4 Suggested Answers
Ian  Hot Tub
  • 77 Answers
SOURCE: my hottub want raise the temp above 89 on the
Some hot tub keypads have a 'mode' button. If yours doesn't try pressing 'warm/temp' followed by 'Jets'..... it's usually a combination of keys that changes the mode and this one springs to mind but I could be wrong.
Good luck,
Ian, from:
Posted on Jun 18, 2010
SOURCE: I have a 18000btu LG
Hello.I think they are on to something with shortcycling on temp sensor.I think it should be sampling the return air instead of (inside coils ?).A 2*f dead band use to be built in (factory installed) to thermostats to prevent on/off, but not sure in this case.Try a new sensor location(return air) and see if anything changes.
Posted on Oct 26, 2010
SOURCE: my white rodgers control panel
Water heater and gas valve are not clear:
Add a comment with description of water heater and gas valve for possible help.
Open following link for White Rodgers intelli-vent gas valve thermostat:
1) Typical instructions for Kenmore and AO Smith water heater with Intelli-vent say:
Set on-off switch to ON position.
Hold down both arrow buttons for 1 second.
Then press hotter button.
2) Also check that 120Volt electrical outlet has power, and check outlet with cheap circuit analyzer from home center.
3) If Intelli-vent gas valve thermostat is malfunctioning, and won't reset, then contact manufacturer of water heater for replacement gas valve.
Label on side of tank will have Model number, manufacturer, type of gas LP NG, serial number for part ordering.
Add a comment for more help.
Posted on Jun 14, 2011
Older leisure bay tub. only a few buttons on topside panel work as they should. temp control buttons switch from economy to standard,cant raise or lower temp. Topside panel or control board?
Top side control. 90% sure by your description of problem. Buy the topside, plug it in and try it before you do full install. If it doesn't work you can return it. Most places won't take back a PC Board.
Apr 25, 2017 | Leisure Pool & Spa
Tub won't heat Message SL
Not much info here but SL could be the mode setting. Typically modes are SLEEP, ECONOMY and STANDARD. Standard maintains your set temp at all times even if it has to turn on outside of normal filtration cycle. Economy only heats during a filtration cycle, and sleep will only heat within 10 degrees of set temp and only in filtration cycle. This cycle is really only useful while going on vacation or other extended periods of non-use. Not sure how to help change modes without knowing what spa pack you have but you should be able to find the owners manual on line with a little research.
Mar 02, 2017 | Pool & Spa
Time and vacation symbol flash-all buttons non responsive - how do I fix
Hello there,
Are you SURE the floor temp sensor is wired correctly Page 8 of the Manual ???? It should be across 1 and 2 . if it was on the number 2 and 3 connections, this would simulate a 'remote switch' check the wiring of the floor sensor carefully in the back of the unit.
Something odd about the 'Vacation'mode' setting. You said it has no remote switch but only this 'remote switch' can disable it. by going open circuit. which sounds suspiciously like something is across pins 2 and 3
Time flashing is 'Temporary override'
Read page 16 AND 17 (flashing as you say) of the user manual
Click literature and download.
Sep 22, 2014 | Honeywell Aube TH115-AF-GA 7-Day...
Hi I have pressed the vacation button on my side by side refrigerator/freezer as we are going away for 8 weeks. The display has lit up but there is no difference in the way the fridge is operating - same...
The settings will reset to a lower settting as the fridge/freezer will not be disturbed . So wait for the fridge to run and shut down and it will continue to run in this low mode to save power but to keep the food in prime condition. The fridge alone will not be shut down.
Aug 31, 2011 | Samsung SRS20DTD Side by Side Refrigerator
Purchased a couple of months ago. No problems with operation or cooling. Does a great job of colling the room and even risidual rooms on that level. Turned unit off while on vacation for one week. Upon...
When the environmental temperature is lower than the set range, the display will indicate "LO".
Lowering the temperature you have it set on, should resolve the problem.
Hope this helped you and thanks for choosing FixYa.
Aug 21, 2011 | Haier CPRB07XC7 Portable Air Conditioner
Changed water filter and bushed lock & water buttons, red light went off but green light and other indicator lights (crushed ice, cubes, night light) did not work. Removed new filter & put . .back...
Below are instructions to reset water filter light. Thanks, Sea Breeze
If helpful please rate.
Reset Filter (select models)
When a water filter has been installed in the
refrigerator, the yellow Order light will illuminate when
90 percent of the volume of water for which the filter is
rated has passed through the filter OR 11 months have
elapsed since the filter has been installed.
The red Replace light will illuminate when the rated
volume of water has passed through the filter OR 12
months have elapsed since the filter was installed. A
new filter should be installed immediately when the
Replace light is illuminated.
After replacing the filter, press and hold the Reset
Filter pad for three seconds. The Order and Replace
lights will go off.
Vacation Mode
The Vacation Mode feature causes the freezer
to defrost less frequently, conserving energy. The
Vacation Mode indicator light will illuminate when the
feature is activated. To deactivate, press the Vacation
Mode pad again OR open either door. The indicator
light will go off.
Temp Alarm
Apr 22, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Power vent 50 gal tank flashing code 2-3
1. Turn off power vent blower and set water heater temp to vacation (lowest temp)
2. Turn on power vent blower
3. Turn the water heater temp from vacation (lowest temp) to hot (highest temp) four times.
4. Set the water heater temp to normal
Aug 21, 2009 | Rheem Water Heaters
Vacation button keeps on activated(refrigerator Samsung SRS20NTC)
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Set to regular temp then lock functions.
Freezer temp + fridge temp for 3-8 sec to lock function
Dec 13, 2008 | Samsung SRS20DTD Side by Side Refrigerator
Coolant temp. raising. no coolant loss.
first with the car off and cool squeeze bottom radiator hose with your hand then do the top,this burps any air out of the system,of course have the cap open,if this doesnt solve the problem its your radiator cores are block as you speed up its trying to force coolant thru a blocked core and temperature rises,you can pull your raidiator and have it cored at a radiator shop,cheeper than buying new
Jul 07, 2008 | 1999 Cadillac DeVille
Televison & Video Logo
Top Televison & Video Experts
