Question about Frigidaire Dryers
Need Control board for 134748900 0604 frigidaire electric dryer
    Sergeant:
  • 232 Answers
If you can't find a board, you might try www.fixyourboard.com
You mail them your board, they fix and return with 1 year warranty. Saved my bacon on a 20-year old GE Wall oven.
Posted on Apr 23, 2017
  • 1003 Answers
SOURCE: Frigidaire Washer - pressure sensor
I WOULD SAY REPLACE THE PRESSURE SENSOR IF BOTH CONTROL BOARDS HAVE BEEN REPLACED
THE MOST ECONOMICAL PART ASSOCIATED WITH THE CONTROL BOARDS ESPECIALLY AFTER HAVING ELECTRICAL PROBLEMS IS MORE THAN LIKELY THE PRESSURE SENSOR it may have BLOWN ALSO
Posted on Jan 31, 2008
dragonsthatk
  • 547 Answers
SOURCE: FRIGIDAIRE AFFINITY ELECTRIC DRYER NOT STOPPED HEATING
eleiment
Posted on Feb 18, 2009
jumptrout51
  • 3361 Answers
SOURCE: Replacing Control Board on Frigidaire model LEQ1442ES0 Dryer
There should be screws on the back side of the top panel that come out. Then the panel will slide out so that you can access the front controls.
Posted on Aug 18, 2009
  • 1531 Answers
SOURCE: have a frigidaire affinity electric dryer that doesn,t heat
check your heating element or the thermal fuses located on the back wall the side of the heating element can and the plastic blower ducting
Posted on Sep 17, 2009
heatman101
  • 43501 Answers
SOURCE: my frigidaire electric dryer wont heat up, only
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 14, 2010
Hi there I have one trouble, I have my kitchen frigidaire gallery but I have on problem with the control board I lost the diagram the part number is 316088182, any one know how I cant connect the colo
Thank you for your inquiry, friend!
I see you need to install part 316088182 inside of your Frigidaire dryer. If you need additional assistance with installing parts I would suggest seeking help from a professional technician for proper installation. Some of these electrical components are intricate and incorrect placement could lead to possible harm. I hope this helps. -Matt
Oct 19, 2014 | Frigidaire Gallery Dryer Control Board...
Why can't I get my new control board for my Frigidaire affinity dryer to work?
Hey tim bryant, thanks for your post!
I understand that you have installed a new board inside of your Frigidaire dryer, AEQ6000ES2, and on the new board the lights blink. I would recommend a reset on your appliance which can be done by disconnecting the power to it for roughly ten minutes. If that step does not correct the issue I would seek professional assistance for the repair of your dryer. I hope that is helpful. -Matt
Aug 13, 2014 | Frigidaire AEQ6000ES Electric Dryer
Frigidaire Affinity Error Code 61
Hello - Could the error code possibly be an EB1? If so, it is recommended for the power company to check the frequency of the incoming power to the washer. If it proves to be correct, then the main control board may need replacing.
Nov 20, 2012 | Frigidaire Electric Dryer
Touch Panel Control Shorting Keys
I would check out the UK WHICH website.
Aug 28, 2012 | Frigidaire GLEQ2152ES Electric Dryer
I have a frigidaire gallery series front loading electric dryer model # 134509400c.press start and it beeps with a dr code.any idea what is causing this?
dr is door error
this generation of dryer has alot of control board failures(the relay for the heat burns the terminals for the wires you can inspect these relay connection visably by removing the front control panel you might want to try setting the machine to the fluff/air dry setting and try starting the dryer, if it starts in air fluff you need to check the connections on that relay this is not a factory taught test.its just something a customer pointed out one time and i have tried on many after the fact, and for whatever reason these machines will still run in fluff mode when the board is fried
Oct 22, 2011 | Frigidaire Electric Dryer
Frigidaire Affinity Electric dryer E68 error. dries clothes fine, then error light comes on later- after dryer has been off. Will not start unless unplugged for period of time.
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Sep 15, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Aug 18, 2009 | Frigidaire FEQ1442ES Electric Dryer
Dryer will not run
dryer starts sometimes if you hold in button. frigidaire gallery series model # GLEQ942CSO. serial # XD350164472. flat panel control board.
Mar 31, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
29 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
