Question about Samsung Refrigerators
I have a samsung side by side refrigerator that i left the frig door open all night , now its a noise that shuts off when i open the refrigerator door what can be the cause of the loud fan sound
  • 958 Answers
SOURCE: samsung side by side refridgerator making noise and freezing
its a heater cycle problem..the defroster is not working properly. its building up ice in the evaporator that touches the evaporator fan that makes that loud noise but stops when you open a door. it could be either a bad heater, a bad thermo disc or a bad timer.hope i was able to help
Posted on Feb 12, 2008
  • 5 Answers
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Posted on Sep 20, 2008
  • 22 Answers
SOURCE: refrigerator
the fan behind the ice maker is iced up poss fault defrost heater gone try total defrost faor a list 36 hrs restart it noise come back then you need to repace the defrost heater hope this helps
Posted on Nov 13, 2008
SOURCE: Right Door is making loud popping noise
After reading these posts, I fixed my refrigerator door in less than 5 minutes. The little black plastic cam on the bottom hinge was loose. To fix it, take the hinge cover off of the top with an 8mm socket, and remove the three 8mm screws holding the top hinge on. Remove the door by lifting up off of the bottom hinge and set it aside. On the bottom hinge is a black plastic cam held on by an 8mm screw. The screw on mine was really loose. Tightening it and putting the door back on made it work like new. You probably don't have a bad cam, just a loose one.
Posted on Dec 25, 2008
SOURCE: noise (more detail)
I think I answered this in an earlier post.
The noise is the fan banging against the motor housing. It's not a defective motor, it's a poorly designed motor.
The solution is to shim the motor mount so it is slightly out of level which will keep the fan from bouncing off the motor housing.
The reason Samsung won't service is they don't understand the problem. I've seen this a half-dozen times.
Trust me -- SHIM THE MOTOR MOUNT!
Posted on May 27, 2009
Manual for samsung frig RF263BEAE8R/AA
Go to manufacturer web site for manual download.
Aug 25, 2017 | Samsung Refrigerators
Freezer is cold, refrigerator is warm.
If your evaporator fan is working (the fan in your freezer) you might want to check the air baffle. That is located in the back of your frig section. It is most likely all the way top left. Put your hand in front of it there should be air coming through the baffle. If there is no air coming through you either left your door open and froze the inside lining if your refrigerator or your air baffle control is broken.
If you left the door open and it froze the lining the only solution is to shut it down and leave both doors open for at least 24 hours straight. There is no way to get the ice out.
Nov 20, 2011 | GE Profile PSI23NCR Side by Side...
Refigerator is not cooling but the bottom freezer is working fan is running in frig are there 2 compressors? door was left open on the frig for several hours by a kid before problem started pls...
if the freezer is working fine - and the fan is running in the refrigerator I would give it a little time (24 hours) to catch up (from the door being left open).
hope this helps
Jun 14, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Suddenly making noise from above the refrigerator behind the vent
Almost certainly there is an ice build up which has eventually migrated to the fan blade. Do a 12 hour defrost to ensure a proper "defrost", then try again. Very possible the door was left open slightly by accident.
Jun 08, 2010 | Sub-Zero 695/O Side by Side Refrigerator
Refrigerator side makes noise, not getting cold
I have same fridge freezer & luckily a extended warranty, engineer has been out on numerous occasions & the motor is getting freezed up, which is why the noise stops when the door is opened. Get rid of it! No solution to the problem...its a faulty appliance & a well known fault with this model or so I have been told. Good luck.
Aug 26, 2009 | Samsung 26.0 Cu. Ft. Side-by-Side...
Maytag frig side by side door pops open when I shut the other side
the ref. is not level or too much wieght in the freshfood door
Jun 03, 2008 | Refrigerators
Frig and Freezer not working.
Beware I bought a Frigidaire side by side in 2006 and the compressor went out in March 2008, the warranty was out in Jan, and the repair man came out and said it was a 2004 model, you might have the same one as I had, they know the compressors are bad in the frig's and you only pay,$160.something if I remember. It sounds just like the problem I had, good luck!
Mar 29, 2008 | Frigidaire FRS3R5EMB Side by Side...
Samsung RSE8KPUS noise
I have worked on refrigerators for 30 years but never worked on a Samsung. This is a WILD and I do mean WILD guess at what the noise may be. Don't use this information to attempt a repair but just to track where noise may be coming from.
There is a motorized damper door that opens and closes between the freezer section and the refrigerator section. My guess is that that damper assembly is what is making this noise. I can not tell you why it may be making this noise except that if is making the noise it probably is going bad. Remember this is just a guess and you will need to locate the damper assembly in order to try to pinpoint the origin of the sound. Your recording was wonderful and I wish more people in my everyday job would use their heads like you. I hope this sheds some light on the problem. Remember I am just guessing, don't spend money till you are able to verify cause.
Seems there would be a 1 year warranty on the frig.
supertechks
Nov 22, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
21 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
