Question about PfaFF Sewing Machines
Pfaff performance 5.0 won't start up. Machine is 10 days old and was working fine when I shut it down for lunch and now it will not start back up.
  • PfaFF Master
  • 11,462 Answers
Is there an On/Off switch that has been turned off? Verify that the cord(s) are fully plugged in. You can also try a different electrical outlet. If it still will not work, you should return it to the vendor who sold it.
Posted on Apr 23, 2017
  • 2 more comments
  • Gord Condie
    Gord Condie Apr 24, 2017
    Thank you R.A. Ellis, have tried all of these suggestions and still no go. Have called the vendor and they will be looking at the machine tomorrow.
  • R.A. Ellis
    R.A. Ellis Apr 25, 2017
    That's great! They will most likely take care of the issue.
  • Gord Condie
    Gord Condie Apr 26, 2017
    Original vendor is going to replace machine with a brand new upgraded machine as this model is no longer being produced. Should have new machine by Friday. Awesome service!!
  • R.A. Ellis
    R.A. Ellis Apr 26, 2017
    What a deal! Enjoy your new machine!!!
Where can I get service manual that will show me the exact procedure from start to finish a adjusting a 145 pfaff sewing machine? I do not need parts manual or service manual to thread the machine?
go google and type in --workshop manual for PFAFF sewing machine model 145
there is a site that is pdf version down load but before you down load it open the version up to see if it is a workshop manual or repair manual and nor service or operators manual
Nov 14, 2015 | PfaFF Sewing Machines
Pfaff 1371 pressure foot won't come down on it's own
I just addressed this issue with my 6110. There is a spring in the shaft for the pressure foot. Over time the white grease that lubricates the spring and the plastic piston at the top dried up, gumming up the works. I took it all apart, cleaned out the bad (now hard grease), re-greased and put it all back together. Works like new. I used a lithium grease as it is easy on plastic parts.
Sep 04, 2012 | PfaFF Sewing Machines
Pfaff 1371 hand wheel is frozen and presser foot won't lift up or down
the machine needs to be checked to see what's wrong with it
Jun 11, 2012 | PfaFF Sewing Machines
Old Pfaff 130 machine partially frozen
check carefully around the bobbin holder area as fluff and threads around here are known to jam the shaft
Jan 18, 2018 | Sewing Machines
I have the Pfaff 7530, Quilt and Craft Pro. It is about 15 years old. It needs about $500.00 worth of work to be operable again. Is it feasible to spend this and have this machine fixed? or put a little...
Hm, this decision is probably too personal for someone else to answer. For what it's worth, there's a 7530 on eBay--bid starting @$650.
You'll need to decide if $500 to fix your machine is worthwhile to YOU. How much faith do you have in the repair person? Unfortunately, sometimes, even when machines are repaired, they can still have other parts fail. However, there are repaired machines that will run for another 15 years without any major problems. I'm just assuming (based on the cost), the problem with your machine involves a computer component which is a common issue with computerized machines. Like all computers, there are parts that will fail over time...that's just their nature. For the most part, computers will fail within 5-10 years. However, if they are installing a brand new computer component, it could be like a brand new machine.
On the other hand, you know your machine and you know what is wrong with it. Purchasing another used machine leaves you in the dark as far as whether the machine works properly, how it's been treated and serviced, if shipping is involved, will it be packed right and not arrive damaged, etc. Sometimes, just the comfort of knowing that makes your machine worth fixing.
If you contemplate replacing your machine, just sit down and make a list of all the options on your machine that you cannot live without. Then set out in search of machines that fill your list of must-haves. The price may help you make your decision.. Finding a new replacement machine could cost a couple thousand dollars.
Pfaff Creative 7530 Pre owned sewing machine
Thread What would you do Pfaff 7530
Nov 17, 2017 | PfaFF Quilt & Craft Pro 7530
Pfaff 360 automatic slows and stops after only minutes of use
Pfaff 360's don't like to sit, they like to drink. . .. oil.
Set top knob "C" to 0
Right top (zig-zag knob) set to 4, lever below but on the same dial points straight down. Set stitch length to 4. Run 5 minutes medium speed.
After that lift off the top cover and spray inside with "Tri-flow", then run a hairdryer on it for 20 minutes to warm up or set near a warm lamp overnight. Run daily 5-10 minutes and exercise the right knob between 0 and 4 (zig-zag). It should come back to working with oil, time, and heat.
Apr 13, 2009 | PfaFF Creative 7570
Pfaff Tiptronic 6270 just stopped working!
There is a fuse in the the base plate that has blown. It is soldered in and is special fuse you won't find at Radio Shack. Unfortunatly it needs to be fixed by a Pfaff dealer on someone with access to the fuse. If you have the work done, make sure they replace a certain reisitor on the base plate at the same time to prevent this from happening again (per Paff).
Sorry for the bad news and best of luck.
Jan 15, 2009 | PfaFF Tiptronic 2040
Pfaff Creative Vision embroidery/sewing machine says motor overload then shuts down
I had the same problem and it was my power supply. I've had more than my share of problems with this machine and it's only 3.5 years old. Good luck.
Nov 08, 2008 | PfaFF Sewing Machines
Sewing Machines Logo
55 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
