Question about Refrigerators
The copper tubing in the handle shaft cracked. Is this a repair or replace?
    Top Expert:
  • Refrigerators Master
  • 45,120 Answers
Probably replace
Posted on Apr 24, 2017
4 Suggested Answers
john224
  • 1378 Answers
SOURCE: gash and pinhole leaksin copper tubing in pool heater
None that last very long. A new exchanger and keeping the chemicals in check moving forward is your best bet.
Of course you can try to have a radiator shop fix it but I have had mixed success with those and it seems to depend on how much of the remaining copper is thin and/or damaged but not leaking yet.
If you would like a quote on a new exchanger, contact us at www.arrowpools.net with you model number.
Posted on Jul 05, 2009
SOURCE: pin hole in 1/4" copper tubing feeding refrigerator
i have a lil hole in the lower panel seperating the fridge frm the freezer, what do i use to fill it up nd stop the gas leaking out
Posted on Aug 19, 2009
  • 5 Answers
SOURCE: How do I replace a single handle Delta mixer??
You would have to open up your drywall, cut and re-solder a new single handle faucet. An easier approach could be to shutting off your water supply, draining the lines in your bathroom from someplace below, and then trying to fix the bad soldered joint if you know how to do so.
I hope this helped.
Posted on May 25, 2010
How to install drive shaft on a husqvarna 322l weed eater 1999 model
The curved shaft machine has a flexible drive shaft like a speedo cable, slacken the two tube pinch bolts, these are accessed on the r/h side of the grey plastic handle through holes in the plastic housing,, remove the two mushroom headed screws either side of the plastic handle,don't lose the black o rings under the screw heads, do not remove any of the plastic housing screws, now carefully draw the tube out through the plastic handle/trigger assembly, once out pull out the old drive shaft, grease the new drive shaft and push back into the tube, once fully in turn the end to make sure the trimmer head turns, now feed the tube back through the trigger housing, make sure it is fully back home and the square end of the new shaft has entered the square hole in the drive drum, re tighten the pinch bolts, start the engine, if the head does not turn, slacken the pinch bolts and push the tube further in, re fit the two mushroom headed screws.
Jun 28, 2018 | Husqvarna Garden
Copper peice leaking in back of refrigerator that comes to ice maker line
Replace copper line or with a set of torches and solder you can weld crack. But copper can be replaced with cheap plastic tubing
Oct 30, 2016 | Refrigerators
I have a RUUD A/C model UBHC-17J11SFF. The consensation pan has a crack. Can the pan be repair/removed without cutting the copper tubing?
not really you have to remove coil to replace pan. if there is room you can abandon that pan and put another under it.
May 12, 2013 | Ruud UBHC Air Conditioner
STA-RITE 5P2R-125G with 0.75 HP motor. Had bearings in motor replaced and was advised that shaft seal is also replaced. Now have a leak from the motor side of the seal plate at the bottom. They replaced...
the absence of the copper cone will not cause a leak, however, there is a different shaft seal that needs to be used in lieu not having the copper cone installed.
If the impeller is damaged or cracked, that can cause a leak at the shaft seal. If you replace the impeller, the shaft seal will most likely need to be replaced as well.
Feb 23, 2012 | Hayward 1 Hp 2 Speed Super Pump Inground...
Replace clutch and shaft on model no 325L brush cutter
There are two versions of this, on the early system the shaft threads into the drum, on the later machine the shaft has a square and just pushes into the drum, to acess the drum on both systems, you need to remove the top cover, diss connect the throttle cable from the carb, un hook the coil wires from the top of the end cover, take out the two mushroom headed screws in the grey throttle handle with a 4mm allen key,do not lost the o rings underneath, slacken the two 4mm headed allen screws from the tube clamp, you can acess these through the pre cut holes in the throttle handle,now twist and pull the tube out of the clamp and through the throttle handle, if the shaft is squared it will also pull away, take out the three 4mm allen screws securing the tube clamping cover and pull away, if the shaft was squared and pulled out, then the drum is held into the bearing with an external circlip, if the shaft is threaded onto the drum then you need to clamp the shaft in a vice with soft jaws and turn the drum to undo it right hand thread.
Good Luck
Jun 02, 2011 | Husqvarna Garden
I just got a used deep freeze.. but i was told something was wrong with the copper tubing.. it needs to be replaced.. what does this copper tube do? and relatively how much could it cost?
if the copper tube needs to be replaced then that means it is now worth fixing. the copper tube is what the refrigerant runs through. no copper tube - no refrigeration. Also you would have to fully destroy the fridge to get to the tube anyway. You may as well get rid of it. sorry
koolman77 (refrigeration technician)
Feb 07, 2011 | Refrigerators
I have an old Simac Il Gelataio Super. I believe the clutch is broken. It will only churn until the product is very soft. Then the blade stps because the drag on the sides is too great. Is this...
It sounds like the main gear is cracked were the paddle shaft goes though it.the d shaped shaft is spinning when the ice cream gets firm. i repaired mine by making a sleeve out of copper pipe and slid it over the cracked part. works great.
Dec 11, 2010 | Simac 4050 Il Gelatao Magnum 1 Quart Ice...
2003 focus 2.0L 14 spi EGR tube broken at exhaust manifold second time. anyone know what could cause it to do so?
Hello! This is a nagging problem...The tube is made out of copper and breaks due to flexing. It is to weak to handle normal stress...Replace and have it welded...Guru....Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Oct 18, 2010 | 2003 Ford Focus
I have a pyrotenex heating cable in my pipe at the cottage. the copper covering on the cable is cracked where it is attached to the fitting into the intake pipe. can it be repaired? i've been told that it...
no the coating cannot be repaired, because the coating is heat resistant and anything u put on will not adhere or be heat resistant enough, a silicon auto sealant may last for while but not likely to last long, u cannot solder as to high a heat will ruin core, had a though there is a cold copper solder solvent for fusing copper pipes if u wrapped with this copper tubing and cold soldered it might work it works on hot water copper pipes. If u try this and it works please keep me posted on this my email is adirondacktrail@hotmail.com
Jul 08, 2009 | Easy Heat Water Pipe Heating Cable
Ice maker connection keeps cracking and flooding my house
sometimes ice makers get iced up inside the fill mechanism and causes this to happen. Have you tried defrosting the freezer? This may take care of your problem.
Mar 13, 2017 | Frigidaire FRS6R5EMB Side by Side...
Refrigerators Logo
1,199 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
