Question about Car Audio & Video
Having trouble under standing rms with speakers. Some speakers rms is per speaker and other are for both speakers.I am looking for soundstream speakers that would be 150 rms per speaker. Thanks
  • 412 Answers
Rms is a method of measuring power (wattage) delivered from an amp to a speaker. In almost every case, wattage capacity of speakers is quoted PER SPEAKER. Likewise wattage output is quoted per amp output channel. Assuming a you plan on a single speaker on each output channel of your amp, you should be in good shape if your speaker wattage capacity equals or exceeds your amp's output rating. I've never seen speakers rated as wattage per pair.
(rms is the dominant way of measuring average watts of an ac sine wave signal)
Posted on Apr 23, 2017
Hi,I have two 250w speakers at 8ohms ,could someone tell me if I need to get a amp with higher watts than the speakers?k
Speakers are rated either at RMS (root mean square) average power or Peak Power. An RMS of about 125 watt is equivalent to 250 watt peak. To match the radio and speakers they both need to be consistent. Also do not be confused with total radio power out vs per channel.
So if the speakers are 250 watt peak power then a radio with 125 watt per channel or 250 watt peak per channel would be a good match.
If the speakers are RMS 250 watt then the radio would be 250 RMS/channel and usually with a four channel radio a total of 1000W RMS
With that much power the neighbors should hear you coming!
Dec 02, 2015 | Car Audio & Video
What is the speaker load impedence of the speakers
Looks like you can use minimum 2 ohms, max 16 ohms
LFC Impedance Sensing
CS Series amplifiers feature innovative circuitry for safe operation into any load. When an amplifier senses a load that
overstresses the output stage, the Load Fault Correction circuit adjusts the channel gain to a safe level. Extreme load
fault under high power levels will cause the signal to be muted for the associated channel. This method of outputstage
protection is far more effective than the standard limiting found on conventional power amplifiers. The LFC
circuit is sonically transparent in normal use and unobtrusive when activated.
Jun 20, 2014 | Peavey CS 1400 Amplifier
I have had this exact Receiver and this is taken right from the specs. in the manual, "120 watts per channel RMS" at 8 ohms - this is in Stereo mode (2 speakers) only". When surround sound is used, "75 watts RMS for Front and Center speakers and 15 watts RMS for rear (surround) speakers. From experience, the Stereo only mode is definitely stronger/louder than when switching to Surround. Most newer receivers are the same wattage regardless of mode.
Feb 19, 2012 | Audio Players & Recorders
Qual a potencia em RMS do spl 12 ?
la potencia em RMS is DUAL 4-OHMS at 300 RMS
Jul 23, 2011 | Soundstream SPL 12 Car Subwoofer
I have a sound stream xta 600.2 what would be the best 12" subs to with it
match your total rms output at the resistance you will be running the amp at to the subs.
if your amp puts out 300w RMS@ 4ohms, then it will produce 600w RMS@ 2ohms. half the resistance, double the power.
So now that you know your available power, you should get speakers that will be used to the fullest at that given resistance.
If you have two 4 ohm subs that have a power handling of 300 watts, Then you can wire them in parallel ( + to + and - to -) to get a 2 ohm load (which will be 300w per sub with the above amp) or in series (+ to - to + to -) to get an 8 ohm load. (300w amp @ 4ohms = 150w amp @8ohms = 75 per sub).
Keep in mind: choose the speakers to fit the amp, not the amp to fit the speakers. If the amp has more power than the speakers can handle, you will blow them. and ALWAYS USE RMS WATTAGES.
May 06, 2011 | Soundstream Xstream XTA600.2 Car Audio...
Hi i got two speakers clarion xw 1500 ,i`m looking for amplifier good quality and strong enought can supply power for two subwoofer speakers same time,please help me
The Clarion sub woofers that you have are 600 WATT RMS each, with a combined power handeling of 1200 WATT RMS. Your best option is buying a 1 ch Amplifier (monoblock) Anything in the region of 1000 to 1500 RMS will be more than enough. Brands that you should look at MTX, Phoenix Gold, Soundstream, MA Audio, Kicker, Hifonics, MB Quartz these are but few of the good quality brands out there in the mid to high end range.
If you are on a tight budget then a good alterrnative without a lot of compromise on quality versus cost then Quantum Audio, Crunch Audio, Kenwood will still do the job just fine.
If you are not restricted by budget. Zapco, Mcintosh, DLS and others are up there in the creme de la creme of car audio.
Another brand name that i have used that is not very well know (as far as i know) is Elemental Designs. They have a great monoblock amplifier that delivers all its power at 12V as oposed to most other brands needing 13.8V (V=Volts) and over, it is also suprisingly inexpensive for its quality.
I hope this helps you in the right direction.
Feb 05, 2011 | Clarion XW1500 Car Speaker
Whats the rms rating
look it up online just type in the speaker name and model number
Apr 09, 2010 | Soundstream SPL Mule Car Speaker
What amplifier should I get?!
planet audio vrx-600.5 it runs 100watts rms to all four corners and will give you 300 wats rms to a 2 ohm sub all day long.
Jan 27, 2010 | Car Audio & Video
Speaker wiring
No degradation. The smaller the ohm, the better the signal ( least resistance ). You and your system should be fine.
Oct 23, 2007 | Tomtom GO 700 GPS NAVIGATION BRAND ONLY...
Car Audio & Video Logo
35 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
