Question about Cerwin Vega Audio Players & Recorders
How can I hook up my cerwin Vega ht 10d subwoofer to my computer surround system
    Sergeant:
  • 299 Answers
You'll need some adapter cables. I would probably try a Y cable in each front speaker line, then connect the pair from the left channel to the "L" binding posts on the back of the Sub. Same for the right.
Not sure of the configuration of your existing surround system. Essentially, you want to "Y" the left and right channels wherever you can get a hold of them and connect each to the back of the sub.
Posted on Apr 23, 2017
2 Suggested Answers
jsinex2421
  • 62 Answers
SOURCE: cerwin vega ht-10d subwoofer won't work in yamaha reciever
Actually, I had the same problem with my JBL PB10. It was the cable. I had to buy a one direction shielded rca cable. If you put it in backwards it will not work. The cable was around 75.00. But it was well worth it. The first cable I tried was a cheap sony brand sub rca cable. I ended up buying the AR(Acoustic Research) 15ft. directional subwoofer RCA cable from Best Buy. Make sure you have your receiver set to the proper setting too. If you have it hooked to main, set it to main. If you have it hooked to the L.F.E.(RCA cable) set it on L.F.E.. Some have the option to set to both. If it is a non powered sub a RCA cable will not work. You will have to run your main speaker cables to the sub first, then from the sub to the speakers. It then "piggybacks" the Low Frequency signals from the receiver.
Posted on Jan 08, 2009
Multi channel Av reciever model STR-DH540
I went with Cerwin Vega for my speakers and they have been great. You can find them at Best Buy I believe or even order over Amazon.com (shipping is always high). Be careful buying over eBay unless they are like new or new--you don't know how they've been used or abused in that case. I have 4 smaller bookshelf speakers for the surround and back surround, an LW12 subwoofer, and some 10" Cerwin Vega L9 units for the front. I also bought a nice CV center channel speaker--went a big bigger and better on that unit as it plays the voices on 5.1 and 7.1 surround.
Jan 25, 2015 | Audio Players & Recorders
Anyone know where I can find a replacement woofer for a Cerwin Vega HT-S12A? It is a 12 inch woofer...The cabinet and amp are in great shape however a stupid kid came over and cranked the sub and seems to...
  • Sounds like the speaker coil to me.
  • Yours is a a 150 watt, 12" subwoofer. If I were you I would not knock my head on the table looking for a Cerwin Vega to put into there. You can a far better quality one for a reasonable price. This Pioneer here.
http://www.google.com/products/catalog?q=12%22+woofer&hl=en&prmd=ivns&bav=on.2,or.r_gc.r_pw.&biw=1600&bih=799&um=1&ie=UTF-8&cid=5529109873222407637&sa=X&ei=glO6TamAB-L00gGzvKmNAQ&ved=0CLoBEPMCMAM# I
  • I don't see that Amp blowing this speaker and it averages about $75. Just turn the box on it's side and remove the screws holding the speaker in place. Drop the speaker. Remove connectors and revers to finis the job.
Regards,
Tony
Apr 29, 2011 | Cerwin Vega HTS12A Subwoofer
What is the omhs of a cerwin vega avs sat4 surround speaker
According the the Cerwin Vega manual for this model and others, all speakers in the system are rated at 8ohms. This includes the Sat4 Surround Speaker and all other channels.
More information can be found at Cerwin-Vega's service and support page at: http://www.cerwinvega.com/product-manuals.html
You can also call them for information as well.
Mar 19, 2011 | Cerwin Vega AVS-5.1 System
I have a set of cerwin vega AT15's my dog decided to put his paw through the one surround and puntured the paper cone I need total 15" woofer replacements or repair. or I need replacements I can buy and...
Ebay sell Cerwin Vega Surround (rubber bit) replacements. If he has ripped the cone too, appart from replacing his back legs with wheels (joke!), contact Cerwin Vega directly and they will send you out a new "driver". These are easily fitted at home by any one with a screwdriver
Sep 02, 2010 | Audio Players & Recorders
Cerwin vega passive subwoofer model sw-12b
Passive woofers are hooked up to the output of a sub amp.
Active woofers are hooked up to the sub out of a receiver. They have the amp built in.
Mar 09, 2010 | Cerwin Vega Audio Players & Recorders
I have a blown LW12 Cerwin Vega Speaker. Can
You have several ranges of options.
1) Contact Cerwin-Vega customer service: http://www.cerwin-vega.com/
2) Do a google search on "cerwin vega speaker replacement". You will find companies both that offer repair or repair kits (e.g., www.simplyspeakers.com) or sell replacements. Contact them - they have the expertise to tell you which of their products are most suitable for your model.
Nov 01, 2009 | Cerwin Vega LW12 Subwoofer
Cerwin vega ht-10d subwoofer won't work in yamaha reciever
Well, as I know, your Cerwin Vega subwoofer is designed for use with stereo systems. Therefore, it has only 2 channels for input, and 2 channels for output as well. However, you can try this out; the first thing I suggest is that you hook up your main front channels through the subwoofer. All you have to do is to connect the subwoofer input to the front channel output on the amp, then hook up your front speakers to the satellite output on the subwoofer. As long as you make sure that system is working on 8 ohms, I believe this can activate the subwoofer.
Sep 15, 2007 | Athena AS-F1 Main / Stereo Speaker
62 people viewed this question
Top Cerwin Vega Audio Players & Recorders Experts
 Grubhead
Grubhead
Joe Lamb
Joe Lamb
Steve
Are you a Cerwin Vega Audio Player and Recorder Expert? Answer questions, earn points and help others
