Question about Rainbow Vacuums
I was vacuuming the house and the rainbow just shut off what is it and can I reset it
3 Suggested Answers
  • 11 Answers
SOURCE: Rainbow Model e Series will not start. Where is the reset button on this vaccum?
There is no reset button on the canister. It may be a bad power switch, a power cord, or the button that presses in when you put the water basin in place may be bad - or the prong on the water basin that pushes that button in when you place the canister on the basin may be broken off.
Posted on Jul 03, 2009
  • 11 Answers
SOURCE: can not get the housing off
Remove the 4 screws on the bottom of the canister, and also carefully remove the water basin gasket. You will reattach the gasket with rubber contact cement when you're finished with your repair/cleaning.
Rainbow turns on for a second or two then quits and won't turn back on.
If you have the model Rainbow E-2 eSERIES then the Motor Rainbow 120v could be going bad. This will trip the auto reset until it cools down.
If you have an E2 Type 12 Rainbow, then the Controller Asm 120v e2 Silver Gold could be going bad.
Our technical support team is available if you need... Contact Us
RainVac
Mar 24, 2016 | Rainbow E series Canister Wet/Dry Vacuum
My rainbow stop working.no red lights.3 times try to start and then switch off by itself.what should I do?
PDF]3 - Rainbow
rainbowsystem.com/.../Rainbow_e2_2011_R14449A-1_English_P...
RexairAs part of Rexair's Customer Care program, each Rainbow and Power Nozzle receives a ... If the Rainbow is not working ... Do not clean the unit or unclog the hose until theRainbow is switched off and the plug is removed from the wall ..... alone or with the Jet Brush attached. ..... The Power Nozzle brush is stopped and.
My Rainbow Vacuum Cleaner Won't Turn On ' eHow
Rainbow keeps shutting off Vacuums Questions & Answers ...www.fixya.com > Forum > Tags > keeps shutting off > VacuumsRainbow vacuums keeps shutting off related questions and answers. ... My Rainbowstopped running I was using the Rainbow and it stopped running. ... the switch . my electrolux has the same problem but wont always turn on.so it probably is ...Three common problems with Power Nozzles and how to fix ...
Dec 03, 2015 | Rainbow Vacuums
My rainbow stopped working while im shampooing
If the water gets to high in the water pan, then the motor will start hitting it and will make it off balance. This will cause the motor to shut off to protect itself. Wait about an hour for the motor to reset.
Our tech. team is available if needed... Contact Us
RainVac
Jun 16, 2014 | Rainbow E series Canister Wet/Dry Vacuum
Reset button on Rainbow vacuum
There is not a reset button on this model
Apr 01, 2014 | Rainbow E series Canister Wet/Dry Vacuum
E series Canister Wet/Dry Vacuum: My tank foamed up into the motor and now the rainb...
Hi, there is no reset button on a Rainbow vacuum. There is a safety switch on all E series and E2 series Rainbow vacuums, that keep it from running without the water basin on it.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
May 17, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow Overflow .. HELP
Thank you,
Ralph
One other thing, water sucking through your vacuum should not hurt it. It is not good though, but will not make it not run.
Thank you again,
Ralph
Apr 21, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Can not get the housing off
May 05, 2009 | Rainbow Technologies D4 Bagless Vacuum
Rainbow vacuum unplugged during use and now won't work.
Sounds like you pulled the cord out check the housing and make sure it the cord is still connected
Jan 24, 2009 | Rainbow E series Canister Wet/Dry Vacuum
My Rainbow stopped running
did you ever find out the problem with your rainbow? Mine did the same thing today- turned on the switch yet nothing happened. Think it needs a new switch???? Do you know how to get canister apart after taking out first screws?
Jun 29, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Vacuums Logo
104 people viewed this question
Top Rainbow Vacuums Experts
Jim Parker
Jim Parker
Chris Nomland
Chris Nomland
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
