard motors ebay 1996 115 hp mariner outboard
  • tipsterdatabase.com/mods.php?id=outboard
  • · Cached page
Aug 27, 2009 | Boating
Mercury outboard over charging
Your motor is fine. It needs to put out more than 12 volts or the battery will not charge. Most alternators put out between 13 - 17 volts, so this is well within the range.
May 09, 2009 | Light Outboard Motor Boat Bass Fishing...
Boating Logo
Top Mercury Boating Experts
Colin Stickland
Colin Stickland
Mike
Steve
Steve
Are you a Mercury Boating Expert? Answer questions, earn points and help others
