Question about HP Office Equipment & Supplies
Hp design jet t790 error 47.01 - HP Office Equipment & Supplies
    Master:
  • 412 Answers
You'll be much happier with a Canon or Epson when you decide to replace this.
Posted on Apr 23, 2017
faxman789
  • 297 Answers
SOURCE: getting a system error 1180
System Error 1180: Capping Motor Error
Description:
Capping Motor over current is detected.
Corrective Action: Try the following:
When the ambient temperature is very low, the Pump Motor Tube becomes hard and the load on the Capping Motor is increased. Make sure that the Printer is in an environment where the temperature is not below -10oC or higher than +85oC.
The Capping Station has a Torque Limiter for up and down operation so that the Capping Station does not experience any over current. Apply grease on the shaft of the Capping Station Gear so that it helps with rotation.
Make sure that the Capping Station cables are connected correctly and are not damaged
If the Capping Motor cannot be rotated, replace the Capping Station
Replace the Main PCA if nothing above corrects your problem
Posted on Jan 15, 2009
  • 5 Answers
SOURCE: Error code 93:11
System Error: 93:11
Description: Unable to pressurize the IDS.
Remove ALL the Ink Cartridges and reinstall them one by one in to the Printer.
Replace the Ink Cartridges.
Replace the APS Assembly.
If the System Error continues, replace the Ink Supply Tubes and Trailing Cable.
Posted on Mar 10, 2009
puertobori
  • 7733 Answers
SOURCE: We have a HP Design Jet 500 We turned it on and
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
    NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ). Figure 2: Example USB connection (your product might not look exactly the same as this example)c01651067.gif
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Solution two: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Dec 03, 2010
cyberware
  • 196 Answers
SOURCE: What is system error 0B0006
The Trailing Cable has been incorrectly connected OR the fuse in the Electronics Module has been burned.
Corrective Action: Turn the Printer OFF and disconnect the trailing cable. Check that the ends of the Trailing Cable are flat and are not damaged or bent. Reconnect the Trailing Cable correctly, making sure it is pushed in firmly. Do the resistance test. Power ON the Printer and check if the Error Code disappears. If the Error Code continues, replace the Main Logic Board
Note: The logic board is a direct replacement for the Designjet 1050C Plus and 1055CM Plus. If the plotter you are repairing is the Designjet 1050C (not Plus) you will also need to replace the memory and the firmware.
If you are repairing a Designjet 1055CM (not Plus) you will have to replace the Hard Disk Drive also. The firmware is identical for the 1050C Plus and 1055CM Plus
Note: The aerosol fan is not used in the Designjet 1050C Plus or 1055CM Plus. Coil the cable out of the way or completely remove the fan.
WARNING TAKE CARE WHEN CONNECTING THE TRAILING CABLE TO THE ELECTRONICS MODULE OR CARRIAGE. INCORRECT INSTALLATION WILL BURN THE FUSE IN THE ELECTRONICS MODULE, CAUSING THE COMPLETE FAILURE AND REPLACEMENT OF THE LOGIC BOARD. 100 OHMS OR HIGHER MUST BE SEEN AT THE TEST POINTS. CONSULT THE SERVICE MANUAL FOR CORRECT PROCEDURE.
Continuable and Non-Continuable Error Codes
Some of the Error Codes are continuable, which means you can press Enter on the front-panel and continue working with the Printer. Non-Continuable Error Codes do not allow you to continue working with the Printer, in this case power the Printer OFF and ON again and see if the System Error disappears. If the Error Code reappears, then the Printer requires service in order to resolve the problem.
System error codes are hexa-decimal based numbers generally caused by internal system errors. Only try one recommended action at a time and check if the error code has disappeared.
thanks and regards
kindly rate this solution
Posted on Feb 12, 2011
seeker5211
  • 1089 Answers
SOURCE: I have an HP design
22:10 Ink Supply Station failure.
Get the Ink Supply Station replaced.
Get a tech to do the work. You will not want to do the work yourself.
Posted on May 06, 2011
How to remove the error paper loaded incorrectly:remove paper on hp Designjet T790
Ensure you have the full range of support from HP.
I have Support assistant and HP printer assistant on my desktop. These were downloaded from the HP support website.
Oct 11, 2017 | HP Office Equipment & Supplies
My HP Designjet T790 report "Error 21.2.:13, restart, if problem persists call support" i restarted but still can't print. Can you help me? Thanks
This is a service station error. One of the more common causes I have come across is a piece of paper or foreign object jammed in the service station. It is located on the right hand side of the carriage. Unplug the plotter. Plug it in and the minute that you hear the print head move, unplug the power. Then open the window, move the head out of the way and look for a foreign object stuck in the service station.
May 15, 2015 | HP Designjet T790 44-In Postscript...
Hp design jet t790 error code 2.0.10
Wrong error code, Pl check once again
Dec 01, 2014 | HP Office Equipment & Supplies
49.4C02 service error on laser jet 2300n HP ?
Check these things:
1) printer driver
2) Size of document to be printed...is it non-standard?
3) Complicated fonts/colors design.
4) Flush the printer queue/spooler.
Aug 06, 2014 | HP LaserJet Office Equipment & Supplies
How to recovery Hp Designjet T790 24-in hard disk?
jeano: if you don't have the Recovery DVD, get with the Manufacturer of the hp Designjet, they will send it free (in warranty) with instructions. bigAl
Apr 19, 2014 | Misc - MFG CR650BBCB Hp Designjet T790...
Error se 36:01 hp designjet t790
If this error code was caused by a paper jam better could you tell what lead to this erro, unplug the power cable from the printer and clear the blockage. Open and remove the Clean out assembly from the printer and see if you have any particles left inside it. Plug in the power cable again and check if the Error Code has disappeared.
Nov 15, 2013 | Office Equipment & Supplies
Hello, I have a T790 with 60.2:17 error since the
Process 1..
1. Switch the power off from the back of the product, wait two minutes, then switch it back on again.
2. Check the power cord; try connecting it to another power socket.
3. Check that the product is properly connected in all other respects.
4. Switch the power off from the back of the product; remove the Formatter; reinsert the Formatter; switch the power on again.
Process 2..
1. Turn off the product with the Power Key on the left of the Touch Control Panel.
2. Press and release the Power Key to turn on the product.
3. Wait for about 10 seconds until the 6 buttons on the Touch Control Panel come on and then press
and release one after another the RIGHT -> HOME buttons.
4. Wait for the unit to complete the booting process. The logs are now enabled in the product even if
the product hangs and shows a system error.
Once U got the error, check the error related spare, replace it, any help post your query..
Formatter snap:
Aug 22, 2013 | HEWLETT-PACKARD T790 InkJet Plotter...
Yellow & Magenta not printing
Both print heads are clogged, try to clean it manually if not succeeded replace both of them.. U can find how to clean print heads in you tube..
https://www.youtube.com/watch?v=Ztl_SiUdPLw
Jul 29, 2013 | HEWLETT-PACKARD T790 InkJet Plotter...
Service Manual T790
hi.i have the code but i cant say that here.hp designjet t790 service menu code 09361002314 azad
Mar 17, 2012 | Office Equipment & Supplies
HP Design Jet 600 Plotter
The problem the 'alignment error' this causes is car desalignment, is need repair phisical.
May 29, 2008 | HP DesignJet 1050c plus InkJet Printer
56 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
