Question about Kitchen Appliances - Others
How does it wok
They don't "wok". You have to get a Wok to wok. What is the real question?
Nov 29, 2014 | Cars & Trucks
Farberware 303 electric wok
e-bay or perhaps yarsellr or craigslist
just a few ideas
Jan 23, 2014 | Kitchen Appliances - Others
I heard that you should season your wok before you use it for the first time. How do you do that?
1. Wash your new wok with hot water and liquid detergent.
2. Rinse and dry thoroughly.
3. Now place on the heat and keep tilting the wok until it has all turned a blueish-yellow.
4. Add a thin film of oil to cover the entire inside of the wok and use a paper towel to make sure the whole wok is covered with a layer of oil.
5. now put the wok back on a medium - low heat for about 10 minutes.
6. wipe the oil off with another paper towel. Don't be alarmed that you will see black on the towel.
7. Repeat the steps above until no more black comes off the wok.
Feb 18, 2013 | Home
I am really getting into wok cooking but have you got any tips for me?
Wok cooking is a really healthy and tasty way to cook but you have to know what you're doing otherwise it could all burn and stick. Take a look at this article that gives 10 tips to better wok cooking.
Feb 18, 2013 | Home
Do you need to use oil when you are cooking in a wok?
Yes you do need some oil for wok cooking otherwise the food will just stick to the sides of the wok and burn. The secret is to pre-heat the wok before you add the oil. Then pour a bit of oil in and tip the wok around until you have coated the sides. Then you can add the food. Make sure that you stir constantly to avoid burning.
Feb 18, 2013 | Home
My dear wife took the lid handle off our breville gourmet wok. The pieces include a screw, a spring and 3 other parts. Im not sure if i put it together properly. Could you help out. Thanks
This is for assembling the Breville Wok lid. This has a built in vent that lets steam escape during cooking. There are 8 pieces not including the glass cover: bolt, metal vent, black O ring, tan round plastic piece, black lid piece (has open/close) on it, spring, clear plastic seal, lid handle.
Order of assembly as follows, starting on inside of glass cover.1. Bolt.2. Metal vent piece sits on top of bolt.3. Black O ring fits snuggly onto of vent piece.Insert what you have assembled against inside of glass cover, bolt poking through topside of glass.4. Add tan plastic piece with 3 prongs going facedown against the glass hole of cover.5. Larger black lid piece goes next. You will need to line up the openings on tan piece and this lid piece so that it sits semi-flush against glass. When complete this piece will turn in place to open/close vent (less than 1/4 turn before stopping).6. Add clear plastic seal to underside of handle.7. Place spring between handle and top of black lid piece and screw together until snug.
Test lid by turning lid piece. It should move back and forth according to the open/close print on top. If no luck, go to step 5 and try again. It is a little tricky, but does work when done correctly.
Feb 02, 2011 | Breville EW30 Gourmet Non Stick Electric...
I need the temperature control/probe for the wok
Hi and welcome to FixYa. I am Kelly. Here is a source for a universal one:
Rival is one of the many brands it fits.
Thanks for using FixYa.
May 11, 2010 | Rival WS60 Non Stick Electric Skillet
GC913 wok ignitor installation
The electrode goes through the wok burner bowl then the spring fits under the bowl. You have to push it up until it clips into the groove on the electrode. Should be quite a tight fit.
Mar 27, 2009 | Fisher and Paykel GC913 - Stainless Steel...
Kitchen Appliances - Others Logo
27 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
