Question about Light Office Equipment & Supplies
I have a 2009 dodge journey today my abs,esp,bas,traction control,and brake light came on when I reached 30mph
What do I have to do to fix that
tunde007
  • 2382 Answers
SOURCE: ESP/BAS warning light on. went
Hi, these systems are all linked together. Most commonly, one of the wheel speed sensors is not reading or is reading incorrectly. This can also occur on slippery surfaces where one or more wheel slides enough to cause the sensor to drop the signal, but not enough to meet criteria for an abs or esp episode. If the light comes back every time you turn on the ignition, there is a deeper problem.
The system has detected a fault in the electronic stability program - brake assist system. You have an electrical connection at the rear wheels secured to the inside of the brake area and are viewable from under the vehicle. It is a small wire harness running to each wheel. Grab the connector and wiggle it around, and make sure they are tight. Due to the connector being mounted low to the ground, sometimes they become dirty or corroded, not making contact. Do this on both sides and see if the lights turn off.
If the light does not turn off, you have to replace dynamics sensor, which is mounted UNDERNEATH the center console in the car. There is a "lost communication to dynamics sensor" and "low voltage to dynamics sensor supply"..
Posted on Feb 13, 2011
  • 71 Answers
SOURCE: ABS/ Traction control light/BAS & brake light on in 2008 dodge grand caravan
It is safe to drive. You need a scan tool to get a code out of it. Could be as simple as a wheel speed sensor going bad. All of these lights will work together normally. The traction control uses the ABS to gain traction, and the Brake Assist System is part of the stability control. Also uses the ABS.
Posted on Oct 03, 2012
emissionwiz
  • 79077 Answers
SOURCE: 2008 dodge charger ESP/BAS and traction light on
Have the brakes inspected for worn out brake pads causing a metal to metal scrape of the pad and brake rotor.
Posted on Mar 20, 2014
Terry Corrow
  • 10875 Answers
SOURCE: the esp bas, abs, traction & brake light come on when I drive
take it to a mechanic! the drive train is failing
Posted on Jun 09, 2015
nobody322
  • 20706 Answers
SOURCE: How to turn off eps bas traction control abs lights
is this a hacking question, or how to repair my car?
repairs:
you can't
the ABS is telling you the brakes are failing
what more needs to be said about that?
ABS auto resets each time you turn key off then on.
if it sticks on the operators guide is clear, get it serviced.
Posted on Aug 24, 2015
My dodge journey esp bas light turns on , what does it mean ?
This is an ESP / BAS Trouble Indicator symbol, meaning Electronic Stability Program and Brake Assist System ().These systems work together, and a fault in either or both will cause the light to come on. Have it checked out just go to your local auto supply store like Auto Zone are Advance auto they have a hand held devise that can check it out at no cost. :-)
Apr 15, 2018 | Dodge Journey Cars & Trucks
Bas/esp light is on inmy jeep commander 2006
This video is for a liberty, but all Jeeps should be similiar.
Jeep Liberty How to fix Traction ABS EST Light Codes C1240 C123F Also a guy in a forum says that it might involve a recall of the DCX recall applying to ABS modules on many Chrysler, Dodge, & Jeep products including the Commander. I'd call your dealer and ask, they might fix it for free if it's a recall. http://www.jeepcommander.com/forums/5-general-commander-discussion/1483-esp-bas-traction-control-light-staying.html
Nov 17, 2016 | Jeep Cars & Trucks
What causes brakes to 'stick' when pedal tapped?
the ABS does not cause the brakes to stick, they cause them not to stick so I would have to agree with them on that. Did you ever drive another journey to see if that vehicle had a similar feel to the brakes. It might just be the way the vehicles are?
If the ESP and ABS lights are on than there is likely a problem with the ABS system. The only way to find out what is going on is to scan the ABS system for codes and work from there. Any reputable shop will be able to do this.
Jan 23, 2016 | 2009 Dodge Journey 2.0
The esp bas, abs, traction & brake light come on when I drive
Jun 09, 2015 | 2008 Dodge Grand Caravan
Bas esp light come on 2010 dodge journey
Your Bas & Esp Light is on due to a failing or already failed Bas sensor & Esp Sensor, You can either do it yourself which can be very tricky if you are not confident with automobile repairs. The dealer should be able to do this at a reasonable price as it should take around an hour to do the repairs. If the problem keeps arising there could be a problem elsewhere that is connected to the same area & is shorting out.
I hope this helps.
May 11, 2015 | 2010 Dodge Journey
Traction control light comes on then triggers abs and ESP-BAS light
You need the system scanned by the dealer for stored fault codes.
Apr 12, 2014 | 2009 Jeep Wrangler
Mar 20, 2014 | Dodge Charger Cars & Trucks
My dogde journey esp bas light turns on, what does it mean?
My 2009 jouney is having the same thing the esp and bas lite is on . What to do ?
Dec 21, 2012 | 2010 Dodge Journey 2.4
Oct 03, 2012 | 2008 Dodge Grand Caravan
209 people viewed this question
Top Light Office Equipment & Supplies Experts
Alan Tippett
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Light Office Equipment and Supply Expert? Answer questions, earn points and help others
