Question about Sony PlayStation Portable (PSP) Console
My joystick is not working normally as it use to be.
Im having a problem with the anolog joystick on my psp.It sticks and makes it hard to operate.Also when you go to any screen where you have to pick a level or put your name in,the icon just jumps around.Is this a related problem with the joystick,or do i have another problem.I took the face off and removed the joystick and turned the psp on and it still does the same thing.
I know how to solve this so worry not! here's the solution:
1:your joystick may have a little part that is dismembered so buy a new one
2:ask for a assistant to open your psp to put the joystick properly
3:I have the same problem so here's what I do.
good luck
Posted on Jul 25, 2009
2 Suggested Answers
SOURCE: psp joystick problems
my psp have a problem on joystick the X and O was change,the one X was operating cancel mode and the O it was a ok.mode.
what will i do?
Posted on Aug 04, 2008
My psp anolog stick is not working when i try to move it up+left what do i do
To calibrate your analog stick, go to the system information screen on your psp, and move your analog stick around in a circle as far out as possible.
May 17, 2011 | Sony PlayStation Portable (PSP) Console
PSP analog stick LBP
u sure it is compadable with the anolog stick? some games you can only use the pad
Nov 26, 2009 | Sony PlayStation Portable (PSP) Console
I HAVE A PSP 1001 THE DOWN BUTTON KEEPS REPEATING. i HAVE REPLACED THE ANOLOG JOYSTICK AND CLEANED ALL THE BUTTON CONNECTIONS.
You don't have to capitalize everything, this can be seen as screaming.
Check if the rubber under cursors is placed the right way.
Check also if you did'nt make a chortcut while cleaning it.
Succes.
Sep 11, 2009 | Sony PlayStation Portable (PSP) Console
PSP joystick won´t work
It should work fine without it. Make sure you keep that little clear rubber part safe. It's what fills the gap between the analog stick and the motherboard on the PSP
Jun 16, 2009 | Sony PSP (Piano Black)
My new installed psp analog stick doesn't work
most of the time when you think that your joystick is messing up its really just the psp's motherboard that is messing up.
choices=get a new motherboard or get a new psp
Feb 05, 2009 | Sony PlayStation Portable (PSP) Console
PSP Not Loading
just remove the battery and memory stick and try it on another psp if the same problem occurs the problem it is because of the memory
Sep 15, 2008 | Sony PlayStation Portable (PSP) Console
PSP analog stick help???
YOU HAVE TO TAKE IT TO SHOP AND TELL THEM THEY WILL GIVE U ANEW ANOLOG AND THEY WILL FIT IT IN FOR U ITS THE ANOLOG OK AND CHILL OK TAKE A DEEP BREATH AND CHILL CALM IT ALWAYS HAPPENS TO ME WHEN SOMETHING GOES WRONG
Jul 01, 2008 | Sony PlayStation Portable (PSP) Console
Psp joystick problems
Good day all
I recently ran into this same problem of a PSP joystick "jumping" or hopping around. Since I'm an electronics engineer I was determined to get to the bottom of this annoying problem, I read all the posts on the site and none helped, but the problem turned out to be much easier fixed than I first anticipated.
First of all I assume that you know how to take the PSP apart and take out the joystick module as well. The Joystick module connects to the PSP mainboard by means of 4 contacts, seperated by a spacer conductor that appears like a rectangular rubber, be careful not to lose this during the process.
Here is why the problem occurs, when you have a faulty joystick module, one or more of those 4 contacts don't connect to the main board anymore, so the when the PSP is trying to measure the resistance to determine the joystick position, it reads a varying value, i.e. the contact is floating.
This happens for mainly 2 reasons, dirt or a faulty module, as stated in the previous posts, the contacts could be dirty, but this can usually easy be seen, and this wasn't the problem in my case, I had a faulty module, but luckily all is not lost.
Here's how to fix a faulty module in most cases. Remove the joystick module from the PSP completely, put that little rectangular rubber on the 4 contacts (clear in my case) aside and keep it safe. There is metal clasp on the bottom of the module, you can simply pop it off with a screwdriver, by slightly bending the clasps on the side and taking it off. Now you should be able to see a VERY SIMPLE mini circuit board with tracks on, on the bottom of the module, you can indeed pop this off too. On this you will see tracks where the joystick sliders move. Put the circuit board aside too. Now look at the now completely open joystick module, you will see the two sliders each having a metal part, each of these metal parts has 2 very small contacts that run on the circuit board tracks that you just removed, most times these small contacts get bent inward and they can't make contact with the circuit board tracks anymore. Just bend them slightly outward again, so that when you put circuit board back, they touch the tracks on the board nicely. Put the circuit board back, it just slips back on, put the metal clasp back, put the rubber back in over 4 contacts on the module and voila, if all goes well you will have a nice working joystick module again. Put it back in the PSP and test it to see if it worked. In my case it worked 100% and saved me a few bucks. Hope this helps everyone. Let me know if it worked.
Oct 16, 2007 | Sony PlayStation Portable (PSP) Console
Psp anolog stick
replacement pack should fix that, but did the stick fell itself or ur psp fell? Also u can try to open psp and clean, i had similar problem just cleaned and it helped
Oct 05, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
205 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
