Leg print out to put back together after repairs
The #5 sticks, how can this be corrected / repaired?
I would take it apart. Be sure to label parts, take pictures, so you can put it all back together. Some drink probably got split on it, so it sticks. Just clean it with a damp cloth and make sure it has stopped sticking before you put it back together.
Good luck.
Paul
Apr 25, 2016 | Canon MP18D II Printing Calculator - CASE...
How do I disassemble it to make it easy to move it?
backward of how you assembled it I would assume .
Jun 21, 2015 | Exercise & Fitness
How do I replace an impeller on a seagull kingfisher
pull two bolts from bottom leg pull off imp is inside round silver plate on bottom of drive shaft two screws pull off put in turning clockwise as you install put back together good luck
Oct 15, 2014 | Light Outboard Motor Boat Bass Fishing...
I need the written instructions to set up an avid screen gazebo 13x9 model 2086 that I just bought at a yard sale. PLEASE HELP.
How To Assemble Avid Outdoors Model 2086 Screen Gazebo
Start with # 4 poles. There are 4. Attach a #3A to each, and then attach #3 to the other end of the 3A.
These are the 4 legs.
There are 6 #2 and 3 #2A. Attach a #2 to 2A, and then #2 to the other end of the 2A. These 3 are the top ridge pole and the 2 side poles.
I believe there are 4 #1 and 4#1B. Attach a 1 and 1B together. Do this 3 more times. These are the gable poles.
You have 2 connectors that say gable and gable. These are for the top pole and 2 gable poles. You have 4 connectors that say gable and leg. Put the leg poles.....in the "leg" hole, the gable pole in the.....gable hole, and the side pole in the remaining hole. That shoule do it. It's easier to put the top together first, and then get 4 people to raise it onto the leg poles. Yes, the leg poles angle out, not straight down.
Jun 26, 2013 | Garden
Avid outdoor screen gazebo instructions for set up #2086
Start with # 4 poles. There are 4. Attach a #A to each, and then attach #3 to the other end of the 3A. These are the 4 legs.
You have 2 connectors that say gable and gable. These are for the top pole and 2 gable poles. You have 4 connectors that say gable and leg. Put the leg poles.....in the "leg" hole, the gable pole in the.....gable hole, and the side pole in the remaining hole. That shoule do it. It's easier to put the top together first, and then get 4 people to raise it onto the leg poles. Yes, the leg poles angle out, not straight down. How's that?
Sep 17, 2011 | Garden
I lost instructions for my Avid Outdoors screen gazebo model #2086 13'x9'. Any help is appreciated
avid outdoor doesn't offer instructions...can someone please post instructions for some of these...it would really be helpful...its crazy that some of these boxes dont come with instructions?!
Jul 18, 2011 | Garden
Screw to leg has fallen off how do I get cage off of fan?
I have not been able to find a large picture of this fan, but I will tell you what I have run into in the past. On some of the fans there are small clips around the grill where the front and back pieces come together. It would be a case of opening these clips and sliding either the front of back grill off. Reverse the process when putting it back together. On others I have found small plastic wire ties holding the two grills together, one at the screw locations where the legs hook onto the fan. These need to be cut with scissors or wire cutters and replaced with new ones when putting the fan back together. New wire ties can be purchased at Home Depot or Radio Shack.
Please let me know how you make out and I will keep looking into this.
Paul
Sep 19, 2010 | Patton U2-1487 Floor / Box Fan
Blower does not work and heating element heat with
Check for power to the unit. If power exists, check your low voltage. Do you have 24volts to R & C at your thermostat?
Feb 07, 2010 | Goodman GMS90703BXA Heater
Reassembling telescopic sections for a 676B monopod
Each leg lock has a leg locking lever and a screw that hold the clamp assembly tight to the leg. Unlock the leg lock lever, loosen the screw above it that holds the clamp tight to the leg. The legs should fit into each other sice each leg is slightly larger or smaller then then next one. Slide the clamps in the approprite places and tighten the screw enough to hold the clamp assembly tight, but do not over tighten it. Over tightening will damage the 679 tubes.
Dec 25, 2009 | Manfrotto 679B Monopod
Canon printer not printing and gives error code U052
you have a purge unit problem, cost more than the printer is worth unless it is under warranty,
Canon small printer technician
Mar 31, 2009 | Canon PIXMA MP600 all-In-One InkJet...
19 people viewed this question
k24674
jasbo
jasbo
