How do you jump your west point infrared heater to see if the on off switch at back I'd bad
  • Heating & Co... Master
  • 1,925 Answers
I agree with John, but, a switch is a simple "break" in power. When off the circuit is open, when on the circuit is closed, therefore completing the circuit. To bypass a switch bring the top and bottom together. Good Luck!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Posted on Apr 24, 2017
    Top Expert:
  • 15,387 Answers
Dangerous to jump switches --invest in a multi meter and test switch and wiring
Posted on Apr 23, 2017
Comfort zone infrared heater runs for a few minutes a then completely shuts off
if unit runs ok for 3 to five minutes then completely shuts all power lamps off , then its hi temp limit sensor (safety) has been tripped , this usually goes out due to failure of main temp control , in point of fact contacts in temp switch literally weld them self's together and cant separate to allow heater to control temp
Oct 15, 2016 | Comfort Zone CZ1500WC Infra-Red...
West point infrared heater makes a loud buzzing sound when truned on
What does this have to do with PC laptops ??? Please post in correct category.
Dec 18, 2013 | Computers & Internet
My Cz2011 Comfort Zone Infrared heater will not stay on. It will stay on for maybe one minute and then it shuts off
I had same problem with mine and found out that the timer was turned on make sure your timer time is set to 00 hope this helps
Jan 01, 2013 | Comfort Zone Infrared Quartz Heater
Westpointe infrared heater shut off
The tilt switches normally go bad in these. It's a square black switch with a round bulb looking unit on top, wired near the power switch. The lower wiring pin will be drooped down as the case melts- test by temporarily jumpering between the two posts. If the heater works with a jumper, the switch is bad. A replacement switch is available for $13 at: (888) 775-1330 AZ patio heaters or http://azpatioheaters.com/product.php?productid=32&cat=3&bestseller=Y#images part no. THP-ATM
Feb 04, 2012 | Heating & Cooling
Oh well basically the gae heater switches off the minute you stop pressing the ignition switch.
then the the pilot might be too small ie blocked needs cleaning or you need a new thermocouple
Aug 18, 2010 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Came back from out west.parked up for 5mintes,just tried to start my car,it just makes a click sound and thats it.
If you didn't try jumping it....low battery.
If you did jump and were able to drive and then tried starting it and the lights dimmed...bad alternator.
If you tried jumping it and it still clicked only...bad starter solenoid (just change the whole starter assembly).
Jan 12, 2010 | 1997 Mitsubishi Galant
Pilot light is on but heater wont come on
Make sure that the knob on the gas valve is pointing to "ON". Take the two wires going to the thermostat and jump them together. If the unit starts you have a bad thermostat. If it does not, jump the terminals that the thermostat is connected to. If the unit starts you have a bad thermostat wire. If not, you either have a bad gas valve or a bad thermopile.
Jan 03, 2010 | Williams Heating & Cooling
West Bend 33600 doesn't heat - how do I test thermal fuse?
Yes, if you have no continuity across a thermal cut-off, that means it is blown.
Feb 22, 2009 | West Bend 33600 Coffee Maker
Rinnai natural gas log fire heater
12 is a fault code, look in the book if you have if, i think 12 is no or low gas pressure, cheers
Oct 06, 2008 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
