Power I have sound just no picture why - Televison & Video
How do I fix a tv that turns on but has no picture or sound?
if it has no sound or picture then it must be the power supply .
Nov 22, 2015 | Televison & Video
No picture or sound
Looks like a power supply issue the only solution to fix this up is to get it repaired.
May 03, 2008 | Toshiba 32HFX72 32" TV
Red light flashes on power switch, but no picture or sound on tv
tv will not power on. red light on switch blinks. power relay clicks, but no picture or sound.
Jul 28, 2009 | Toshiba DVD Recorder AND Series2 TiVo...
At first, no power, no sound, and no picture. I replaced the power source board. I have power and sound but no picture.
verify your connections you may have the video cable connected to a different input than your audio
Apr 14, 2009 | Televison & Video
TV power light comes on but no picture/no sound
chip on ic board repair shop might replace it and reprogram if the tv is worth the fix
Feb 05, 2009 | RCA Televison & Video
No picture or sound?
hi i have a 42 inch plasma samsung tv i have picture and no sound
Nov 03, 2008 | Televison & Video
Hi again
yes 3x its lamp cover no doubt. ballast supply will give different error on this unit. this should help hdtv man
Diagnostic Item
Number of times
lamp flashes
Probable Cause Detected Symptoms
Lamp cover error 3 times - Lamp cover is not fastened securely - No picture/No sound
Fan error 4 times
- Fan1-4 Power is not supplied.(G2 board)
- Fan connector is not seated securely
- Fan caught wires or harnesses
Temp error 4 times
- Internal temperature is too high
- IIC-E line connector is not seated properly
(WE:H3 board, WF/XS:H4 board)
Lamp driver error 5 times - Lamp driver defect - No picture/No sound
Low B error 6 times -No "DD 6V " output (G1 board) - No picture/No sound
Audio error 7 times
- Short-circuit of Audio power supply line
(KD board, G1 board)
- Blowout of a fuse
(F4702,F4703,F4704 on KD board)
- IC failure
(IC4703,IC4708,IC4710 on KD board)
D-OVP error 8 times
- Overvoltage of +3.3V or +2.5V
(A board, B board)
ATSC-OVP error 10 times
-No "DTL MODULE 5V " output
(G1 board, G2 board)
Lamp error LAMP-LED is ON. - Lamp is dead - No picture/No sound
Jul 01, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
