Replaced agitator dogs but still won't agitat or spin
The bottom part of agitator doesn't turn but will drain
jsrock516
  • 5911 Answers
SOURCE: Roper washer, agitater stripped?
It sounds like you need to replace your agitator dogs (yes, there is such a thing). They are small plastic pieces that are used by the upper portion of the agitator to grip as it turns. This is a common problem when they wear out. If you go to searspartsdirect.com, there's an illustration of what I'm talking about under the "Agitator, Basket and Tub Parts" heading. Item number 10 (part number 80040) is what you need to replace. Just type in your complete model number in the "Search by Model Number" block. The following link provides you with step-by-step instructions on how to do this:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
You can find these same parts at repairclinic.com and a cheaper price. Use the part number provided. I hope this helps you.
PS The item is priced for a package of 4.
Posted on Aug 06, 2008
TheMobilian
  • 8220 Answers
SOURCE: agitator spins in one direction
The purpose of the upper portion of the agitator is to push the clothes in a downward motion. As the agitator moves the dogs grab and on the backward srtroke the top portion rotates a quarter turn. In the spin mose the agitator only goes in one direction or your clothes would be torn to shreads.As the washer rotates back and forth, the dogs grab the inner walls of the upper agitator and that forces the clothes into a downward movement to the bottom of the tub. These dogs will wear out. To test whether or not these are bad just grab the agitator while in wash mode. The dogs should advance the top portion easily. If not then they are worn out. To replace them you must remove the agitator and sit it on the floor. Hold the base down with your feet and yank the top upwards. After seperating the 2 pieces you simply install the new dogs and line up the bottom with the top being careful not to break the little tabs on the bottom agitator that hold the top in place.
Posted on Dec 22, 2008
  • 221 Answers
SOURCE: 10yr whirlpool toploader wash machine no spin/agitat. but works?
When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Posted on Jan 08, 2009
jsrock516
  • 5911 Answers
SOURCE: Won"t spin or agitate. Makes a loud rattling noise
If this is a Whirlpool manufactured TOP LOADER (such as Roper, Estate, Kenmore, Amana, and Frigidaire), you may have a damaged or broken motor coupling. Whirlpool manufactured top loading washers use a motor coupling between the drive motor and gearcase (transmission) in place of a drive belt. This configuration is known as "direct-drive". The coupling can break through normal wear and tear. Washing frequent loads of heavy items and reduce the life span of the coupler. Common symptoms include the following:
1. No spin or agitation.
2. Washer will fill and empty.
3. Drive motor still runs.
4. Strange rattling, grinding or clicking noise during agitation or spin cycles as the drum sits still.
If your washer is exhibiting these symptoms, then its probably a safe bet that the motor coupling is bad.
The following link explains how to replace one:
http://www.fixya.com/support/r3574231-replacing_a_motor_coupling
The part number for a replacement motor coupling is inlcuded in the link I provided. Replacements can be purchased at any of the following websites:
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I have listed also included helpful exploded view parts illustrations to assist you with locating and properly identifying any parts you may need.
If you have any questions, please post back with your complete MODEL NUMBER (located on a nameplate along the wash tub rim under the lid) and let me know. I hope this helps you.
Posted on Dec 17, 2010
SOURCE: WASHER FILLS WITH WATER, THEN WON'T AGITATE.
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Posted on Jul 23, 2011
Will not drain, spin or agitate
make this test and fix it. God bless you
First you will need to identify if you have a direct drive type or a belt drive. The later is obvious if you have belts under your machine it is a belt drive, if not it is a direct drive. Also there are 2 basic agitator types with some variances among them. The 2 piece and the single.
Agitator Dogs
The agitator dogs are in the 2 piece type of agitator. These wear out over time. They also break and can cause noise. To inspect and replace the agitator dog .
