Bad static on TV Ears when hooked up to a dish satalite reciver
Nitrotrike
  • 589 Answers
SOURCE: CODES
Your codes can be found here:
http://www.remotecodelist.com/remotes/jensen/JR300C.pdf
Posted on Jan 10, 2008
SOURCE: TV won't work with rabbit ears
You must change the input on the system to be AIR/Antenna , the way it was before was set to cable/dish/DTV.
The tv sees the input different.
Posted on Jun 08, 2008
  • 10 Answers
SOURCE: How do I hook up my Dish Satelite to it?
should go from your satellite to dish box might say sat on bck of box then the next [connection think says tv that should go to tv itsself or dvd vcr whatever ur hooking up to it then from that point hook it to ur tv
Posted on Oct 23, 2008
bestdarngood
  • 3037 Answers
SOURCE: cancelled dish & hooked up rabbit ears. no local channels
Digital channels require a really strong signal to work well compared to analog. Can you get any analog channels through the tv itself? You will probably need to get a large antenna mounted outside to get these channels to work especially if you are a distance outside the city from where the broadcast is coming from. Sorry for the bad news. It is one of the bad things about the digital transition.
Benjamin
Posted on Mar 25, 2009
  • 374 Answers
SOURCE: HOW TO HOOK UP TWO SATELLITE RECIVERS THAT I HAVE
Ok since you have A 625 it uses different technology than the 4000 in a sense but I will assume that whomever connected the 625 use a Dish Pro Plus LNB. You can verify this by going out to the dish and looking at the LNB which is the eyes if you will on the dish. The cover facing you will read DP Plus, or Dish Pro, Dish Network, or you may have nothing at all on the housing. You will want it to say DP Plus for the easiest install.
On this LNB there are three ports. You will only need the two on the left if looking at it so you can not read the housing. One of the ports will be connected to a line running to the 625 and the other to the 4000. The line going to the 4000 should not contain any breaks in it after the ground block if one was used. Once inside the house connect the line from the lnb for the 4000 to the back of the receiver. Conect the receiver to the TV and run a check switch. This receiver will go into a test of 1 of 38 if all connections are good. A 1 of 50 indicates a loss of signal somewher on that side of the install.
The 625 can utilize di plexers but that type of install is to detailed to go into straight away so we will connect it using a straight feed to TV2. Run the cable from the LNB into th room with the 625. Inside connect that line to a siver device called a seperator that came with the receiver and connect the two leads from it to the sat in ports on the back of the receiver. Connect a line to the Home distribution port on the back of the receiver and run it to the room with the second tv you want to have DVR in such as a mater bedroom etc.Connect the cable from the tv out port on the receiver to the tv. Power all devices on and run a check switch. This test should read 1 of 3 if all connections are good. A bad connection will read 1 of 38 on the receiver. A total absence of signal will stay at 1 of 1 for a longt ime brfore going to 1 of 38.
You will need to call dish and activate the 4000 rx since it has not been on the account for some time and will need a software update that they will send to it via satellite.
Other obstacles could arise and if they do let me know. Thanks for using Fix Ya.
Posted on Mar 01, 2010
All I get is static when I use my T V Ears. Everything hooked up properly, have new battery. What's wrong?
Hook up your TV cable to Bell , Rogers , or satelite box , make sure cable is connected good.
Feb 27, 2012 | TV Ears 10241 Professional Listening...
We move the tv from living room to bed room and we have to change the chanel from 3 to 60 to get the tv to work on dish network, we try to change from 3 to 60 we try evereything whit no result, we call...
Rescan all the channels?Hook the tv and the satalite signal cable in the tv and dish network box correctly check?Go to tv menu.Goto SETUP,pick CH. pick option CABLE enter to rescan all channels.This should have all the channels,belong to the package u order.
Sep 04, 2010 | Televison & Video
HOW TO HOOK UP TWO SATELLITE RECIVERS THAT I HAVE LIKE MODEL 4000 DISHJNETWORK RECIVER I FOUND IN MY CLOSET AND MY NEW DISH NETWORK RENTED DVR 625 RECIVER HOW TOO HOOK BOTH OF THEM UP TO THE 3 CABLES AND...
Feb 28, 2010 | DISH Network DVR-625 DTV Receiver /...
Does my TV need a NTSC tuner to watch dish network if it is NOT hooked up directly to a receiver?
No your tv does not need a tuner if you are not hooked up to the reciver. If you have one of the recivers that does two tvs then you just need to find the right chanel to put the tv on. It can be any where from 56 on up to 166.
Feb 01, 2010 | Televison & Video
Cancelled dish & hooked up rabbit ears. no local channels
Benjamin
Mar 25, 2009 | Insignia Digital-to-Analog Converter for...
Digital converter
If you recieve your signal on this TV over the Air (Rabbit Ears) then Yes you will need a digital Converter for this TV. If you are hooked up to Cable or a Satalite Dish, your TV will continue to work without the converter box.
Dec 29, 2008 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Oct 23, 2008 | JVC AV-56WP74 56" Rear Projection...
Sanyo DP 37647
What input did you connect the satalite to? Probably one of the 'video' inputs I'm guessing, which means you have to select that video source using the 'INPUT' button on your remote. (Some makers use different names but you get the idea)
Hope Ya Fix it!
Dec 29, 2007 | Sanyo DS27510 27" TV
26", HDTV monitor, Theatre Wide HD, NTSC standard, "Moving DOTS"
YES IT WAS A STATIC FREQUENCY COMING FROM YOUR AC OUTLET TRY TO USE AC FILTER FROM YOUR OUTLET
Apr 24, 2007 | Toshiba 9.6 STN Color LCD Screen Assy...
Televison & Video Logo
Top Televison & Video Experts
