Question about Kenmore Vacuums
How do I repair tgepile height pedal on kenmore 28014 intuition vacuum? It's stuck on low pile.
Kazong
  • 152 Answers
SOURCE: Can I fix height adjusment?
all i no is on the bottom of unit there is 2 smaller wheels that control the height adj. see if that the prob.
Posted on Mar 02, 2008
johncaman
  • 201 Answers
SOURCE: I have a Kenmore progressive cannister vacuum cleaner.
There should be a pile height pedal on rear of the attachment, just behind the where the wand goes into it, near the handle release pedal. Just keep clicking on it to go through the height settings.
Please rate if this helps :)
Posted on Mar 05, 2009
RockyNR1
  • 324 Answers
SOURCE: Kirby vacuum height adjuster is stuck in high
Remove the nozzle and remove the front wheel shaft. Take these 2 screws out.
When doing so - watch for the spring that is under the top pedal, do not let it fly out of window. If you will find that shaft is bent buy and install a new shaft (you can find all parts HERE). You may try to straighten it but usually it doe not last long - wheel ***** falls off and you have to buy new shaft anyway. If shaft seems to be ok - clean old grease and dirt, lubricate well the pedal teeth and assemble everything back. This should solve the problem. Occasionally spring may be broken but this happens very rarely.
Good Luck,
Rocky
Posted on Apr 10, 2009
SOURCE: vacuum height won't go on low carpet setting.
Make sure you're not trying to adjust w/ handle in upright locked position because thewre is a cam which raises the vacuum head a little bit when handle is locked in upright position. If this is not the problem, turn vacuum upside down with handle in unlocked position and power cord not plugged in(for safety reasons obviously), unscrew and remove 3 screws that hold belt/beater brush assembly cover in place(2 are in corner near ends of beater brush and 1 is towards motor housing) tilt end of cover with 1 screw up and remove cover(there are 2 tabs at beater brush end of cover). Right above this is the height adjustment assembly with 2 rollers, raise up the assembly gently and using your finger or a bristle bottle brush,etc. make sure there is no debris caught between the height assembly and the hose(you will understand when you see it), if there is no debris you can now see the pattern on the bottom of the height adjustment knob and the lobe that rides on it, just check to make sure nothing is broken and/or missing, hope this helps!!
Posted on Dec 29, 2009
  • 177 Answers
SOURCE: is there an operating manual on the web for a
Hi, here is a link to a site that holds the manuals, but you will need the model number of your cleaner. Hope it helps! Please rate me. :) http://www.managemylife.com/mmh/owner_manuals/search/product_type.Vacuum,%20Upright?query=Kenmore
Posted on Jul 17, 2010
How to change height adjustment on kenmore canister power-mate?
My powermate has a little pedal on the bag of the beaterbar housing that you press all the way down with your foot and then release. Each time you press down it changes the height from 'xlo' to 'lo' to 'med' to 'high' and then it starts over again.
See the attached picture
Mar 23, 2016 | Kenmore Vacuums
The beater brush will no longer drive under a load on short pile carpet
Have you tried changing the height adjustment? There should be a knob or lever that allows you to adjust the height of the beater brush to accommodate different carpet lengths. Even with a new belt, the brush will not spin if the height is too low. Try adjusting it all the way up, then while it is running, adjust it down until there is some resistance. The beater brush should just barely scrape the top of your carpet.
Aug 30, 2015 | Riccar 8955 Upright Vacuum
Wont move forward or backwards
Generally the belt is probably stretched and needs replacing but I have had several that required modifying the height adjustment assembly. Belt should be a bit of a fight to stretch and get the brush block back in properly to maintain resistance. The higher carpet causes the belt to slip and can even cause burn/wear from the motor shaft spinning in one spot. Sometimes people run them and burn through and break the belt. Generally you smell rubber burning if belt is slipping and burning. The height adjustment modification was a last resort and not easy! Not for the average person! Another post tells how to modify but better be handy!
Dec 07, 2013 | Hoover Vacuums
Can I fix the high, medium, low level switch on vacuum piece?
The height adjustment lever on Kenmore Power Nozzles is one of the machine's weak points. It's not well made as far as being protected from dirt and dust and moisture. It's always easier to move these things when the vac is on it's side or at least with the front end in the air. That takes the pressure off the adjuster. The mechanism may need nothing more than to taken apart in the presence of a good air compressor which can be used to blow out any of the aforementioned debris.
Nov 11, 2013 | Kenmore Vacuums
Need belt 38528- brush belt
belts will stretch when they slip. There no adjustments on beater-bars. The way to prevent this is to have a height adjustment to be high on high pile and low for low pile rugs.
Oct 28, 2013 | Hoover U5780-900 Windtunnel Cyclonic...
My brushes wont turn once the vacum is on the carpet.
If they are turning when they're off the carpet, then you have the brush height setting set too low. There should be a dial somewhere near the brushes, some say things like "high" to "low" or "high pile" to "low pile." Turn it one notch towards high/up and try it again, and keep turning one notch and trying until the brushes turn. You want them as close to the carpet as you can get them without them stopping. If this doesn't fix it, you have to be more specific as to whats going on.
Aug 19, 2009 | Dirt Devil Vacuums
Dirt devile featherlite vacuum pushes extremely hard on high pile carpeting
the dirt devil featherlight has a automatic height adjustment for carpet and bare floors.check the wheels and see if there is something wrapped up around the wheels
Apr 28, 2009 | Vacuums
Mar 05, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Mar 01, 2008 | Hoover U6434-900 Bagged Upright Vacuum
Agitator stops when sweeper is pulled backward
If you have made no changes to the vacuum's setup and are using it on same carpet you have previously used it on with no problem, then the most likely cause is the agitator/beater bar's drive belt is worn or on some models may have a tension adjustment which is set too loosely. This can also be caused by having the vacuums height adjustment set to low for the carpet or flooring you are using it on, causing to much drag when the vacuum is pulled backwards for the agitator to overcome.
The vast majority of agitators turn in a forward direction, as if it would pull the vacuum forward, when you pull the vacuum backwards the drag is increased.
So...First check height adjustment (a no cost fix), then check out the tension adjustment (if present on you model, some engage when top of vacuum is tilted back after stepping on the release pedal) Lastly, consider changing belt especially if you have had the vacuum awhile or if it gets a fair amount of use or it you seem to need to use it on a low height setting all the time to vacuum up debris.
Hope this helps!
Dec 19, 2007 | Kenmore 34923 / 34925 Progressive Bagged...
Vacuums Logo
55 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
