Question about Miele Washing Machines
Miele Cerami is unfamiliar to me. Two front eyes will not turn off. Others operate correctly. Checked model plate : shown. Does it have rheostats that could be causing the problem? Seeking partsCarol
2 Suggested Answers
SOURCE: crystal eye webcam will work on some chat sites but not others HELP!!!
Pls tel me the model? also is this the first time it is happening?
Posted on Feb 15, 2012
Can a replacement stir rheostat be purchased for a fisher scientific hot/ stir plate model 11-500-4sh.
The value of the rheostat will part of the numbers on the metal case. You should be able to get ons from Radio shack or online.
Aug 11, 2016 | Kitchen Appliances - Others
Is there anew model that uses a 2 screw side plate instead of a 3 screw with larger dia. yoke screw
If you wish to get some details About microwave Oven working and troubleshooting ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
May 22, 2016 | In Microwave Ovens
How do I set the clock on the Miele oven?
I don't believe this model has a clock feature - just cooking timer. I checked through the operation manual and did not find any indication of a clock function. The manual is available here:
http://www.mieleusa.com/manuals_pdf/Residential/Ovens/H350-2_us.pdf
Mar 15, 2011 | Miele Novotronic H350-2B Electric Single...
The check drain and check inlet lights are flashing constantly on my miele w 2240 washing machine
I have a Miele W502.
Both lights flashing usually is caused by a water leak into the case of the machine which trips the float switch in the base. You can reset this by tipping the machine forwards at 45 degrees and allowing the water to drain out on to the floor. It will reset everything but if you still have a leak it will trip ou again due to the float switch.
I had the same problem with the 2 red lights flashing, which was fixed by emptying the float tray as above.
On further investigation I found that the door seal had rubbed on itself at the 6 o'clock position and had worn a small hole which was causing the water leak.
To replace or repair the Door Seal you will need to remove the front panel.
1. Turn power off and unplug machine after opening door.
2. Remove the front panel lower kick plate by inserting a thin ruler between the kick plate and front panel about 4 inches from each end and lever down until it releases.
3. Remove the 2 screws at the door lock switch on the front panel.
4. With the kick plate removed you will see 2 screws at each lower edge of the front panel, remove these 4 screws.
5. Remove the spring loaded band from around the edge of the door seal facing you and after that release the seal from the front panel and push in.
6. Remove the hex bolt from the 6 o'clock position just below the door seal on the front panel.
7. You should now be able to lower the front panel out of the locating pins and remove it.
8. With front panel removed you will be able to remove the tensioning band which holds the door seal in place around the drum by undoing the screw at the right hand side of the band at the 3 o'clock position. It is accessible from above with a long bladed screwdriver. Take note of how far it is tensioned on the thread of the screw and try not to undo it all the way or you may lose the nut on the band.
9. Once you have removed the band, slip the seal off the drum and slide the water outlet to the seal from the dispenser.
10. When you replace the seal do not do the tensioning band up too tightly or you will hear it squeak when you spin the drum in either direction.
11.Reassembly is the reverse of removal, taking care to put the door manual release strap through the inner slot in the front panel.
I repaired my door seal with Silicone Sealant and loose weave fabric tape after rubbing it clean with alcohol as i didn't want to pay $100 for a new seal from Miele.
Feb 09, 2011 | Miele W2240 Front Load Washer
Miele G892SCB intake/drain light on. removed a piece of glass but rubber peice in non-return valve is broken. Continues not to clean or drain. Can we order a new NON-RETURN VALVE. DW is 7...
Yes. 1 800 843 7231. follow the prompts to get to the parts department. have your model and serial number handy. They will get you the correct part. If you have any problems getting it in, or it doesnt solve your problem, repost. I will keep an eye out.
Nov 20, 2010 | Miele Dishwashers
How to thread the needle
You will find a vast array of threading diagrams at the link HERE
Without the model number I cannit be more specific.
If your model is not shown, tale a look at the others for one that is similar.....there really is not a lot of difference from one to another once you see the logic of the thread being
1. Directed from the spool to the .... 2. Tension Unit, then a 3. Length pulled by the take-up arm, 4. Held and then directed 5. Through the needle eye
Hope you have some joy with this.....it is probably all outlined in your Instruction Manual too
Regards
Martyn Bargainbox
Jul 30, 2009 | White Sewing Sewing Machines
Will not pick up bobbin thread
Unusual for this machine. Check to be sure the needle is inserted with the flat side to the back of the machine. If it is, remove the needle plate, bobbin and bobbin case. Turn the hand wheel slowly toward you and see if the point of the hook is above or below the eye of the needle when the hook point is aligned behind the needle. If the eye is above the point of the hook the machine is out of time and best taken to qualified technician.
Jul 04, 2009 | Janome 6019QC Mechanical Sewing Machine
Miele KM 320 G gas cooktop ignitor
I had a similar problem and discovered that the control knob had fried itself, most likely due to liquid penetration down the shaft of the control knob and into the control knob electronics. Inside is a printed circuit board with resistor, diode and a rheostat. The surface of the board was charred beyond repair.
To trouble shoot the problem, open the cook top and hook the burner in question to one of the known good control knobs. If it ignites, then it is the control knob electronics. If it doesn’t, then there is something wrong with the igniter.
Note: The 2-zone Wok Burner had a different control knob that the other burners.
To open the cook top, do NOT loosen any of the Phillips screws on the sides. Here are the instructions from the user manual:
Disassembly
Shut off gas supply, disconnect the manifold pipe, disconnect the electrical power. Remove pan supports, burner heads and burner rings. Remove control knobs.
In the event that the hob is built in, undo the bracket clamps underneath the work surface. Lift the hob on to the work surface. Unscrew the venturis on the high-speed and super high-speed burners using a 20 mm wrench. Lift and remove the burner rings and burner base plates. Disconnect the wires from the ignition plugs. Keep the wire from dropping into the undertray by inserting it in one of the slots in the burner supports.
Remove the three screws securing the dual ring wok burner. Remove the wok burner base plate. Lift the ceramic tray from the hob.
Note: Each regulator shaft is equipped with a black ring. This ring may cling to the rubber seal in the ceramic tray. Check and remove the rings from the rubber seals.
To order parts, call 1-800-245-8215, 8:30 AM to 5:00 PM EST
Mar 04, 2009 | Miele 35 in. KM326G Gas Cooktop
Leaking water out of front vent when opened
Hi jpkenney, The vent can be replaced. If you open the door and look around the outside of the door, you will see the stainless screws that hold the top & bottom parts of the door on.( the top control section is separate to the rest of the door). Just undo the screws & there you have it. The vent can be replaced easily. Hope this helps.....goodluck.
Jul 29, 2007 | Miele 24 in. G881SCI Built-in Dishwasher
Washing Machines Logo
46 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
