Question about ZAGG Computers & Internet
Remove keyboard How do I remove zagg keyboard from ipad
My zagg case/keyboard turns on but doesn't connect to my ipad
Don't forget to switch on bluetooth. Then look under devices if your keyboard comes on the screen. It could be the device is asking for you to type in a code like 0000 or 1234. Or whatever.
Only when you did pair the device to your iPad, it will be able to see the keyboard when you switched it on.
Oct 18, 2014 | ZAGG Computers & Internet
Can not get keyboard to pair with ipad
Make sure the keyboard has been fully charged. Most BT keyboards do have provisions to get power from the iPad.
Jul 18, 2014 | ZAGGkeys Cover and Bluetooth Keyboard for...
Cannot get ZAGG keyboard pair to iPad
Check that the keyboard's battery is working and it's on. Turn on Bluetooth on the iPad (Settings > Bluetooth). Press the keyboard Connect button. Choose the ZAGG Keyboard on the iPad, and type the code on the keyboard.
This doc describes the process:
Good luck! :)
Mar 25, 2014 | Apple iPad Tablets & eReaders
Pairing Zagg keyboard and iPad 4
There must have been some updates to the IPad that made it not recognize the board. Either take the Ipad back to before the updates were put in or look for a patch at the manufactures site.
Jan 27, 2014 | Computers & Internet
My Zagg keyboard won't connect with my iPad2 and the connect light continuously blinks. Please help.
On your ipad, go to bluetooth close out of it completely and reconnect to your Zagg keyboard! Worked for me, hope it works for others.
Jan 21, 2014 | Computers & Internet
The letters B & N do not show up on the iPad3 using the Zagg Keyboard. This includes upper and lower case. All other letters show up fine
Joke-something against barnes and noble?
Try using something to stop the static buildup on those two keys. That could be the issue, esp. if you use them often. or was it always this way? a thin metal file should be rubbed under the keys GENTLY so you don't pop them. Then try again or consult your warranty.
Oct 23, 2013 | ZAGG folio Keyboard for iPad 3 and iPad 2...
Zagg keyboard Will not work after connected by Bluetooth in ipad2
I have a Zagg keyboard for my iPad mini. I found the same thing happened but then realized it only works in most apps, not all. For example it doesnt work when typing in a password in settings. Try you keyboard in an app like notes. Also make sure you haveheld down the power for long enough that the light is red for 5 seconds.
Sep 28, 2013 | Apple iPad 2 Wifi 16GB
Zagg keyboard doesnt work
Mine went dead after about 3 weeks. Once I realized there was a charging port which is not IPhone, but droid type. Began charging. Would not recognize until I went to blue tooth setting and said forget device. Then turn bluetooth on and then hold bluetooth key down on for 3 seconds or so on keyboard. Then it worked. I guess dont let it run till it dies.
Apr 16, 2013 | ZAGG New Apple Ipad 2/ Brand New Ipad...
Computers & Internet Logo
Top ZAGG Computers & Internet Experts
Paul Wang
Are you a ZAGG Computer and Internet Expert? Answer questions, earn points and help others
