Question about Pool & Spa
What is the value of capacitor used in MQ booster pump
3 Suggested Answers
aquaman987
  • 927 Answers
SOURCE: Hi, I have a Grunfos
First check with a pressure gauge to see that the pressure is, indeed, dropping. Then, if it is possible, turn off the outlet valve to isolate the pump.
If pressure is still dropping, there is probably a check valve on the inlet of the pump that prevents water from the high pressure side from leaking back to the inlet piping side.
To test this, let the pump run and pressurize the house and immediately close the valve for the incoming water. If the pressure holds, then open the inlet valve and see if the pressure drops. If it drops, the inlet check valve has to be replaced (or cleaned).
Gary
Posted on Feb 19, 2011
  • 3 Answers
SOURCE: i have a problem with mq booster pump
Grundfos said the problem of on off every few seconds was air in the line. Then
later admitted it was the control unit. After replacing two units in 2 yrs I replaced
it with a standerd pump pressure switch.....Runs fine
Posted on Jan 14, 2012
Grundfos MQ 35
Check the capacitor or the centrifugal switch.
Aug 26, 2013 | Grundfos MQ3-35 3/4 HP Pressure Booster...
I have a problem with mq booster pump every 10 seconds kicks back and kicks on i am check the showers no leaks everything is ok please tell what can be a problem
Nov 17, 2011 | Grundfos MQ3-35 3/4 HP Pressure Booster...
Problem with mq pump
MAKE SURE THE PUMP IS WIRED FOR 120/220. THE WIRE GAUGE
SHOULD BE #12 OR #10 IF 100 FEET.
My mq 35 pump, has started to splutter and the pressure goes completely, occasionally coming back on its own and other times i have to reset the alarm... the pump is three years old and this has been...
Sounds like it may be air in the system - there is a black plastic bleeder screw on the top of the pump - open it and let air escape, if any, then fill with water, close screw and start pump.
Oct 16, 2010 | Grundfos MQ3-45 1 HP Pressure Booster...
My grundfos MQ 3's motor sounds like it is locked up. When i plug it in everything seems to work except the motor just humms until the alarm shuts it off. There is nothing blocking the impeller. What would...
Either the motor has gone bad and will not start or the capacitor is bad and is not helping the motor to start...an experience repair person can tell tou what is happening...
heatman101
Jul 12, 2010 | Grundfos MQ3-45 1 HP Pressure Booster...
With the water running the MQ pump runs intermittently
This is a problem with your bladder in the pressure tank or the pressure switch. Ether one will produce this cycling on and off. Good luck.
Mar 09, 2010 | Grundfos MQ3-35 3/4 HP Pressure Booster...
Pool & Spa Logo
26 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
