Question about Blue Computers & Internet
I can't get into my laptop a blue scree appears and say error code Oxc000000f185 I am trying to get a recovery disk for my laptop. also it has msrpc.sys. how can I get a recovery disk
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 27 Answers
You can use a rescue disc
Posted on Apr 23, 2017
Marrie
  • 563 Answers
SOURCE: Projector Problem- Screen appears Blue
Hi there
Press the source button on your Projector until it reads RGB.
If this doesn't work , right click on your desktop and go to properties - check that your seconadry screen is attached in your advanced settings.
Posted on Apr 30, 2008
SOURCE: error 10E716045D
When I first trying system recovery the recovery would complete and when rebooting it hang at mup.sys in the drivers, now I get this error 10E716045D.
Toshiba A105-2716
Posted on Nov 15, 2008
  • 166 Answers
SOURCE: Trying to use Toshiba "recovery Disk creator"
u need a blank dvd, or tell the program your using regular cd, it will be like four dvd's or like 11 regular disks. in some cases it wont work with either, i have seen it where the program just doesnt know any disk is inserted or blank. if thats the case, update the program or contact toshiba
Posted on Sep 01, 2009
SOURCE: recovery error 320 on sony vaio laptop
Ketanvasu your an idiot....If he's trying to recover the laptop obviously the thing isn't working...so how the hell is he supposed to burn cd's genius?
Posted on May 18, 2010
  • 2567 Answers
SOURCE: Hello to everyone, I have been reading forums for
This is a typical sign of a defective hard drive.Your hard drive might or might not be repairable, depending on the degree of damage.
I would recommend that you use a live CD (such as this one: http://www.ultimatebootcd.com/download.html) to boot up your computer & run a hard disk diagnostic tool like HDD Regenerator. It might take several hours (sometimes days) to fix the damage. If this did not help, then you will have to replace the hard drive.
Posted on Jul 22, 2011
When the computer boots, it display bluescreen
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.If after running the Check Disk Utility you still have problems you will probably need to reinstall windows. Look into doing a Repair Install so that you don't lose your data.
Apr 24, 2012 | HEWLETT-PACKARD 630 Notebook
Igxprd32 error
Apr 13, 2012 | Computers & Internet
I am getting a blue scree error on my IBM Thinkpad R51 that says unmountable_Boot_Volume. It will not let me run on save mode...it brings me back to the blue scree error message. I have windows xp
Unmountable boot volume = The file system is damaged and cannot be mounted.
To fix that do the following:
1.Put the CD first in the boot order and boot from the XP install disk.
2.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3.Select your partition - it should be C
4.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5.At the command prompt, type chkdsk /r , and then press ENTER.
6.At the command prompt, type exit , and then press ENTER to restart your computer.
This takes a bit longer, but the system should boot back into Windows.
Jun 14, 2010 | IBM ThinkPad R51 Notebook
I have compaq C772TU Laptop. The problem is that Its hard disk warms up in 3 minutes after startup and after some time it hangs and shows a blue scree error. Please help me out to resolve this problem....
If it has the blue screen error, try to turn off the pc, remove the power cable and battery. Press and hold the power button for 5 seconds. Reseat the cables and battery. turn on the laptop.
If Blue screen occurs, turn off the pc and reseat the Hard Drive. If it still occur, then that is the time to replace the hard Drive..
May 25, 2010 | Compaq Presario 1700 Notebook
Error Code: Oxdooooo1e
this is a memory fail...and it is usually caused by errors on the disk or ram memory ...try to not use the recovery disk .and instead use a clean windows and boot until you have the choice to delete the partitions and format again from scratch..
after that install to the end and use the recovery cd just for the drivers ...
Jan 28, 2010 | Acer Aspire 3680 Laptop
Trying to use HP Recovery CDs on notebook. When
This error comes because of bed indexing unit in harddisk.
For that boot your computer with recovery disk then follow the procedure then delete all partition 1 by 1.
Then create new partiton.
then fomrat 1 partition and install windows.
Try this 4 to 5 times then you can success .
Let me know if you need further assistance.
Thanks.
Nov 04, 2009 | Compaq Presario Notebook
Hi i just want to know what will i do if my comouter crashed when i open it theres a blue scree appear that it says that my computer was shut down please help me thank you..
It is because of your harddisk has bed indexing for fix errors on harddisk you need recovery disk.
Then boot your computer with recoverry disk.
When you power up the computer press F1 or F2 or "del" key to enter in bios .
Then go to boot option then set first boot device as your cd or dvd rom.Then save and exit.
Then put disk in rom then power up follow the porcedure on screen.Then choose recovery console then type in prompt "chkdsk /r"
then press "y"
then it fix error on harddisk.
Then check if still same blue screen you need to repair windowes for that boot again with disk and choose repair windows option.
Let me know if you need more assistance.
Thanks.
Oct 05, 2009 | HP Pavilion dv9000z Notebook
Error : 0x400110020000100A
Look carefully at the hard drive that you are replacing. When you take it out of the [mine is a Compaq f750us] computer you might see, for want of a better term, a "STRETCHER" attached to the contacts/connectors, remove it. Put it on the NEW hard drive, put hard drive into computer. Try it again. I did and I did NOT get the "error" code! Why because the HD is now CONNECTED...touches the contacts..
Jul 22, 2009 | HP Pavilion DV6700T Notebook
When trying to do things on my laptop i get a blue screen error and than it goes into start up repair. It does not do this all the time every few days or so my question is this the hard drive or if i were...
hii i read through ur problem you can try this hope this will solve the blue screen errors
if u turn around ur laptop you can find centre piece of the laptop most probably it might have 2 screw uncrew it and take the cover out carefully , you will find a long chip take it carefully and dust it and place it again.ram some times caused the blue screen error
Next try to run recovery console , run the recovery disc if u got with u and it will asked couple of Q's press R for recovery
if still not resolved revert back with the exact error code so that i can get it fixya
Nov 01, 2008 | Computers & Internet
Blue screen error
unplug hdd replug and then check if not recovery cause u cant boot ur pc to safe mode also..if u have win cd try repair it
May 12, 2008 | Computers & Internet
Computers & Internet Logo
Top Blue Computers & Internet Experts
vince
Lawrence Oravetz
Are you a Blue Computer and Internet Expert? Answer questions, earn points and help others
