Question about The Watches
What kind of batteries fits the oulm 1149 watch?
    Master:
  • 263 Answers
2 Suggested Answers
  • 39328 Answers
SOURCE: How do you change battery in a oulm unisex watch 1149?
  • Open case
  • Remove old battery
  • Install new battery
  • Close case
Posted on May 07, 2016
What size of battery fits guess steel
Just take it to a local jeweller and they will change the battery whilst you wait for $6 to $8. There are so many batteries and usually you can't by just a single one in the small sizes that watches use.
You often need a special tool to get the back off, and a jeweller's eyeglass to see the tiny screw and the right screwdriver to fit it.
May 20, 2016 | Guess Waterpro Bracelet Watch
  • Open case
  • Close case
May 06, 2016 | Watches
Need new battery, last owner took original battery out.
Take Watch to Watch shop for them to fit new battery .. As you don't have original battery in your watch, you would not what type to buy if you wanted to fit it yourself.
Mar 13, 2015 | Fossil Watches
How long should a bulova watch work ---my husband bought me a bulova watch 7 years ago ----it stopped working & I thought I just needed to replace the battery ----so I did but less than 3wks later the...
I would expect the battery to last more like 3 years than three weeks.
Did you replace the battery yourself? If so, are you sure that it's the correct one correctly fitted? Did you use a quality make of battery?
I've known people to use metal tweezers to fit batteries - the risk of shorting the battery is very high with the result that battery life is seriously reduced.
Look at it this way - the watch cost you over 300 bucks, so it's a decent quality watch. Take it to a professional to have a battery fitted - it's not worth the risk doing it yourself if you're not completely sure what you are doing, and if the battery they fit fails then you can just take it back to them to sort out. Having a battery fitted for you should not cost a lot of money - but if you have somehow damaged the watch by trying to do it yourself then it will have been a very expensive way to save a little money....
Oct 14, 2017 | Bulova Diamond Watches
How do you change the battery in a black dice flow watch
You need to open watch case back using appropriate tools. There are two batteries in this model - one for each watch movement. Unscrew/un-clip battery contact. Memorize polarity (+ and -). Take the battery to your nearest watch battery shop or watch repair shop and buy the same one. Fit new battery back in watch (remember polarity!). Fit back contact as it was. Close the watch case back. Set the time. Done.
Feb 25, 2011 | Black Dice Industries BD04101 Flow From...
I need to replace battery
All you need is to open watch case back, remove the rubber seal and unclip the contact. Take the battery out (memorize polarity: + and -) and buy the same one. Fit new battery in the right way back in watch, fit the contact, place back rubber seal and refit watch case back. Reset the watch. Done.
Feb 25, 2011 | Polar M32 Heart Rate Monitor Watch
How to open the back of Kenneth Cole KC3434 watch to change the battery?
BASIC WATCH BATTERY CHANGE
Get a replacement battery for your watch. Some watches have the battery information stamped on the back plate. If yours doesn't, you'll have to wait until you've removed the old battery to see what kind of replacement watch battery you'll need.
Lay your watch face down on a non-scratching, non-skid surface. It may help to clamp the watch to the surface.
Remove the back from the watch. You might be able to pry it off with your fingernail, but you'll probably need a stiff, thin tool like a knife or screwdriver. You can also buy watch repair kits, which have the perfect tools for the job. Check the watch back for a small notch to insert your tool, but not all watches have these.
Remove the battery from the watch once the back is off. You might need to tip the watch over to let the battery fall out.
Insert the new watch battery into the proper space, first double-checking its size against the old battery to make sure it will fit. Press lightly into place.
Replace the back on your watch. Make sure you press firmly to get the back seated snugly.
If this doesnt work, then take to a local jeweler/watchmaker who is equipped with the right tools to assist you.
Best regards.
Aug 17, 2010 | Kenneth Cole KC3434 Wrist Watch
I have a aspenus jdag 3atm with a missing battery and i don't know what kind of battery it is because all of the betteries that i have found in stores are too thick for them to fit.
Take it to a watch shop or to Sears and they should have the extra small watch battery you need or they can order it for you if it's something rare. The cost for just the battery is about $3.
Apr 21, 2010 | Watches
Watches Logo
44 people viewed this question
Top The Watches Experts
D. E. Hev
John mullen
Are you a The Watch Expert? Answer questions, earn points and help others
