Question about Sharp Televison & Video
White spots on sharp tv - Sharp Televison & Video
I have several white spots appearing like snow on my Sharp 70" screen. How can I correct? Is there a pixel problem with my TV? I have only had TV for over 2 years.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/. Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jan 01, 2017 | Sharp Televison & Video
I have a Sharpe LC-60LE600U. The power went out on it. What power board works on that TV. The lower left hand corner has a black spot, too. Will the power board fix the black spot as well?
Power Board wil not fix black spot. the spot is caused from lamp failure. Led strip has at least one LED out, takes out the whole section. Go into trouble shooting to verify. After so many start ups with the black spot, the TV will not turn on in TV mode.
Sep 22, 2016 | Sharp Aquos Televison & Video
Anyone knows where white spots on the screen along the bottom of the tv screen can be coming from
The spots are part of the transmitted signal. Normally they are masked so you don't see them.
Aug 16, 2016 | Sharp LC 70SQ15U 70 inch Aquos 1080p
To remove a black spot on a old sharp model TV?
1,white spots appeared on screen,means the DMD chip is broken,you need a new DMD chip.
we supply the new DMD chip,it's life is 6 years,
and the price is USD190
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Apr 30, 2014 | Sharp 4500HRS ECO/3K HRS STANDARD 180W...
I am using Sharp multimedia projector XR-32S-L.There are white spots in the screen. What should I do to remove it?
white spot in image is comman problem of dmd chip it is fixed in to light engieen with heat sink replacment can possiable by expert
Mar 30, 2014 | Sharp XR-10X Multimedia Projector
I have white spots on my image from my projector SHARP XR-55X?
1,white spots appeared on screen,means the DMD is broken,you need a new DMD. USD200
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Oct 05, 2013 | SHARP ELECTRONICS CORP PROJECTOR, SHARP...
Sharp lcd tv problems
screen driver fault. or screen cable fault would need to be check before. check screen driver on the back of the screen un plug it and give it a clean..
Oct 01, 2013 | Sharp Televison & Video
My DLP617W is black and white today and tried everything I know, does not work. Any suggestions ? Thank you.
i'm probably sure that is the dmd let me know a couple of things.
TV make's were noises? the white spots comes and go?
it look like this?
Dec 28, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Televison & Video Logo
24 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
