Question about Sewing Machines
Elma supermatic balls up under machine after a few stiches
  • Sewing Machines Master
  • 12,241 Answers
Thread nests (also called bird nests).
Remove the top thread.
ALWAYS RAISE the presser foot and rethread from the beginning.
Birds nest under the fabric big loops of thread top side looks good...
What causes Bird Nests Superior Threads
Posted on Apr 23, 2017
My double discs no longer work on me Elan Supermatic sewing machine
Are you sure you have the settings right on the machine? It can be a little unintuitive with these old Swiss beauties. Start by checking the disc is fully clicked into the Elnagraph, there is a little finger underneath which marries up with a hole in the disc. Now turn the dial in front of the elnagraph to A, the automatic setting. Now turn the stitch length dial to the straight line and the stitch width to A also.
There were a few variants of the supermatic and I have descibed the last one the Star Series, this machine is white with blue top. But I have got a manual for the earlier green supermatic as well so could drag this out if you havent resolved the problem. I do find that any machine left for a while unused may,suffer from loss of needle swing, the needle bar bearing gets funked up. Can be worked loose with Triflow and gentle wiggling. The bar bearing slides across on a shiny metal rod and is,pulled back to centre by a spring, so,this could also have broken,or come off.
Sep 25, 2014 | Elna Sewing Machines
1960s Elna Supermatic - lower thread only catches sometimes
Make sure you have the correct needles for this machine and that it is fully inserted into the needle bar and correctly oriented.
Mar 20, 2013 | Sewing Machines
My machine is baby lock.it suddenly got a problem.it is: it sews a few stiches and stops and it goes on like this
here are some suggestions, if the suggstions don't help then it
would be a good idea to have the machine check to see if something
in wrong with the computer part of the machine
1. change the needle--make sure it's the right needle for the fabric
2. rethread the machine top & bobbin,,make sure to use every
thread guide
3. make sure the bobbin is turned the right way in the bobbin case
4. clean under the needle plate & in the bobbin area for lint
Oct 12, 2012 | Baby Lock Sewing Machines
After one or two stiches the thread balls up on the bottom and the needle unthreads.
suggestions
put in a new needle
check your top thread tension
clean the bobbin of lint & loose threads
Aug 01, 2011 | Singer Pixie Plus Sewing Machine
I am sewing swimsut material and the machine is skipping some stiches.
Usually you use a ball point needle and stretch the material as you sew. Another trick is to us tissue paper under your fabric.
Apr 21, 2011 | Kenmore Sewing Machines
I have a singer model 2200 inspo\iration sewing machine. The top stich sews perfect, but the bottom stich balls up.
Totally rethread your machine, then check your needle, put in new one if you haven't changed it in awhile or not sure if it is bent. Usually it is in the top threading for problems underneath. Also, make sure that you are using the same weight of thread top and bottom or else you can have problems. Good luck
Sep 26, 2010 | Sewing Machines
White 1760 skips stiches...
Change your needle and use a ball point.
Feb 28, 2009 | White Sewing 1766 Mechanical Sewing...
Singer 533 missing stiches
Replace your sharp needle, code 2020, with a ball point needle, code 2045. This usually solves the problem. You can also put "Stitch and Tear" at the bottom to help stabilize the material. If you can do not have Stitch and Tear, try a piece of tissue paper for the short term.
Dec 22, 2008 | Singer 7462 Mechanical Sewing Machine
Sewing machine not making stiches
At first, my machine was getting all tangled under the fabric and then would stop working because it was tangled in the bobbin area. Now the bobbin area is staying clear but there are no stiches being made. I have no idea what to do. melissashulga@yahoo.com
Sep 07, 2008 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
41 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
