Question about Pool & Spa
I have a Canadian spa swift and the pump is beeping with error code E7 can anyone help
    Habit-Forming:
  • 77 Answers
E7 is a DRY heater fault.
Check the following first:
1) Water level - Have you filled the spa with enough water?
2) Filters - Are the filters blocked, when did you last clean/replace the filter?
3) Is the circulation pump running? If you can hear the pump, can you see/feel the water circulating? If you can't feel the water circulating but you can hear the pump, then you may have an air lock within the pump/heater.
Canadian Spa Co. do offer their own repair service for these spas. Basically they collect the faulty pump unit, repair it and then send it back. Although it isn't cheap and you should check the basics first.
Good luck,
Ian Kime.
Posted on May 04, 2017
SOURCE: AR-5132 Error code E7 13
netoiyer les miroire de scanner et la bare blanve
Posted on Dec 19, 2008
SOURCE: sharp ar-m205 error code E7 11
U HAVE TO UPGRADE THE FIRM WARE BY ENTERING SIMULATION 49-1 THE VALUE IS d THEN UPDATE THE FIRM WARE IF U HAVE IT
Posted on Jun 06, 2009
  • 143 Answers
SOURCE: Sharp MX-2700N - Error Code - 'Call for Service E7 - 05'
E7 is only part of the code. It could be a hard drive problem, memory problem, laser problem, or a loose connection on one of the boards.
Posted on Aug 01, 2009
  • 74 Answers
SOURCE: cannon pixma mp145 printer error code e7 & e2
E2: Reload the paper correctly and press [Black] or [Color].
E7: The cartridges are not installed in place.
These are from the manual.
Posted on May 10, 2010
SOURCE: hi have problem with canadian spa
OHS, OH, or SPA TEMP LMT Message There is an "Over Heated Spa" (OHS or OH) Water Condition.
One of the Water Temp Sensors has detected 110°F (43.3°C) Incoming Water Temp and Spa Functions are Disabled. System will Auto Reset when Water Temp is below 108°F (42.2°C). Check for Extended Pump Operation or High Ambient Temp, or contact your Dealer or Service Organization.
Spa Water Cool Down
• In order for the Spa Water Overheat Error Message to Automatically Reset and Clear, the Spa Water Must Cool to below 108°F (42.2°C).
• Check the Topside Panel Display to see if the "OHS", "OH", or "SPA TEMP LMT" Spa Water Overheat Error Message has Cleared. If the Error Message has Not Cleared, the Spa Water is still too Hot to Continue Testing.
• Either Wait for the Spa Water to Cool Below 108°F (42.2°C), or Exit Now and Retest at a Later time.
You can find answers to COMMON SPA MESSAGES at the following website:
COMMON SPA PANEL MESSAGES
Hope this helps.
Posted on Sep 09, 2011
How do I reset my machine. I have Singer 7285q Patchwork. I got a E7 code, and now my machine will not do anything but beep. Help!
Search for:
Make Model error E7
sometimes the owner's manual shows error codes in the troubleshooting section.
Jun 30, 2017 | Singer Sewing Machines
E7 message
A/C Blowing circuit breaker and giving a error code E7 - Heartland ...
https://www.heartlandowners.org/.../24381-A-C-Blowing-circuit-breaker...
May 21, 2011 - 10 posts - ‎4 authors
Has anyone have any idea what could cause this issue? It is a Dometic rear AC with HP and will not cool at all. The fan runs but no cooling at ... Dometic Refrigerator - Error code E-3 - On the road, help ...
Jun 6, 2015
Dometic CCC 2 Error Code E7
Aug 9, 2014
Dometic A/C won't turn on with remote or from unit
Aug 30, 2012
More results from www.heartlandowners.org
Dec 02, 2015 | Heating & Cooling
Error code E7:02 on fisher and Paykel Quicksmart washing machine
consult the user manual from the manufactures website its normally a free download eric
Jul 16, 2014 | Fisher and Paykel Washing Machines
Intex purespa error code
sounds like shorted temp sensor
Jul 13, 2014 | Pool & Spa
PSF error code on my artic spa drifter
pressure switch failure check recirculation pump and filters and pressure switch
Apr 27, 2013 | Qca Spas Majestic Series Aruba Xl Hot Tub
What does error message E6 mean on a prompt set spa #jl017108?
I am having the same problem, not E4 but E6 error code and have to keep resetting it and about 15 min later it start beeping the error code again? Please help
May 21, 2012 | Pool & Spa
What is error code7
Which spa control system do you have?
If it's a Brett Aqualine - E7 = Improper electrical connection
Jan 31, 2012 | Pool & Spa
Hi have problem with canadian spa (balboa mrspa1) control panel digital reading when turned on goes to OH,circulation pump will not run
Spa Water Cool Down
Hope this helps.
Mar 30, 2011 | Balboa Instruments Duplex Digital Panel 2...
Error E7
Hi, before i can help, you need to press the print button and it will show a 'sub code', which will determine the exact fault.
Cheers
Andy
Feb 22, 2008 | Office Equipment & Supplies
Pool & Spa Logo
792 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