Agitator Coupling / Spline
The other type depending on age of your machine use a spline. Newer GE types have a coupling that gets stripped out and the older GE type has a spline directly on the agitater that gets stripped out. You will need to remove the agitator. The dispenser usually pulls right out. This will give you access to the bolt that holds the agitater down. Remove the bolt, then place your fingers under the agitator and pull up. This can take some force. A belt slid under the agitater can also work. Once off you will see if it is stripped or not.
Belt
If your washer is a belt drive type make sure the belt is tight. Check for black soot from belt wear. Replace if it has excessive wear or broke.
Motor Coupler
This is a fairly common problem with direct drive machines but inexpensive and easy to replace. The Motor Coupler transfers power from the motor to the transmission. The following video will walk you through the replacemente motor coupler.
Transmission
The transmission does not usually fail. To check this on a direct drive remove the motor and then turn tub inside. If it spins freely with no noise the problem is elsewhere. If it is noisy it needs replacing this is expensive and depending on the age of your machine you may not want to replace it. On a belt drive remove the belts and spin tub.
Jul 25, 2013 | Washing Machines
Kenmore top load washer won't agitate, but will drain and spin
your dogs may be bad in the agitater.. if u open the lid and turn the agitater back and forth does it rachet or does it turn freely both ways?
Dec 13, 2012 | Kenmore Washing Machines
Washing machine spins not agitate
your "dogs" in the agitater may need to be replaced.
Mar 07, 2012 | Washing Machines
Kenmore 28803 Washer, Top portion of agitator not spinning. Bottom is spinning fine.
The problem with the top portion not rotating on the agitater is going to be because of worn out agaitator dogs. This tip i wrote covers exactly how to replace the dogs
http://www1.fixya.com/support/r10294924-top_part_agatator_isnt_turning_top_load
GENE
Oct 16, 2011 | Washing Machines
The upper part of the agitater doesn't agitate during the cycle and spins freely when the machine is off
as it seems you know the dogs need replacing and this youtube video i have a ttached will show you step by step how to do that
http://youtu.be/0GQh8JLqVv8
Jul 25, 2011 | Whirlpool Kenmore Washer Dog Agitator Set...
The agitatae doesn't seem to be cycling the
The agitator is made in two parts. Upper and lower. The bottom part does the actual agitating.
The upper part is supposed to be loosely fitted. It just screws down the clothes to contact
the bottom agitator slowly.
The top part turns one way, and slips the other way. By the action of what is called "Dogs" inside
the top part. These dogs are probably worn and need to be replaced
Take the top off the agitator and there is one bolt in the middle of the agitator. use a long extension
to reach the bolt and remove it.
Pull off top agitator (keep it straight up so you don't lose the dogs_
Go to local Appliance store and ask for Agitator Dogs.
Replace Dogs exactly as they came out
When you re-assemble the top it will be loose. This is normal.
Good Luck!
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 24, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
After top load washer fills with water you can hear the agitator but the agitator does not move
IF WIRLPOOL AGITATOR DOGS FUNNY A REMOVE CAP OF AGETATER REMOVE CAP INSIDE AGITATER REMOVE 7-16 NUT PULL AGITATER OFF FIRST CHECK TO SEE IF IT SPINS IF IT DOES DOGS IF NOT A DRIVE COUPLER IS YOU PROP ITS INBETWEEN YOUR PUMP AND MOTOR
Apr 03, 2010 | Washing Machines
The top half of the agitater does not work it just
There are small plastic parts called "dogs" that wear out. The agitator needs pulled apart and those dogs replaced. It is fairly simple to do.
Jan 09, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Replacing the dog something or others in the agitater
The following link explains what "agitator dogs" are, and gives the steps necessary to replace them:
If you have questions, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
Jan 27, 2009 | Kenmore 24032\24036 Top Load Washer
Washer does not spin and drain water. (Kenmore Elite Heavy Duty)
it seems to me ur washer transmission is going out or already there
Nov 26, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
