Question about Sewing Machines
What is wrong when the underside of embroidery has bunched thread
Have we designer se
    Sergeant:
  • Sewing Machines Expert
  • 248 Answers
Hello
The bunched-up thread on the underside is the needle thread. Check that the upper thread is threaded correctly, passing through all the required thread guides and that the thread is securely lodged in the tension assembly ... there should be reasonable tension when upper thread being pulled by hand.
Also check that:
- there are no 'dust bunnies' or a piece of thread hiding in the tension assembly, and that
- the needle is inserted correctly and that it is a system 130/705H Embroidery needle.
Happy Stitching
Sewingirl/
Posted on Apr 24, 2017
Having trouble with tension on my Husqvarna Viking E 20
Be sure to RAISE the presser foot BEFORE threading the upper thread. (Remove the upper thread and rethread from the beginning.) Upper thread malfunctions commonly occur if it is not threaded correctly or the thread is not seated in the tension disk properly.
Install a brand new needle if you haven't already done so.
If it continues, this information about bird nesting could be helpful:
Sewing Machine Thread Bunching Up Here Why
Why Do Get Bunched Up Thread Under My Fabric
8 Tips to Fix Birdnesting in Embroidery
Why Is the Thread Getting Tangled Up Under My Material When Use My Sewing...
Jan 22, 2016 | Husqvarna Sewing Machines
Birds nests embroidering husqvarna viking designer se
sounds very much like insufficient needle tension
Feb 01, 2014 | Sewing Machines
Distorted embroidery with Designer SE
have you tried changing the needle
try rethreading the machine top & bottom
also clean under needle plate area & bobbin area for loose threads & lint
Jan 27, 2012 | Husqvarna Designer I
Brother embroidery machine broken
make sure the bobbin thread is wound and installed correctly
remove tangled thread and clean lint out from under feed plate
clean and remove shuttle to clean out area with lint brush
inspect bobbin for burs and scratches...make sure when reinstalling shuttle and bobbin that it rotates freely
hope this helps
Feb 04, 2010 | Brother SE-270D Computerized Sewing...
Thread wad on undersurface
machine not threaded properly? wadding thread underside means upper thread does not have tension.
Jun 30, 2009 | Brother SE-270D Computerized Sewing...
Embroidery sewing machine stopped working
I am not sure what you mean: motor runs but nothing else moves?
Have you have turned the machine off and tried again? Like computers, sometimes they need rebooted.
More information is needed to evaluate further.
Dec 29, 2008 | Husqvarna Designer I
Brother Embroidery machine thread keeps breaking
It doesn't matter so much the thickness of the stabilizer but more a matter of it being taut like a drum and the proper stabilizer for the fabric you're using. Couple of reasons the thread breaks...the thread gets caught on the edge of the spool in the crack where the thread originally starts, you're not using the right size spool cap or the upper thread is wrapping around the spool pin. When I use my 170 for embroidering I always use the vertical spool pin to eliminate this problem. Try it and let me know how you make out.
Nov 18, 2008 | Bernina Artista 180
the needle thread tension is wrong
bunching up under the material indicates that it is too loose
Nov 17, 2017 | Sewing Machines
Machine embroidery
You should always use proper Bobbin Thread for embroidery - not a bobbin wound from regular dressmaking thread. You are right, the special bobbin thread is thinner so that the embroidery thread will be pulled to the underside and you get a nice shiny embroidery on top with no bobbin showing through. Wind yourself 6 or more bobbins at a time of bobbin thread to always have some on hand, or buy the pre-wound L size ones.
All embroidery machines - no matter what brand - recommend using bobbin thread for embroidery. It is readily available at all sewing stores, probably even Spotlight would carry some. If you get stuck for a supply, try overlocker thread.
Dec 04, 2007 | Husqvarna Designer I
Sewing Machines Logo
27 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
