Question about The Office Equipment & Supplies
THE COVER FOR THE WS60 WOK SHATTERED, DO YOU STILL CARRY THEM OR WHAT WOULD I LOOK FOR IT IS 13 3/4 INCHES, WOULD THAT BE REALLY 14?
Canon c2880 streak across width of 8 1/2 X 14 paper when printed
THE PAPER SELECT ARE NOT COMPATABLE, SELECT LGL IS EQUAL TO 8.5/14 FLSC IS EQUAL TO 8.5 /13. TRY TO SELECT BLACK COLOR OR CLEAN YOUR DEVELOPING UNIT.
Feb 06, 2014 | Canon imageCLASS D880 All-In-One Laser...
How many inches should my wok be? I am only cooking for my family so it does not need to be huge?
don't be too confused by the woks in the shops and all the different sizes. An average family size wok is 14 inches. If you are making a dinner party, a 16 inch wok would probably be better.
Feb 18, 2013 | Home
I am really getting into wok cooking but have you got any tips for me?
Wok cooking is a really healthy and tasty way to cook but you have to know what you're doing otherwise it could all burn and stick. Take a look at this article that gives 10 tips to better wok cooking.
http://www.tigersandstrawberries.com/2006/01/16/stir-fry-technique-ten-steps-to-better-wok-cookery/
Feb 18, 2013 | Home
I have a 1979 fiat spider, I am putting 14" rims
Make sure the rims are the correct bot pattern (4 X 98) and hubcentric. As for tire size, goin from a 13 to 14 inch rim is called plus one. The key is tio maintian the same tire diameter so the gear ratio and speedometer arenlt affected.
A stock 13 take a 195SR- 13 tire, wirth the 'SR' being a 75 series tire with a diameter of 24.52 inches. The closest match in 14 inch tires is 215x60-14 with a diamter of 24.16. As close as possible match.
That would as much tire as youi wouls ever need.
Jan 16, 2011 | 2007 Fiat 124
I need the temperature control/probe for the wok
Hi and welcome to FixYa. I am Kelly. Here is a source for a universal one:
http://www.marbeck.com/fry_pans_universal.html
Rival is one of the many brands it fits.
Thanks for using FixYa.
Kelly
May 11, 2010 | Rival WS60 Non Stick Electric Skillet
I cant copy legal size
Be sure to set Paper Size to LGL (14 inches long)/FLSP (13 inches long).
Additional Function > Common Settings > Reg Paper Size > Drawer 1 > Select right paper size
Jan 25, 2010 | Canon imageRUNNER 1023iF Black and White...
Could I use wire size 14 for 1 1/2 ton air window
No sir,14 gauge,three conductor will carry only up to 15 amps,which is usually wired for lighting circuits.Look on the electrical requirement plate on the unit,usually located under the front panel cover.It will tell you how many amps are drawn when unit is operating.Using a three conductor cable;wire accordingly:#14--15amps----#12--20amps---#10--30amps----#8--50amps.These are the wire sizes and the current(amps)they will carry.Be safe! Gregg
Jun 11, 2009 | Heating & Cooling
Need help viewing all public television channels
Your TV is set for standard broadcast. You need to go to the set up menu and change from antenna/normal to cable mode. In standard broadcast mode you receive off the air programs 2-13 vhf and 14-83 uhf. In the cable you receive 2-13 and cable channels 14 -125 if the set is not too old. When cable channels first came out some sets would just cover 14- 36 or 14- 47 or 14-66 etc. The newer sets cover the now standard cable channels 14-125. Hope this helps you Stargazer
May 25, 2007 | Quasar SP-2725 27" TV
27 people viewed this question
Top The Office Equipment & Supplies Experts
Gareth Cockram
Gareth Cockram
Tygh Duval
Tygh Duval
Jerry Greenberg
Jerry Greenberg
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
