Question about Locks & Locksmithing
I have a combination lock. The auxiliary key turns around (360 0C) without locking or unlocking; what should I do?
SOURCE: 2002 Jeep Liberty, rear window latch is ''locked'' & window is open
i was having the same type of problem. we just put a couple of washers behind the latch and then adjusted the latch and it solved our problem.
Posted on Jan 31, 2009
frcs68
  • 1605 Answers
SOURCE: keyboard locked
if the mouse still works, then go to start>>control panel>>accessibility options.
uncheck all boxes under the general tab.
Posted on Apr 29, 2009
  • 89 Answers
SOURCE: tailgate lock sticks and key won't turn. can't unlock tailgate
the barrel is faulty and needs replaced
Posted on Jul 12, 2009
  • 12 Answers
SOURCE: Hotel Lock
you need the master remote for this model to unlock since it is a "motel set" also you will need the owners manual you will find both by googleing the model
Posted on Feb 08, 2010
SOURCE: presto combination lock on a suitcase will not open
my mother in law has a norton suit case and needs keys the number on the lock is 332 norton do not excist anymore where can i get replacment keys from?
Posted on Mar 01, 2010
How to set a combination on a Samsonite 3 dial combo lock
How to set a 3-dial luggage lock - YouTube
? 1:22
https://www.youtube.com/watch?v=TI4AgFhcnys
Sep 16, 2017 - Uploaded by Distant Lands Travel Store
http://www.distantlands.com How to set luggage locks. Simple and easy instructions on setting luggage locks.
3-Dial TSA LockĀ® & Cable - YouTube
? 1:21
https://www.youtube.com/watch?v=QlysHXuaftY
Jun 28, 2012 - Uploaded by Eagle Creek
it comes with a 50 inch cable. so that you can use this combination to go ahead. and secure different pieces of ...
How to Reset a Samsonite 3-Digit, Built-in Combination Lock ' USA ...
traveltips.usatoday.com > ... > Vacation Excursions > Things to Do on Vacation When purchased, the locks are set on a factory default combination that you can change as often as you wish. Turn the number dials to the previously set combination, or to "0-0-0", the factory default combination for Samsonite luggage. Locate the reset button, usually placed to the side of the combination dials. People also ask How do I reset my Samsonite luggage lock?
How do you open a combination lock without the combination?
How do I set the lock on my Samsonite suitcase?
How do you change the combination on a TSA lock?
Feedback
Lock Instructions - Samsonite
https://www.samsonite.ca/lock-instructions.html Luggage locks approved by the TSA have a universal master key that will open the locks (the keyhole you will see on your TSA lock, when you have not been provided a key ... Every TSA approved lock has an identifying mark that shows it may be opened by the master key. ... Have the lock set on your original combination.
Mar 17, 2018 | Samsonite Photography
Mazda mx3 japanese import 94 reg key fob died, i changed the battery but it will not now unlock the car, the doors are deadlocked so the key wont unlock the doors either, can i re-sync it from outside? Or...
Whether your key fob is damaged or just has a dying battery, there is a way for you to unlock your vehicle and start the car. Just follow the steps below:
  1. Press and hold the auxiliary key release button on the underside of the key fob.
  2. Grab the looped end at the top of your key fob.
  3. Pull out the auxiliary key.
  4. Use the auxiliary key to unlock the driver's side door.
[Read more: What to do when you're locked out of your car]
HOW TO START THE MAZDA 3 WITH A BROKEN OR DEAD KEY
Now that you've managed to enter the vehicle with the auxiliary key, you're going to need to know how to start your Mazda 3. At this point, the auxiliary key can be put back into the key fob, as the key fob can still be used to start your vehicle. This will only take a few extra steps.
  1. Make sure the shifter is in the Park (P) or Neutral (N) position.
  2. Depress the brake pedal.
  3. The light on the engine start button should flash green.
  4. Take your key fob and touch the back of it to the push button start.
  5. When the green light on the engine start button stops flashing and remains continuously illuminated, press the push button start normally to start the engine.
  6. It is recommended you allow the vehicle to idle for about 10 seconds.
Mar 03, 2018 | Mazda Cars & Trucks
Unlock car without keys
I have 4 dial brass combination lock, and I can not open the lock, how I can set a new combination , the existing combination is not working
Jun 30, 2013 | Locks & Locksmithing
Master Lock 5400D Key Storage Combination Lock box i reset it combination a couple of days ago and it worked fine until today. Now it won't open with the new combination. How can I get in to it without...
Two solutions: (if the box is closed and it is attached to something)
1. Contact Masterlock.com and fill out the form, get it notarized and send it in for the combination to unlock it based on the S/N which is on the lock.(http://www.masterlock.com/faq/LostCombinations/). Good luck on this since Masterlock will end up finding something that will prevent them from giving you the combination. Its quite frustrating and NOT worth the trouble.
2. Go to home depot. Buy a 24in bolt cutter ($22) cut the stem of the lock. and replace with a new lock that you can buy from home depot for $ 29.00. If you have a key that is inside the lock box that you really need, You will now need to drill out the combinations piece by piece and the door will pop open or send the lock back to Masterlock. They will retrieve the key for you and send it back.
Jun 25, 2010 | Master Lock 5400d: Portable Select Access...
Doors lock and unlock when not even around car
try changing the batteries in the remote.....
Jun 07, 2010 | 2000 Nissan Xterra
406 wont lock/unlock please help!!!
Switch ignition ON.Press and hold lock button for 10 sec.Switch ign.Off.Remove key from ign. switch.Wait 5 sec.Sinchronization procedure complete.Confirm sinchronization has been successful by locking,double locking and unlocking vehicle. Repeat abuve procedure to sinchronize any remaining key.Good luck
Nov 30, 2009 | 2005 Peugeot 405
Problems to open a Samsonite TSA 007 lock on suitcase
Hi I have a problem to aopen my luggage I think my niece has change my security code accidentally , but now I cannot open my luggage can you please chelp me out?
Nov 08, 2009 | Samsonite Tripod
I have a master lock 1534D and can't remember the combo. How can I reset it?
Check the MasterLock web site to see if they still offer to provide for forgotten combinations. Some years ago I got a combination for a standard rotary dial lock by providing the usual identification information plus a photo of the lock showing its serial number.
Jun 11, 2009 | Master Lock 5400d: Portable Select Access...
Handle will not turn
handle will not turn = locked,
wafer locks on low end safes are utter **expletive deleted**,
it may not be unlocked even if the key is truned fully, play with the key
and or
if combination & key, the combination may alter without user input, or seem to because of play in the dials.
and or
electronic locks fail when the battery is flat
Sep 21, 2008 | Sentry Fireproof Safe
Locks & Locksmithing Logo
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
