Question about The Office Equipment & Supplies
I was loosening my child's buckle on her stroller by pulling on the buckle and when I pulled on the buckle and the buckle then got stuck.
How do I fix this?
  • 17 Answers
SOURCE: Stroller pulls to the right.
The following is from the instruction manual for the Expedition LX. It should be very similar to the Expedition LE.
"Stroller pulls to one side:1. The stroller is sensitive to the air pressure in the tires. If the rear tires do not have equal pressure, the stroller will feel like it is pulling to the side with the tire with the lower tire pressure. Check that the rear tires have the same pressure. Add air pressure to a maximum of 25 pounds using a bicycle style hand air pump.2. The alignment of the front wheel of the stroller can also cause the stroller to pull to one side. The stroller is designed so that the front wheel can be adjusted to correct for any alignment problem. Page 3 of the instructions
shows an expanded view of the front fork assembly. To align the front wheel, first loosen the wheel via the quick release handle as in step 2 of the instructions. Grab the front wheel directly in front of the stroller and push the wheel in the opposite direction of the pulling problem. You will notice that the axle will move within the slot on the fork. Move the wheel to the side a small amount. Retighten the quick release handle. Give the empty stroller a push across an empty smooth surface (let go of the handle) and note if the stroller now runs straight. Re-adjust the axle a small amount at a time until the stroller runs straight. Please note that a very minute
movement of the axle will affect the tracking of the stroller. Once you have aligned the front wheel, you can mark the holding plate position with a marking pen if you detach the front wheel on a regular basis. Please note that the hole in the fork is designed to allow the stroller to be adjusted to pull to the right, go straight, or pull to the left. If you continue to have difficulty with tracking, please call our customer service department at (800) 328-7363 for assistance."
Posted on Dec 18, 2007
SOURCE: stroller pulls to the left
It's a wheel alignment issue - I had the same issue & my husband fixed it. Try removing the front wheel & reattaching it. If that doesn't solve the problem, keep adjusting the front wheel slightly until the stroller no longer veers.
Posted on Jan 27, 2009
billshoff
  • 23 Answers
SOURCE: My rear seatbelt in my subaru outback is locked and wont pull out to buckle up. Can it be fixed
I assume you've already worked the seat belt end back and forth with force. Did the belt move at all? Did you remove the rear seat bottom cusion from the car? That will give you additional leverage on the belt.
If the belt twisted the last time it was used and then rolled up, you need to go to the dealer or an upholstery shop for help.
Posted on May 07, 2009
SOURCE: Maxi Cosi Tobi straps locked
hi i had the same problem so i took it back to toys r us where i got it from, they rang manufacture and were advised that they r going to recall them as it is a fault. hope this helps
Posted on Sep 19, 2009
  • 4 Answers
SOURCE: Graco Stroller Buckle
try
http://myebestbuy.com/allplasticbuckleslist-1.aspx
heaps of them there
Posted on Aug 06, 2010
Instructions on how to fold
Kindly follow the steps to below to fold the stroller:
  • Use the ball of your foot to push down on the brake lever, located near the rear wheels of the stroller. Gently push on the stroller to confirm that the brakes are set. Grip the front edge of the stroller's canopy, if present; pull the canopy back towards the rear of the stroller.
  • Push the tabs securing the ends of the harness straps to the harness buckle. Pull the straps aside and remove the child from the stroller.
  • Kneel down next to the stroller's front wheels. Locate the locking mechanism set in between both pairs of front wheels. Use the locking mechanism to disable the swivel feature on the front wheels.
  • Pull the stroller's seat back down to the lowest position; some models may feature locking mechanisms located on the sides of the stroller or built into the handlebar. Lift any latches securing the sides of the stroller in place.
  • Push the handles of the stroller downward. Push the rear section towards the front of the stroller until the device is fully folded. Clip the storage latch located on the side of the stroller to the side of the handlebar.
Apr 24, 2016 | Baby Gear
How can I fold?
Kindly follow the steps below on how to fold the stroller:
Apr 16, 2016 | Baby Gear
How do I let the stroller down?
    Kindly follow the steps below to fold the stroller:
Sep 09, 2014 | Evenflo Aura Traditions Travel System...
Maxi-cosi tobi strap tensioner not working. able to tighten straps when child is in seat but when buckle is pressed to release straps and get child out, unable to loosen straps tensioner will not let go.
Hi, Make sure that when you go to loosen the shoulder straps that the **** strap is pulled toward you, otherwise you cannot make the shoulder straps loosen, this is a safety feature. Hope this helps.
Jul 28, 2010 | Maxi-Cosi Baby Gear
We are having problems openning the buckles on our Maclaren
Hi this is Sarah from Maclaren,
our customer service can help you out with this you can contact them via email at info@maclarenbaby.com ' ); //-->
Feb 21, 2010 | Maclaren Quest Mod Stroller
How to fold a beby trend expedition single
TO FOLD STROLLER
• Close the canopy as described in the canopy section. Recline seat by releasing buckle as described in seatback positioning section.
• The stroller is folded by simultaneously pulling each trigger fold. . When the fold latches are released, the handle will begin to fall toward the floor. Release the fold buttons and press downward on the stroller handle until the stroller is completely folded. Secure the stroller in the folded position by hooking the fold latch, located on the right side of the stroller, over the rivet that protrudes from the frame.
CANOPY
* The canopy features a ratchet system that allows the canopy to be moved forward to block the sun or wind. To adjust the canopy’s position, push forward or backward on the canopy until the canopy is in the desired position. See figure 23.
SEATBACK POSITIONING
* The seat has a multiple position recline that is controlled by a strap and buckle assembly behind the seat. . To recline the seat, loosen the strap through the buckle and adjust to the required recline position. To place the seat back in the upright position, press upward on the seat back with one hand while pulling the strap through the buckle with the other. The strap will lock automatically.
http://www.babytrend.com/download/2007061021349109CT_instructions.pdf
Apr 28, 2009 | Baby Trend Expedition LE Jogger
Evenflo Aura stroller
To loosen straps, push in the release button on the buckle and
pull up.
Oct 19, 2008 | Evenflo Aura Traditions Travel System...
pull up.
Oct 19, 2008 | Evenflo Aura 3s Co Stroller
I need a replacement safety clip for a Maclaren's techno pushchair
try this website
lots of buckles
Oct 13, 2008 | Jane Powertwin Azulon Stroller
Missing Instruction Manual
https://plweb.evenflo.com/faq_detail.aspx?faqid=4407 the above link is for the manual but here are the instructions. If you have two plastic harness adjusters located on the back of your seat please follow the following steps: On the very bottom of your car seat locate two metal anchors one on each side of the seat, pull the metal anchors out of position and turn them sideways and feed them through to the front of the seat. Release the buckle tongues and chest clip and pull the harness straps to the back of the seat while pushing the chest clips, buckle tongues and harness anchors through to the back of the car seat. NOTE: You may find it easier by pulling down the seat pad when feeding the straps through. All pieces will fit through the harness slots. Choose the appropriate slots for the new harness position. Push the harness anchors, harness straps, buckle tongues and chest clips back through to the front of the seat. Once the straps are completely pulled back through to the front of the seat, make sure the straps are not twisted by clipping the chest clip together and buckling the buckle tongues, then feed the metal anchors through to the bottom of the seat and clip anchors back into place. ********************************************************************* If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of the harness straps must be completed with the baby in the child restraint.
Aug 02, 2007 | Evenflo Embrace
23 people viewed this question
Top The Office Equipment & Supplies Experts
Jerry Greenberg
Jerry Greenberg
old marine
old marine
Mitch Vass
Mitch Vass
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
