Question about Power Computers & Internet
2004 Chevy Silverado the gage lights won't come on now it's like the battery not charging
No power at all and battery is new
  • 793 Answers
Hi,maybe you need to get the alternater checked.
Posted on Apr 23, 2017
My 2004 Chevy Silverado 3500 won't start I get clicking and the lights work, battery is new and has full charge and I replaced the starter and it ran great for about a month. Now I cannot get it to st
Believe it or not the starter may have gone bad again. Check all wires to the starter motor too. One broken or loose wire there will do it too. With the headlights on, attempt starting, if lights don't dim even a little then the load on the battery is not increasing indicating an open circuit to the starter OR inside the starter.
Oct 12, 2014 | 2004 Chevrolet Silverado 3500
On 2004 chevy silverado
Take the positive lead off the battery. Touch the battery with the lead on and off for about five to seven times. This should reset the alarm. Reconnect the positive lead and using the remote control for the vehicle alarm arm and disarm the alarm once before operating as normal.
May 17, 2013 | Cars & Trucks
My 2008 silverado won't start battery is charged
No, it isn't an ignition issue.
Check power to the starter motor solenoid.
If this is getting power when cranking, then the issue is with the starter motor solenoid or starter motor. Replace.
Nov 12, 2012 | Cars & Trucks
2004 chevy silverado crewcab 4x4 110k, recent 100k service check engine light came on - checked gas cap, not problem used stp gas treatments, light went out, rough idle continues loud clatter from...
just depends on what work was done and what was replaced last service
clatter and loss of power etc
could be timing out . a spark or fuel delivery issue
to clear the codes
undo the battery terminals ...count ten reconnect
if engine light stays on
there will be fault codes to be read from the ECU
Apr 29, 2017 | 2004 Chevrolet Silverado 1500 Crew Cab
If i disconnect battery will it remove message?04 chevy silverado
only temporary. it will come back on again until the problem is fixed.
Jan 25, 2010 | 2004 Chevrolet Silverado 2500HD
2004 Chevy silverado 2500HD the left stop light not working
use a testlight turn on the LS light ground the test light touch the pin inside the lamp socket if it lights look for a bad ground if it does not check your fuses or, run a new power wire under your truck secured with zip ties from the switch
Apr 20, 2009 | 2004 Chevrolet Silverado 2500 Crew Cab
Check gage light comes on for 2004 chevrolet trailblazer''
Check gauge light can come on for a number of different things, from Low fuel to low oil pressure to high engine temperatures. When the light comes on check all the gauge's and see whats causing it, one or more of the gauge's will be showing an issue, Low fuel or low oil pressure, Low battery power. Any of the mentioned things can cause it... Figure out whats causing it then you can remedy the situation...
Apr 19, 2009 | 2004 Chevrolet TrailBlazer
2003 Chevy 2500HW won't start
recheck battery cables make sure there clean and tight. sounds like its not geting good conection, or starter is bad.
Feb 01, 2009 | 2003 Chevrolet Silverado 2500HD
Computers & Internet Logo
24 people viewed this question
Top Power Computers & Internet Experts
waruna
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Power Computer and Internet Expert? Answer questions, earn points and help others
