Question about Garden
Is there a primer on the 22" model247,37237 - Garden
The primer bulb doesn't fill with gas
sounds like you hasve a cracked fuel line or a cracked primer bulb. that is why it cant prime.
Aug 29, 2015 | Swisher 190cc 22" String Trimmer Mower...
Primer pump lacation
Not all mowers use this feature to start their fuel flowing. Try using choke for 2-3 pulls, and reduce to half-choke if it starts. If all else fails, make sure it's not flooded by opening up the throttle for a few pulls.
May 06, 2014 | Poulan Pro 22" Self Propelled High Wheel...
Where is the primer ball
It may not have a primer ball. If it does, it would be attached to the carberator. If it starts, but won't stay running, that could mean your carberator needs to be cleaned/serviced.
May 29, 2012 | Mtd 22" Yard Machine Push Mower
Toro 22" cut starts. to
a hole in the primer bulb or gas line it could be a pin hole right in the primer bulb itself and when you hold the bulb you might be holding the hole itself which keeps it running....
Jul 14, 2011 | Garden
Re: primer button
When posting please indicate the model number if you are asking about an engine part. If its Briggs and about 4.5 hp ,there is a tab on either side of the primer and that releases the primer. Smaller engines are held in with a metal ring
Sep 25, 2009 | Mtd 22" Yard Machine Push Mower
Primer button
most primer are held in by a spring just use a small screwdriver slide it down besidfe the button and pry the spring out slowly
Jan 16, 2018 | Mtd 22" Yard Machine Push Mower
Won't stay running
these carb /air filter housing gaskets were notorious for warping? there are 2 screws behind the air cleaner remove those and disconnect the throttle cable pull the black square housing off and replace the gasket with a rubber one from local mower shop?
Aug 27, 2009 | Poulan Pro 22" Self Propelled High Wheel...
When I put in gas the gas flows out of the primer pump. Got this becasuse someone did not want it. Now I understand.
The primer plunger will have to be replaced. Some of them have an o-ring on the back of plunger that holds it in place.
Jul 09, 2009 | Mtd 22" Yard Machine Push Mower
Lawn mower will not start and run
Sounds like a clogged carb or a cracked primer bulb. I would install a carb rebuild kit and new primer bulb if your mower uses one.
May 18, 2009 | Craftsman Garden
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
