Question about Canon CanoScan LiDE 25 Flatbed Scanner
CanoScan Lide 25 error message
I ge the same error: "Error in scanner . Turn off scanner and follow instruction in manual,scanner drive will be closed(Error 201)"
Then something about a "cannot find Twain"...
I loaded all the upgrade drivers...HELP!
Ok, I solved this problem in an unorthodox fashion but it worked... so far that is. First a little history, I was getting this problem constantly and I was at the point where I was going to dump the machine in the trash... therefore I decided to do a little surgery.
Solution: I ripped off the plastic sides of the scanner and lifted the glass from the front while it was still in the back of the machine. I started to try to scan. After doing that I received a different error. After that error I replaced the glass without the plastic sides and it scanned with no problem. It works for me and it has worked since. Unorthodox? Yes it is, but when I forced a different error and forced recognition. I believe this is a software problem and not a hardware. Good luck to the rest of you. Any questions, I'll try to reply.
Posted on Aug 29, 2009
  • bozdograul
    bozdograul Nov 07, 2012
    It worked for me!
  • 23 Answers
It's a problem CIS. Replaced the CIS, if you loocking it.
Posted on Nov 13, 2009
  • Canon Master
  • 365 Answers
Unplug the usb cable and reboot.
Plug back in and watch what the OS states.
It should install some drivers and then you should be in business.
Posted on Jul 24, 2009
By Massoud on Mar 28, 2008" " When i try to snan ,i come up with a aignal"Error in scanner . Turn off scanner and follow instruction in manual,scanner drive will be closed(Error 201)
if that scanner is powered by the USB port .. you might want to try a different port or a powered external port .. sometimes some USB ports cant supply enough power ..
Dec 23, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
Hi there, I have a Canon Flatbed scanner (Lide 25) and when i try to scan i get an error message as follows: 'Unable to load TWAIN server'. How can i fix this?
Hi Jason
A Simple fix just reinstall your software that came with the scanner and this should re establish the link between twain and your scanner
Regards Alan (alstech)
Please dont for get to leave feedback if this was helfull
May 12, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
Re: CanoScan LIDE 30 on Mac OS X (Version 10.5.6)
I was able to install the CanoScan Toolbox by doing the following: MacIntosh HD --> Library --> CFMSupport --> Get Info. Under 'Sharing & Permissions', I added my name & changed 'Read only' to 'Read & Write' .
Problem now: I can't install the LIDE 30 Scanner Driver. I clicked on the downloaded driver & a box opened. I clicked on ScanGear CS Installer, but that didn't work. I then clicked on 'Into Plug-In' --> ScanGear CS 7.0X --> Choose Application --> CanoScan Toolbox 4.1 --> Plug-Ins, but couldn't continue as the 'Open' tab was greyed out. What should I try? Any suggestions would be appreciated.
Feb 27, 2009 | Canon CanoScan LiDE 30 Flatbed Scanner
Canoscan does not work on vista 64-bit
I'm not sure if this will work on the lide 20. I have an lide 35, and there are no 64 bit drivers for it. I downloaded and installed the drivers for the lide 60, told the computer to manually find the lide 60 drivers for my scanner, and installed the canoscan toolbox for vista 64 bit. Works like a champ.
Nov 07, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
CanoScan LiDE 20
already install the scanner driver but still can't working properly.
Sep 04, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Canon CanoScan LiDE 25 Flatbed code 39
Did the message say:
"Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)"
Download the Delete driver application from Canon's website and run it. After deleting this and rebooting, try installing again.
May 29, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
CanoScan LiDE 50 error code: 2,7,0
Has your scanner been working before?
If so, has anything changed since then such as new printers or other devices added to the computer, or upgraded to a new OS?
Which OS are you using?
When exactly does the error occur?
Does ScanGear open?
Are you able to preview?
Try connecting the USB cable to another port on the computer (directly to the computer...not through a HUB or any other device). Bypassing a hub, which would have to be a powered HUB, or other devices would rule out any issues with those devices.
Ultimately trying the scanner on another computer would rule out issues with the scanner as well.
May 09, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Error 201
Which scanner is this? Error (201) usually indicates some sort of power issue...such as the scanner is not getting enough power. If this is a USB powered scanner you may try connecting to different USB ports on the computer.
Mar 28, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Canon CanoScan LiDE 25 Flatbed Scanner Logo
1,179 people viewed this question
old marine
old marine
