Speaker hook up, sub hook up, sound
Surroud sound, help, would like a manual, lost in move, thank you, Jackie
  • 10 Answers
SOURCE: NO Sound from NEW speaker unit?
Yes the green wire that goes from the speaker should be plugged into the green jack on the PC. An easy test to see if its the computer or the speakers is to have the speakers on and volume up a little and tap the tip of the green plug with your fingers while out of the computer. If it makes a humming or any noise at all while tapping, the speakers are working if not lets check voltage at the power plug or if the unit has any lights on. Gook luck!
Posted on Mar 25, 2009
remington870
  • 48 Answers
SOURCE: hook up wireless speakers
I'm assuming the wireless speakers you have utilize an RCA jack to connect to the receiver.
Solution:
The good news is yes, you can use them on your receiver. The bad news is that the only output on your receiver is "VIDEO OUT" so whatever you want to watch or hear on the wireless speakers must be connected to the "VIDEO INPUT".
If the wireless speaker module uses speaker wire to connect to a receiver you will simply tap into the surround thumb clip speaker jacks.
I will add that wireless speakers tend to be disappointing when used in home theater.
Posted on Mar 31, 2009
  • 19 Answers
SOURCE: Subwoofer turns on and is hooked up, but no sound.
The signal don't seems to be present to the sub input.
Try change the wire betwen the audio system and the subwoofer.
Spider Guy
Posted on Mar 15, 2010
plaztiksr4me
  • 154 Answers
SOURCE: sherwood home sub sp210 manual for speaker hook-up
pull sub out it may have been replaced and the speakers inside were not connected.
Posted on Apr 09, 2010
SOURCE: Lost manual..do not know what is the difference sound surround
Hi use this link to download the manual .
manualnguide.com/manual/teac-ag-v8060-receiver.../page/2/.
Take care.
Posted on May 18, 2010
I Lost My Samsung HT-D355k Home Theater's Remote & Now Surroud Speaker & central speaker is not Working. help me what should i do?
Get a replacement remote of a substitute to help you select menu items. Otherwise try to navigate the menu using the buttons.
Check this site to get manuals for this product.
HT D355K HT D355K ZN Support SAMSUNG Gulf
Feb 09, 2015 | Samsung Audio Players & Recorders
Home subwoofer no sound
always 1 speaker per amp output!!! and between red and black only. You can send any signal into a subwoofer. Hi frequencies will be quiet but it's safe. switch a normal speaker for the sub and listen, you should hear a muffled sound. Look for the sub output on the amp... do you need to switch on the sub manually somewhere?
Sep 02, 2014 | Boston Acoustics Audio Players & Recorders
I have a Fisher RS-909 Surrond Sound amplifier. It has no "sub out" jack. I had the sub-woofer working in the past by wiring it as shown in the manual. The problem is that the system was in...
Alright i had a chance to look over things, this is how you are going to hook up the sub. first we'll be connecting the surround sound unit to the sub woofer.
surround sound unit sub woofer
left front: positive (+) <-----to------------->(+) left speaker level in
negative ( - )<- - -to- - - - - - ->( - ) left speaker level in
right front: positive (+) <-----to------------->(+) right speaker level in
negative ( - )<- - -to- - - - - - >( - ) right speaker level in
now that the surround sound unit is connected to the sub woofer you will need to connect the front surround sound speakers to the sub woofer.
sub woofer front surround sound speaker
left speaker level out (+)<-----to--------> (+) left front speaker
left speaker level out( - ) <- - - to- - - - ->( - ) left front speaker
right speaker level out (+)<-----to--------> (+) right front speaker
right speaker level out( - ) <- - - to- - - ->( - ) right front speaker
Alright now that the wires are all over the place and plugged in
turn everything on and see how it sounds. let me know if everything is working as it should. if you need help with anything else or if something does not seem right please feel free to contact me via e-mail or phone
Mark Woodring
Feb 13, 2011 | Audio Players & Recorders
Spider Guy
Mar 15, 2010 | Onkyo 630-Watt 7.1 Channel Home Theater...
Hook up wireless speakers
Solution:
Mar 24, 2009 | Sony STR-DE475 Receiver
New (old) house with stuff installed when we got it
IF YOU HAVE THE SAME AMOUNT OF CABLES AS SPEAKERS HOOK THESE UP TO YOUR AMP THEN SUB TO SUB OUT PUT ON YOUR AMP WITH A SUB CABLE OR PHONO THAT REACHES FROM AMP TO SUB.SET AMP TO ALL CHANNEL STEREO OR MODE THAT SENDS STEREO TO ALL SPEAKERS,ALSO SET SPEAKER SIZE IN SETUP OF AMP TO SMALL AND SUB OUT PUT TO SUB ONLY.YOU SHOULD GET MUSIC AROUND THE HOUSE.IF SOUND IN SAY BEDROOM IS NOT AS LOUD AS BATHROOM USE THE TEST TONE TO LEVEL OUT EACH SPEAKER.
HOPE THIS HELPS.
CABLE GUY.
Jun 26, 2008 | Audio Players & Recorders
I've got a home theater in a box with the HTR 5635 receiver. I've moved and lost the set-up directions and have forgotten how to hook up the subwoofer to the receiver. Can you help me?
YOU SHOULD HAVE A SUB OUT PUT ON THE BACK OF THE AMP MARKED PRE OUT IF NOT CONNECT THE FRONT LEFT AND RIGHT SPEAKER OUT PUTS TO THE SUB THEN FROM THE SUB TO YOUR SPEAKERS.
HOPE THIS HELPS
CABLE GUY.
Jun 19, 2008 | Yamaha Audio Players & Recorders
12w3v2 Started making distorted bass noise at low volume
Connect each speaker coil one at a time to a square 9 volt battery and watch for the cone to move.
Also try hooking another speaker to your amp just to make sure the noise isn't in the amp.
You can use a 9 volt battery to test wire polarity also. Hook up the + wire of the speaker to the + terminal of the battery and the - speaker to the - battery terminal. If the speaker moved UP or OUT then the wiring is correct. If it moved IN or DOWN then the + and - wires are backwards on the speaker.
Also if you have two or more speakers hooked together test all the same way while they are hooked to each other. ALL of the speakers need to move in the same direction at the same time.
Clipping causes more speaker damage than anything. "Dirty Power" can happen in good quality amps too. The gain control is to match the voltage between the headunit and the amp. It is NOT a volume or boost knob. If you overdrive the first stage of the amp and then clip it damage will occur to the amp and speakers at some point.
Hope this helps.
Jan 04, 2008 | Jl Audio 12W3 Car Subwoofer
I lost the installation manual on JHT525.
plug your low input into the subwoofer output of your reciever.that should get the sub working then you have to run speaker wire from your speaker outputs on your reciever into your sub in the top row of inputs then the outputs on the back of sub(the bottom row of speaker hookups go out to your speakers....my email is bsharp76@hotmail.com if you still cant get it i can talk you through it on there or ill give you my instant messenger name is you still have problems good luck,b
Apr 05, 2007 | Jensen JHT525 System
26 people viewed this question
 Grubhead
Grubhead
